Question about Craftsman Air Tools & Compressors
Craftsman compressor Model 921.153101, quickconnectplug won't fit
The quick connect plug won't fit into the quick connect socket. It seems a bushing is lodged part way, keeping the coupler half-way open. It seems it should come out, but the manual says nothing of this and I did not want to rip it out.
  • mark_fortenb Feb 10, 2009
    Okay, that'll do it. I just thought I was missing something. Thanks.
    Problem Solver:
  • 13 Answers
I had the same problem with my craftsman and I replaced the female on the compressor with a better quality no problems since.
Posted on Feb 10, 2009
How do I get an owners manual for a craftsman 3/4 hp air compressor model 919-150273
you can get quick connect adapters at home depot, lowes or most auto parts houses
Sep 03, 2014 | Craftsman Air Tools & Compressors
It was running fine. then for some reason it stop working
What ampage does your compressor draw ? If it is more than 10 amps you have blown a fuse . DO NOT PLUG COMPRESSORS INTO CIGARETTE LIGHTER SOCKETS ! RATHER CONNECT UP DIRECTLY TO YOUR VEHICLE'S BATTERY.
Jan 11, 2013 | Craftsman 40 Scfm 30 Psi 12v Inflator...
I can't get the hose to connect to the compressor.
after scewing the fittings on hose & compressor with thead tape (ofcourse) ,simply pull the collar back on the female fitting & incert the male fitting & release the collar .----------these may be called quick connectors but they require a little effert under air pressure.
Jun 03, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
CRAFTSMAN Air compressor Model: 919167450. IT'S GOT A LEAK" SO FAR SEEMS LIKE AIR ESCAPING AT CONNECTION OF COMPRESSOR TO TANK. THE COMPRESSOR THEREFORE DOESN'T SHUT OFF COZ PRESSURE LIMIT(PSI) IS...
Manual:
http://www.managemylife.com/mmh/owner_manuals/8336/CRAFTSMAN-Air-compressor-L0809089
Schematics:
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fP0040151-00001.png
Parts ordering:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Air-compressor-Parts/Model-919167450/0247/0703000/P0040151/00001?blt=06&prst=&shdMod=
Jan 08, 2011 | Craftsman Air Tools & Compressors
Need a new pressure switch for Craftsman model 919152920 compressor, but that part is no longer available. The switch doesn't function to even turn on the compressor.
You can purchase a generic/ universal pressure switch from www.grainger.com or ebay. Just look for the correct fittings and pressure cutout. Cost about $20. Before you order a new switch you should test that motor and pump are ok. Jump the wires on the pressure switch temporarily so line-in is connected to motor line. When you connect cord to wall plug the compessor should start and begin to fill. If function ok then order switch. If the motor does not start, may not be switch. Good luck
Nov 09, 2010 | Craftsman Air Tools & Compressors
Motor runs, but no air pressure builds in tank
Three things to check.
1) Check that the tank drain is closed
2) Check that your quick connect fitting at the discharge of your compressor is sealing properly.
3) There is a copper or aluminum line that goes from the head of the compressor to the tank. Check the fittings on each end they occasionally come loose due to vibration.
If all of the above is ok:
Check the head gasket of your compressor. The unit you have is notorious for blowing head gaskets.
Hope that helps,
under_psi
Aug 31, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Drain plug on bottom of tank, what size?
1/4" NPT, be sure that you only remove the fitting and not the entire bushing that fits in the bung.
Hope that helps,
under_psi
Aug 30, 2010 | Ingersoll Rand - Rand Type - 30...
I have an older Craftsman Air Compressor and the knob valve to reg the pressure seems to not be working. Can I replace it?
It is getting increasingly more difficult to obtain replacement parts for older compressors. If your regulator failed at a fairly high pressure adjustment, say around 100-120 lbs, you could just leave the old regulator in place and add a regulator when needed to one of the quick connects. Purchase a generic pressure regulator from Lowes and add quick fittings to easily connect the regulator or remove when not needed. You could also just remove the old regulator and work-in a new generic regulator in its place. Generic regulators sell for $20 - $40. Good luck with your repair.
Aug 06, 2010 | Craftsman Air Tools & Compressors
I have a Craftsman Air compressor 919.150380. My tire needs air. My husband passed away 3 yrs. ago, and I don't know how to operate it. Can't find owner's manual or one online.
Attach your hose and tire filler. They should be a "quick connect". Take the larger fitting and kind of slide it back and insert the smaller fitting. Let go of the slide and pull to make sure you have a positive connection. It will be easier to connect everything when there is no air pressure. There should be an on/off switch located on the right if the tank is facing you. Plug it in, turn it on and wait for it to fill up. Depending on how much air you need, you might have to put some in and then let the compressor cycle back up to its high pressure.
Let me know if I can help you further.
Mike
Jan 28, 2010 | Craftsman Air Tools & Compressors
Need to replace drain valve
The "welded nut" is the pipe fitting into which the drain valve or drain plug is screwed. It's usually brass and the valve or plug can be obtained through Sears or possibly and good harwarde store. Be sure to use pipe sealing compound or teflon tape on the threads when you re-install the valve or plug.
NOTE - THE AIR MUST BE DRAINED FROM THE TANK BEFORE REMOVING THE VALVE OR PLUG. ALSO, POWER SHOULD BE DISCONNECTED FROM THE COMPRESSOR!
Mar 04, 2009 | Craftsman Air Tools & Compressors
Air Tools & Compressors Logo
401 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
