Question about Microsoft Office Professional 2007 Full Version for PC
Word makes a duplicate file automatically
When i save a file in word,it makes a duplicate automatically.but the duplicate looks like a hidden file with "~$" in front of it/ e.g. file name - school duplicate        - ~$ school
  • cuddyniall Feb 10, 2009
    thanks for the quick reply.
    no "always make a backup copy" was not checked.but "allow background saves" was checked would this be the problem.It is only a recently occuring problem and it only seems to be for office files.
  • cuddyniall Feb 11, 2009
    thanks again, but how do I stop the $ files from appearing in my documents
As i know when you open a word or excel file it automatically creates a backup file (as told by you), it is because Microsoft has make it like that if while working in a word file if you system shutdown then you can get the edited part back by opening the document itself.
Just do one thing close all the word files and then delete all the $ symbol files or duplicate files. and it is done... Nothing to worry...those are unnecessary files.
Posted on Feb 11, 2009
Check TOOLS --> OPTIONS on the SAVE tab. See if "always make a backup copy" is checked.
Posted on Feb 10, 2009
MAKE YOUR S60 DEVICE FASTER AND RECOVER RAM In the next few posts i will...
In the next few posts i will post some tricks to make your phone faster and also recover precious RAM.
If you are running low on phone memory and have a lot of apps installed, you can recover a part of it by transferring help files to the memory card.
open Xplore or fxplorer and move C/resource/help to E/resource/help.
All the apps will find it automatically in the E drive.
This trick will increase your phone memory thereby making your phone a little bit faster.
first use jbak taskman to kill lifeblogobserver process
make sure x-plorer is set to show hidden files
then go to c/data/lifeblog/database
now delete the lifeblog.dbfile
reboot phone
now use jbak taskman to kill lifeblogobserverprocess once again!
select llifeblog.db file and press 6 tick hidden and read-only reboot phone. You'll notice the phone's boot up is faster and it will also release some RAM.
if you want to use lifeblog again go toc/data/lifeblog/database
and untick hidden and read-only
3. STOP AUTO STARTUP OF APPS ( for a faster boot up)
You can disable the third party applications to boot at start . These applications boot at startup and slow down the phone,s startup. In order to stop them to boot them use the following process.
The info of all the start up apps is stored in c:\private\100059c9\start.dat
whenever you allow any application to start automatically at startup the file start.dat is updated. The simplest method to disable the apps to load at boot up is to simply rename the start.dat file i renamed it to start.dat.txt. After renaming it your phone will boot as it boots after a fresh formating.
When ever you again want to enable the startup apps just remove the .txt extension.
You can also edit start.dat file to enable some applications to boot at start up and disabiling others but i don,t know how to edit .dat file. But you can edit it if you know how to edit it.
The easiest method of editing the .dat file is to delete the old start.dat file and then go to the applications which you want to boot at start up and rechange their setting ie (enable auto start=yes). A new .dat file will be created automatically which will only boot those apps which you want.
You can even further boost up your phone start up by renaming files like
C:\private\100012a5\DBS_101F99FE_NSml_Adapterlog.d b
C:\private\100012a5\DBS_101F99FE\NSml_adapterlog?? ?.dat
C:\private\100012a5\DBS_101F9A02_nsmldmfotaadapter .db
To .txt files or simply delete them.
Deleting all these files is the other name of restoring your phone to factory setting without losing any application data. Deleting these files also deletes sim data mean the network data of all the sims used in a phone. When you will rename all these files your all phone setting will be lost like clock time ,month date year. When you will again set different settings like adjust the ,adjust the date duplicate files of all the files you renamed or deleted will be created mean fresh data files .to again gainyour original setting as they were before applying the hack just delete all the duplicate files and rename all the above files as they were before renaming and restart your phone all your setting will be restored.
on May 09, 2010 | Cell Phones
I was using gmail; opened excel file; made changes and saved now i can't find the document. Help!
If you clicked "Save" not "Save As", the file is likely in your temp files somewhere.
The method to find the file is tedious - but if it is on your computer - this will find it.
Click Start>Search for Files or Folders and then under the When Was it modified - put in the date range for when you saved the file.
Next - in All of Part of the File name type: *.xlsx
Next - In Look In - make sure to choose the whole C Drive.
Next - In More Advanced options, make sure to check the System Folders, Hidden Files and Folders, and Subfolders.
Then click search.
If the Excel file is on your computer - this search should locate it.
Nov 03, 2011 | Microsoft Office Professional 2007 Full...
I cant find my hidden files
you have to go to folder option, then view, then click on the show hidden files and folders. the go to my computer, then local disk c: the documents and settings, then your username and you will see files you didnt see get to folder options once your on your username after documents and settings, go up to the top and click on tools, then you will see folder options
May 27, 2011 | Computers & Internet
I tried downloading a map update for a brand new garmin nuvi 1300 and now it says cannot unlock maps and doesn't work. Any quick fix?
