Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
Ac power only
Laptop will not run on the batterie but the batterie works fine in friends laptop
  • Anonymous Feb 11, 2009
    hi thanks for the reply but that did not solve it
  • 716 Answers
Make Sure The Battery Is Making Good Contact With The Metal Prongs. It Must Not Be Making Good Enough Contact Some People Have A Good Result From Sticking Penny In The Battery Compartment To Press The Battery Against The Contact. Also You May Try Bending The Contacts Toward The Battery.
Posted on Feb 10, 2009
Power on problem
hello my friend,
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
hope it will help you today.
Aug 30, 2011 | Computers & Internet
My acer 5920 wont charge or wont work on ac adaptor but the ac adaptor works fine on my friends laptop
Either the AC port on the back of your laptop has a lose connection - if operation without battery is an issue, or if battery charge only is issue - then battery may have to be reseated or it is at end of life. Test by removing battery and running AC alone. if connection port is bad, laptop will power off immediately/unexpectedly. Good luck! btw - batteries for this unit are around $40 on ebay
Jun 14, 2011 | Acer Aspire 5920-6706 Notebook
Runs on battery only wont charge or run on ac power charger working on another laptop fine
Computer power probems are traceable to batteries, ac cables and power outlets. First, the computer batterie should charger fi were situated appropiated in the compartments without ac cables power cord malfuctions.
Jan 28, 2011 | HP Pavilion dv6000z Notebook
Approximately 5 weeks ago I started getting the message when on AC power that the "smart AC adapter is not providing enough power" (something like that anyway!) And even though plugged in would...
first, you need to try to power on your laptop with another battery with the AC adaptor plugged in. if your problem was not solved you need to check the power jack on your mothernorad.
Jan 02, 2011 | HP Compaq 6735s Notebook
Dell 2650 DC wont work
make sure the charger you purchased has the correct voltage out and amperage(in millivolts) as requested by the laptop computer, if not you risk the chance of damaging your laptop. although they fit in the power plug, it does not mean theyre compatible. The specs should be located at the bottom of the laptop or inside the battery bay.
Apr 01, 2010 | Computers & Internet
Compaq N610c does not power on on AC adapter or on Battery :(
it might be that the AC adapter is no more working. To confim this, remove the laptop battery and test the AC adapter with the laptop.
You can also borrow a friend's AC adapter and test it with your laptop.
I wish you good luck.
Mar 03, 2010 | Compaq Evo N610C Notebook
Hi forum, I have been using Compaq N610c notebook and was working fine but was not power ON . on AC adapter but it was working on Battery. From last day, the battery become zero showing battery indicator...
It's possible that the AC adapter "died", and then your computer ran on battery-power until the battery went to 0%.
Or, the socket on the laptop where the AC adapter connects could have broken, or become disconnected from the motherboard, such that the power from the AC adapter was not being accepted, meaning that your computer was running on battery-power.
Take the AC adapter and the computer to a qualified technician, who can test that the AC adapter is working fine, and can disassemble the laptop, to inspect that socket where it connects.
Computer switching between battery & AC power.
Hi friend,
You can release the battery then use the ac adapter for run the computer..if your computer is runing then you need to change the battery...
Jan 06, 2010 | Dell Inspiron 9300 PC Notebook
HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
55 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
