Question about Dryers
Kenmore gas dryer not getting hot enough
I replaced the Cycling Thermostat but the dryer still takes a long time to dry. The model# 110-87874100
    President:
  • 1,902 Answers
Have you checked the lint trap and also the vent hose? If you have yet to do that try it. Also make sure that the vent line is not crushed. It needs to be wide open
Posted on Feb 10, 2009
GE Dryer model DDE8509R0MWW is getting warm but not hot, takes forever for clothes to dry :(
Check the ductwork for excess lint, kinks, bird nests (yes) or anything else that would restrict the air flow. There is a lazy man's shortcut for electric dryers ONLY: Disconnect the dryer vent and run a load of damp clothes... if the dryer dries the load in normal time, the duct is clogged or kinked. If it doesn't, it's something wrong inside the dryer.
The most common reason for your problem is the cycling thermostat. This is cheap and relatively easy to fix. GE cycling thermostats require turning OFF the power and removing the front of the dryer. It's located on the blower housing. Two wires, two screws. If you have an ohm meter, a good one will read zero ohms.
http://www.repairclinic.com/PartDetail/Cycling-Thermostat/276447?modelNumber=DDE8509RCMWW
The other possibility is the heater element. GE has a dual element. If half of this heater breaks, it takes a long time to dry towels and jeans. Incredibly, GE gets about $200 for these because you can't replace only the heating coil (which was only about $30)... you have to buy the whole unit. This requires removal of the drum. Not impossible for do-it-yourselfers, but it's a challenge for first timers.
Good luck.
Mar 03, 2011 | Dryers
Heating Element Won't Shut Off
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
May 26, 2008 | Maytag 24 in. MDBH955AW Built-in...
Dryer control doesn't move on less dry more dry setting and will not shut off when clothes are dry.
If clothes are hot then try dryer on timed dry. If timer does not move then timer is most likely bad . Replace. If timer moves on timed dry it is not getting hot enough to click the cycling thermostat.(If clothes are overly hot above 160 then the cycling therm. is stuck Replace.
Oct 29, 2010 | Dryers
My GE Dryer dries but only after a longer time than before
One of your heating element is probably out of commission. You can replace it cheap. Here's how:
SOME REPAIR PICTURE
Dec 16, 2009 | GE DBSR453EBWW Electric Dryer
Taken to long to dry
IF ELECTRIC
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
IF GAS
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Aug 21, 2009 | LG Dryers
Our dryer takes multiple cycles to get clothes dry. Eventually the clothes dry, but it takes forever.
If your dryer is taking more than an hour, check these. Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws. It overheats Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat (read about cycling thermostats in "Drying is too slow," above). It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But?if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork
Jun 12, 2009 | Whirlpool Dryers
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
1. Venting
2. Thermostat
3. Heating element
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
Does not completely dry clothes in the time it used to
For Electric Dryers, check the following---
1. Venting
2. Thermostat
3. Heating element
For Gas Dryer, Check the following---
1. Venting
2. Thermostat
Jun 01, 2009 | Maytag Dryers
Changed motor now dryer works until its too hot
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
Heating element stays on
Vent
Heating element
Internal ductwork
Cycling thermostat
Mar 07, 2009 | Whirlpool LER7646J Dryer
Dryers Logo
593 people viewed this question
Top Dryers Experts