These are the instructions for unlocking maps from the Garmin website:
  1. Log into your myGarmin account1
  2. Select myMaps
  3. Click Manage Maps and Downloads
  4. Below the appropriate device, select the "Details" link
  5. Look for the Unlock Code listed on this page
  6. Copy all the unlock codes for your device
  7. Close your internet browser
  8. Right click on your desktop
  9. Click new, and then click Text Document
  10. Click on the newly created Text Document icon from the desktop
  11. Type your unlock codes into the document
  12. Click File and Save as
  13. Change the file name to gmapprom.unl
  14. Change the “Save as type” to "All files"
  15. Close the document you should see the file gmapprom.unl on your desktop)
  16. Right click on the gmapprom.unl file and then click copy
  17. Connect your Garmin device to your computer and click Computer/My Computer
  18. Click on the 'nüvi (drive letter:)'2
  19. Right click on the Garmin folder and click paste (see next line for nuvi 1xxx series)
  20. For nuvi 1xxx series devices, the gmapprom.unl file is required in the ".System", "Garmin" folder which is a hidden system folder. In order for you to see the hidden system folder:
    • For XP:
      1. In MyComputer go to the Tools menu and choose Folder Options...
      2. Select the View tab
      3. Select the radio button next to "Show hidden files and folders"
      4. Uncheck the box next to "Hide protected operating system files (Recommended)"
      5. Click OK
    • On Vista:
      1. In the Computer window go to the Organize menu and choose "Folder and search options"
      3. Select the radio button next to "Show hidden files, folders, or drives"
      5. Click Ok
Safely disconnect your Garmin device from the computer to complete the process. If you are having any issues duplicating the steps above or are still receiving the message "Can't unlock maps, your unit will not function without maps” please contact Product Support.
1 The device must be registered to view the Unlock Code.
2 In My Computer, some units may be labeled 'garmin (drive letter:)'.
Aug 07, 2010 | Garmin nuvi 1300 Car GPS Receiver
How can i remove duplicate photos in Windows photo gallery?
Hi There! The easiest way to remove duplicate photos is to go through and delete one by one.
Dec 10, 2009 | Microsoft Windows Vista Home Basic for PC
I have thousands of duplicate music files on my computers for itunes. They make a mess of my library and take up hard drive space. How can I erase the duplicates without having to manually delete each...
What OS you use..
if it's windows.. please google
Sep 12, 2009 | Apple iTunes
Need to remove duplicate files
Hello rvpooley
My name is Billy.
PC Junktion is dedicated to finding solutions to those pesky computer problems.
Since you know what kind of files your are searching for, In XP, Windows Search Companion makes it easy to find duplicate files with the file search utility.
There are also many fine and free programs for accomplishing this mechanical feat. Let's first look at the Window's utility.
Create a Folder on My Desktop by right clicking and select new folder. Name this folder "Mixed up files" or something you can remember. It will be on your desktop.
GOTO->START->(menu pops up)->Click Search(magnigfying glass icon)->All Files and Folders->
Stop and take this in.
Text files will end in .txt, word docs end in .doc or (2007) .docx
picture files will most likely be .jpg, .bmp, .gif, or .png.
We are going to use a wildcard search. An asterisk(*) represents the filename ina wildcard search.
For example in the [All or part of the filename] Box, we can search for ALL files of that flavor.
Type these wildcards in the first box exactly or copy and paste.
*.txt; *.jpg; *.gif; *.bmp; *.png;
LOOK IN: Drop Down Box-> CLICK->My Computer
Click Search. Be patient, there may be more than you know of...
Wait for the utility to finish.
GOTO Edit in the Toolbar and choose Select All. Move to the folder you created in My documents.
You know have them in one folder (on your Desktop) and now I will find a utility to handle the job.
You may want to back up to a DVD or CD in case of a crash.
I will be back tomorrow.
Hope this helps for now.
PC Junktion
Apr 02, 2009 | Computers & Internet
I don't know how to access my Western Digital Backup. I have no icon to click.
If you have a WD Media Center, Dual-option Combo, or Dual-option USB external hard drive, you can use the Retrospect Express software that comes with the drive to create a backup schedule that will backup your data onto the drive.
To setup an automatic duplicate schedule in Retrospect Express 6.5 on a PC, please follow the instructions below.
  1. Start Retrospect Express by pressing the Automatic Backup button on the front of your Media Center external hard drive after you have installed the Retrospect software and powered on and connected the drive.
  2. You will be presented with the Western Digital Automatic Backup Wizard. Click Next to continue.
  3. Highlight the drive(s) that contains the data you wish to backup and click Next. To select multiple drives or folders, hold down the Ctrl key and make your selections.
  4. You will have a choice to backup your documents only or all files, make your selection and click Next.
  5. Highlight the drive you wish to copy your data to and click Next.
  6. You will have the option to run the data duplication daily or once a week. Make your selection and click Next.
    • If you choose a daily duplication, you will have to select the time that you'd like the duplication to start each day, then click Next.
    • If you choose a weekly duplication, you will have to select the day and time that you'd like the duplication to start, then click Next.
    • If you wish to run the duplication one time when you are finished setting up the schedule, check the Start the backup now box and click Finish. Otherwise, just click Finish.
    • You will see the Automatic backup button glow a solid blue. When the blue light is on it indicates that the automatic duplication schedule is enabled and your duplication is set to run at the scheduled time.
For the duplication to run successfully, you must have both the computer and drive powered on and connected correctly at the scheduled time.
May 28, 2008 | Computers & Internet
Lcd screen shows white screen and black marks
you can fix the problem by having the original sansa files when you format it it deletes everything
get a friends sansa files or do this
and just because it would be a pain looking for the original files i uploaded here for people who deleted them put these files into a folder named
REFS--no files
and put them in into 1 folder named SYSTEM--make it hidden then put it on sansa
then create a music folder make it hidden
then create photo folder with thumbnail and my album folder make my album hidden
then create pictures folder make it hidden
then create playlists folder make it hidden put this file in it
make a record folder with 2 folders named radio and voice
make a folder video
captilize all these except the one listed below
make a tmp folder
this should work :)
Mar 11, 2008 | SanDisk Sansa e250 MP3 Player
Microsoft Office Professional 2007 Full Version for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
