Question about Amana 3.2 cu. ft. Top-Load Washer
Replacing belt Amana washing machine - lwd27aw. Belt broke, got new belt. Need help on how to put it on.
  • 716 Answers
Put The Belt On The Motor First Then Put What You Can Get Of The Belt On The Other Pulley And Turn It. It Will Give You The Anchorage Needed To Put The Belt Back In Position. If This Doesn't Help Let Me Know And I Will Further Assist You.
Sincerely,
Michael Scott
Posted on Feb 10, 2009
Amana washing machine will not spin keeps shuting off
If it's a front loader, check the bearing, they wear out.
Nov 22, 2013 | Amana Washing Machines
I need to replace the belt on my Amana ALW480DAW. The other one burnt up and broke. I have the new one. Do you have a diagram I could view to help me install the new one?
I used the following links:
http://www.partselect.com/ModelFrames.aspx?ModelID=29693&ModelNum=ALW480DAW&mfgModelNum=PALW480DAW&ManufactureID=1&Selected=31971&Position=7&mfg=Maytag&Type=&Mark=7
http://www.applianceaid.com/amana-wash.html#belt
Oct 21, 2009 | Amana ALW480DA Top Load Washer
Amana dlw330 washer belt urned & broke again
Had the same problem on a machine I worked on. Changed the belt... was burnt and broken. Second time I replaced the belt, I ran it through all of the cycles and listened to it on SPIN cycle.. Although it's spinning.. it's making an extremely LOUD noise... It's the Spin bearing that is gone out. When a load is put in, and in spin cycle, the bearing is oveloaded..(being dry).. and putting extreme pressure on the motor and belt. When the drum reaches a point where the bearing just won't spin, the belt stops, and spins on the motor pulley, wearing it through.. (And smoking a great deal).. until it breaks.. again. I believe the top "Spin bearing" is about 75.00 or so.. and a BEAR to replace. Hope this helps
Feb 26, 2009 | Amana DLW330RA Top Load Washer
Lwd27aw belt replacing
PULL THE FRONT LOWER PANEL, BELT SHOULD BE IN FRONT OF YOU. YOU MAY NEED TO DROP THE MOTOR TO GET THE BELT ON
Feb 10, 2009 | Amana NAV5805A Top Load Washer
Washer belt
To replace the belt on your Amana washer, pull the unit forward then tilt the top of it back to about a 45 degree angle. Once you get the right angle, the unit will rest against the wall behind it instead of falling forward. Take your new belt (availble through local appliance parts stores or on line from the manufactures web site) and first put it in the track around the large pulley, then the track on the smaller pulley on the right. Lastly, the pulley on your left should be moveable. Move the final pulley so that you can get the belt over it. It will then move back to a tensioning position.
May 14, 2008 | Amana NAV5800A Top Load Washer
Removing motor to replace belt for agitator
first unplug washer then there are 4 half inch bolts on the motor holding it to the frame take those out unplug the motor harness. then twist it out you may have to take the hoses off. then there are 3 torxs screws in the pump take them out and put new belt on same way you took off and then reverse the steps and you will be ok
Jan 30, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Does not spin out all the water
Sorry RickAZ, I have just joined the fixya family. I'm trying to get old unsolved problems off the list, so I'm just posting a fix. Congratulations on your replacement washer.
Jan 03, 2008 | Amana ALW480DA Top Load Washer
Changing belt on washing machine, that broke
to change the belt you need to remove the pump attatched to the motor. the pump is held on by either spring clamps or in older models, torx (star) screws. I believe the size for the torx screws is #20. slip the belt over the motor pulley and around the tension pulley and finally around the transmission. reinstall the pump and you're good to go.
Aug 18, 2007 | Amana ALW540RA Top Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
210 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
