Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Machine keeps flashing F-51
Happens on every load. except delicate
This happened to me, everytime I washed clothes it lite up F51 and wouldn't go through the cycle to drain. I had to manually put the machine on drain and spin to get the water out.
After three times of having the repair man come I called Whirlpool and said I had a lemon and it couldn't be fixed and the machine was replaced. They are allowed to try three times to repair the machine for the same problem, like it lighting up F51 and then they have to replace the machine as a lemon while the machine is still under warranty.
I hope this was of help. The delivery man said that the machines are bounced around so much during transit that it's no wonder they have problems.
Posted on Feb 16, 2009
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Does not enter drain and spin cycle on delicate setting
Machine stop at 51 sec after started ,start button flashing nothing is happening ?
Dec 29, 2013 | Amana Washing Machines
F-51 code
Motor RPS Failure--F then 51 flashes when there is a motor rotor position sensor(RPS) senses rotation after stop command.F-51 ERROR CODE IS DEALING WITH THE SPIN CYCLE. THE CONTROL DOES NOT DETECT IT SPINNING.THE RPS SENSOR ON THE BOTTOM OF THE UNIT NEEDS TO BE TAKEN OFF AND PUT BACK ON ABOUT 10 TIMES. SOUNDS WEIRD BUT USUALLY FIXES IT.But if that does not help then it needs to be replaced. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Sep 01, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Help
F then 51 flashes when there is a motor rotor position sensor (RPS) failure.
It can also be a defective control board false reporting an error which is common on these models.
Apr 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Maytag flash F 51 and ul error
Unbalanced load, open lid and redistribute the load, close lid and press START/PAUSE.
Oct 19, 2009 | Maytag Bravos MTW6600T Top Load Washer
Timer light keeps flashing
sounds a s if you have ablockage within oyour pump assy, remove th elower acess panel and undo the "button trap" your problaby clogged up, the drain pump is humming, causeit cant pump any water
Jan 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops and must be restarted flashes F51
there is a updated wiring harness and sensor on the the bottom of this tub on the motor. It needs replaced
Nov 13, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
121 people viewed this question
Dan Webster
Dan Webster
Sal De
