Question about GE Monogram ZDI15C Automatic Icemaker
No ice cleaned and all steps done.everything comes on and fills but no water on freezing plate.if sensor is bad ,how do i check it?
    Brigadier General:
  • 8,619 Answers
Hi!
Please check whether the ice maker has been turned off. Here's how to check.
Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Please rate the solution.
Thanks
Rylee
Posted on Feb 10, 2009
  • Rylee Smith
    Rylee Smith Feb 11, 2009
    If your ice maker has stopped producing ice completely, check these, in this order:
    • Msure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
    • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
    • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace
    Please rate the above solution.
    Thanks
    Rylee
Have replaced everything and ice maker still doesnt work model ed5shaxmb10
An ice maker has 3 basic tasks:
1. Call for water.
2. Freeze.
3. Harvest.
Then the cycle repeats. There will always be some sensors that determine timing of those tasks. Home units usually have a bin level sensor (often an arm that's lifted as the bin fills) that can be locked in the up position to disable the ice maker.
If it's calling for water but not freezing, make sure the condenser is clean. (Sometimes they look clean but are plugged in the middle.) It has to get down to nearly 0 degrees to efficiently make ice, if it's not getting cold enough you may need a tech to figure out why.
If there's ice in the tray but it's not harvesting, clean the tray, hard water deposits can make the cubes stick in the tray.
May 26, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Scotsman ice maker, short freeze code no ice
this Scotsman Prodigy had bad Ice thickness probe, error was for long freeze cycle. Hope this video will help someone
Jul 13, 2014 | Kitchen Appliances - Others
I have kenmore freestanding ice machine. Water flow fine, will not cool. Can I add free on and if so where
You do not add freon to these units, they are sealed, no access ports installed from the manufacture. If you are actually low on freon than you have a leak and will just end up in the same place you are now. Some things to note since you have not posted a model number. Does the water come into the reservoir when you first turn it on? Does the water circulate over the freeze plate shortly after it's done filling? Is your condenser coil on the bottom behind the toe plate completely clean of dust? With the toe plate off are all of the components running, like the compressor, and fan motor after your fill time has expired? Please add a complete model number from the sticker on the unit for better advice. Pleazer Appliance...
May 07, 2014 | Kenmore 51lb. Clear Ice Maker
1 minute fill cycle,harvest cycle 3.5minutes water still filling the reservoir and down to a pan drain by the time reach the freeze cycle water seem to be in normal flow but the damage its been done before...
look for a stuck or otherwise malfunctioning water fill valve. one way to check, turn the machine off and see if the water is still running to fill it. start with that and let me know.
May 03, 2014 | Hoshizaki Cubelet Ice MakerDispenser Water...
Emerson ice maker not freezing ice, making small cubes and they are soft and mushy.. seems to not freeze ice solid and takes forever to drop ice
When was the last time you cleaned it by running ice machine cleaner through it. After a period of time algea, or slime will form on the chill plate where the ice is made. Sometimes its invisible to the eye, but it doesn't mean its not there. When this happens the machine will freezse the water, and when the ice tries to slide forward to the cutting grid, it catches on the chill plate. There are no sensors in the machine to tell it that this is happening and so the machine moves forward and starts running more water across the plate, which in turn runs across the ice caught on the chill plate melting it and using it as a ramp to fall into the bin melting the ice there as well. So, try cleaning it before taking any further steps, then if the problem persist feel free to get in touch.
May 15, 2012 | Emerson Im90 Portable Ice Maker
Refrigigerator ice maker is not working.
Pour about 2/3 cup of water into icemaker . If it freezes and dumps the cubes , replace the water valve ( the piece the wall waterline connects to on the fridge .). Also check the fill tube inside that fills the icemaker , to see if it is frozen solid . If so , then the water valve seeps and needs replaced . If the water freezes and does not dump , replace the icemaker . Check the coils below refrig , to make sure they are clean of dust , lint , pet hair , etc . An icemaker has to be 5 degrees to operate , and if the coils are not clean , that could bring the temp up to 6 or even higher .
Aug 29, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
GE Monogram Ice Maker makes ice, unit doesn't cool enough
This model Icemaker makes ice by flowing water across a freeze plate. It is located in the top of the unit behind the white cover directly below the ON/OFF/CLEAN switches. After freezing a sheet of ice it releases and slides to the cutting grid. It then drops into the ice bin and begins to melt and the whole process starts over again. The level of ice in the bin is controlled by the high level sensor on the right side of the ice bin. It is a whit tube with two wires coming out of the top. Without this sensor it can overrun the bin capacity. Bottom line this unit does not freeze ice, it only holds it like cooler does.
Jun 03, 2009 | GE Monogram ZDI15C Automatic Icemaker
Kenmore Coldspot not making ice
sounds like the flap that u can usually hear once the ice has stoppped coming out it sounds like a pop or thud ...what happens is the magnet goes bad and keeps the ice maker constantly open to the outside air causing ice melting and massive ice cubes.....usually a costly repair...check and lemme know
ps. id have a licenced repair guy check it out
Sep 30, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Scotsman CM250AE Ice Machine tech help
Check the bridge size adjustment at the top of the metal grid that the ice forms on. This determines the size of the cubes. Whenever you make a repair on the water system, especially on an older unit. make sure the unit is clean. A little bit of calcium deposits (or that other nasty looking stuff) getting into the passage ways will make it run erratically, and can drive you nuts.
Nov 06, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
GE Monogram ZDI15C Automatic Icemaker Logo
579 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
