Question about Xerox Phaser 6180N Laser Printer
Graphics print with pink background
On any .doc I put together, if a graphic is included then it prints against a pink background. How do I resolved this problem? Thanks.
  • 1 more comment
  • pudge1972 Feb 12, 2009
    The Config Report, under Network Setup, says it is Firmware Version 10.66. The Engine Version is 05.08.00.
    I tried to update the firmware with your link but the FirmwareUpdateTool, once mounted, won't launch.
    I seem to be connecting (wirelessly) to the printer via ma MAC Address (not through the IP Address.) Would this have any bearing on the problem whatsoever? Thanks for your help.
    G4 iBook, 1.33 Ghz Power PC
    OSX 10.5.6
  • wigmeister11 Feb 19, 2009
    I have the same problem. Anything I print has is printed twice, once with black ink and once in pink the background.
    I checked the firmware and the engine versions (10.66 and 5.08).
    Everything seems up to date? Any other suggestions
    President:
  • 2,072 Answers
That is a firmware issue. You can go to Xerox.com and follow these procedures.
Print a Configuration Report and review the Engine Firmware Version section to determine the firmware version. See the Related Items below for additional information.
Firmware version 05.08.00 or higher can be installed to resolve the image quality problem. If necessary, upgrade the firmware version. See the Related Items below.
If the printer's firmware version is currently at 05.08.00, replace the Print Cartridge. See the Related Items below.
graphics print with pink background - elem_1_spacer.gif Related Items:> Go ToMicrosoft Windows OS Firmware Update Version 05.08.00
> Go ToApple Macintosh OS Firmware Update Version 05.08.00
> See AlsoHow To Print the Configuration Report
> See AlsoHow To Replace the Print Cartridge
Posted on Feb 12, 2009
  • Rick Kasper Feb 13, 2009
    No, your connection would not be causing that problem.
    Since you are at the proper level of software then the most likely cause is the print cartridge.
I just replaced my old Printmaster with the 2011 Platinum. I designed business cards using the template from the list. But when I print, the cards are too large to fit on the page. I've tried reducing...
According to your problem you want print a business card and face the with font size & background
colour. It may caused your printer settings.
# First check your paper size in your printer propreties. It must be visiting card size.
# check printing resolution.
# printing quality in printing preferences should be suitable for a card printing.
for your second problem find the background graphics option in your printer properties and set it
properly.
For supported resolution, background image see ith product mannual
Dec 20, 2010 | Computers & Internet
Have a dell 942 AIO. graphics in grey seem to print purple
what OS are u using ?
U may will have to unistall the driver Again ( make sure that the printer is unplugged) . run Patch .. ( Available at support.dell.com )
Reinstall the Printer drivers again ( downloading from Dell Website .. install them ( make sure that the cable is connected only when Prompted ) )
This should resolve the Problem
Mar 20, 2010 | Dell 942 All-In-One InkJet Printer
User prints a Powerpoint 2007 doc and several of the slides have missing info. One has the upper left quadrant partially printing and two others have 3/4 of the slide partially printing. Fresh install of...
I would recommend you download the latest drivers for your printer, and also check to see if your powerpoint has updates as well.
also, its possible your printer does not have enough memory to print complex graphics, try reducing the quality or resolution of your file.
thanks adi
Dec 16, 2009 | Computers & Internet
I have a tally 2250 printer to beused under win98.
you can installed this printer driver of genric text only.
Jun 25, 2009 | Tally T2250 Matrix Printer
Missing graphics
Depending on what program you are using go into your page that you are trying to print and go to print setup, look for include graphic and background. Next go into your advanced printer settings and make sure that print back ground is activated.
Feb 05, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP2100 laserjet won't print inserted pix in Word 2007 doc
I ended up fixing this problem myself.
I needed to set the printing resolution in the HP printing dialog box to 1200 x 1200 dpi as the HP2100 can print at this resolution.
Select: Print/Properties/Advanced/Graphics. Then set the printquality to 1200 x 1200 dpi.
Rod Salter
Dec 15, 2008 | HP LaserJet 2100 Printer
Cartridge/Printer problem - very weird (HP PSC 1315)
quiet easy you have to change you print selection to all or everyday printing that way it will print both color and black all together instead of not this and that
Mar 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Happy Laser Jet 4
Hi there you could try the following see if this helps.
  • Click Start
  • Select Printers and Faxes
  • Right hand click on the printer Icon
  • Select Properties
  • Select Advanced located at the top of the window
  • Select Print Processor
  • On Right side of window select Raw [FF auto]
  • Exit all open windows then test
If the same problem repeat above and select different graphic mode. Hope this works for you
Thanks J
Jan 07, 2008 | HP LaserJet 4 plus Printer
Won's print pdf files
Trouble with the HP Laserjet printed output may be solved by using the following settings (or similarly named ones): "Use raster Graphics" (instead of "Use vector graphics"). This may fix the problem of "reversed" text (white on black background) not printing, as well as other problems. "Download TrueType Fonts as bitmap soft fonts" (select "bitmap" instead of "outline" or "graphics"). This may remove the overlapping of text on the printed document. "Graphics dithering" select "coarse" or "fine" (instead of "none"). This selection may improve the quality of images contained in the document. You can find all these settings in your printer properties. Go to File, Print, click Preferences, in Printing Preferences, click one by one all the top options, and change one of the top solutions, one at the time, checking your printing output. Always check if you have the latest version of Adobe Reader Program. If not download the latest version from Adobe, it's free. Is this the first time that you have the problem? or with the same printer (HP 4si), did you were able to print PDF files in the past?
Sep 10, 2007 | HP LaserJet 4si Printer
Xerox Phaser 6180N Laser Printer Logo
440 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
