Question about Troy Bilt Pony 6.5 Hp Rear Tine Tiller
What type oil goes in the tranmission?
In a troy bilt pony rear tine tiller
  • Anonymous Mar 28, 2014
    my troy bilt pony will not go in forward or reverse
  • 69 Answers
80W90 Gear oil goes in the tranny. 30W is for the engine only,
Posted on May 06, 2009
Trans oil! 90 or 140 wt.
I use 140 in my older tiller.
G
Posted on Apr 27, 2009
    President:
  • 1,073 Answers
Recomended oil is Briggs & Stratton 30W Engine Oil
Good luck to you
Nic
Posted on Feb 10, 2009
Troy bilt pony 5hp rear tine tiller is leaking behind muffler on side of motor
Head bolts are probably loose, check the 3 nearest the mouffler and of course check all of them.
May 09, 2011 | Troy-Bilt Pony Garden Tiller
I WAS JUST GIVEN A TROY BILT 5 HP REAR TINE PONY ROTA TILLER. THE DECAL WITH THE MODEL NUMBER ETC. ON THE TINE CASING IS UNREADABLE. DO YOU HAVE ANY IDEA WHAT MODEL THIS MIGHT BE? I WOULD LIKE TO GET A...
The serial # of the tiller should be stamped directly above the right wheel on the transmission housing. This should give you more info to work from.
May 02, 2011 | Troy-Bilt Pony Garden Tiller
What oil goes in the gearbox behind the motor , I have a junior
any type of gear oil will work for this. I know some gardners that use tranny fluid for heat
May 04, 2010 | Troy-Bilt Pony Garden Tiller
What kind of oil do you put in the gearbox of a 15 year old pony tiller
Hello. The older models use SAE 90 or SAE 140 weight gear oil. joe
please rate my answer as very helpful. Thanks. Joe
Apr 25, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I cannot get my oil seals of my rear tine tiller It is a Troy Bilt 5.5 hp and I got the left side off but the right side tine attachment will not budge any suggestions please
Have you tried soaking the shaft area with either PB Blaster or Deep Creep penetrating oil. Try this for a few days before trying to tackle getting the tine attachment off.
Jan 26, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
My neighbor let us use his troy built tiller and it needs oil but he doesn't know what type of oil to put in the transmition. please help
The recommended lube for a Troy Bilt transmission is 140 Gear Lube. It's tough to find. If you use lighter oil, the trans seals will likely start to leak.
Jun 06, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Replace tine shaft oil seals - Junior model
on my pony the disc came off when i removed all of my tine shafts. then i pulled the old seals out an drove the new ones in
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy bilt pony left side tine assembly fell off
sounds like the shaft is either bent,or the inside diameter is worn and the shaft tube needs to be replaced.
Apr 23, 2009 | Troy-Bilt Pony Garden Tiller
Troy tiller tines
they should point inwards and towards the rear of the machine
Oct 17, 2008 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
685 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
