Question about Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony KD-28DL11U increasingly slow start up
From standby, when TV switched on began to experience a delay of some 5 - 10 minutes which has now increased to circa 45 minutes starting up. Start up light flickers between green and red - as if searching for some sort of signal/s!
5 Suggested Answers
  • 142 Answers
SOURCE: Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Posted on Dec 01, 2008
SOURCE: TV switch light flickers 11 times but no function
Hopefully it is only a board component that needs replacing and your dry joints that need re-doing. I would advise that you take it to a television repair shop as this type of repair can be very complex (replacing resistors and capacitors just to name a few).
Posted on Dec 03, 2008
ginko
  • 19396 Answers
SOURCE: Standby Indicator flashing SONY KD-32NX100U
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
  • 83 Answers
SOURCE: Sony KD-28DL11U switched off by itself (went for
pls. cheks your tv main supplay pin is proper canacted.
IF ok .
then problum is inside of the tv set.
check EHT out put voltage pin Diode /ragistance/ capeceter is filed.
any out put voltage from EHT is Droping. then TV is swithed off by itself
Posted on Oct 20, 2009
Sony tv turns off
ahh..the 16 blinker..that's a clear sign that your control board is having a terrible 'hair' day. How old is the TV?
Feb 13, 2008 | Sony KD-32FS170 32" TV
My son stepped on a remote control for a DVR. The Sony Trinitron Wega KD 32FS130 went blank. Now it won't come on, goes into standby mode, with the red light blinking four times. Any suggestions?
It is possible that the button your son stepped on is stuck. If so, remove the batteries form the DVR remote control and see if the TV works. Unplug the TV from the wall for a few minutes to clear its memory to be sure. Some times remote controllers can have cross-talk, meaning it can affect other equipment,
Dec 27, 2009 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Sony KD-28DL11U switched off by itself (went for red light). when I try to switch it on again the control light is green but there is no picture nor sound. any idea what could have failed?
IF ok .
Oct 19, 2009 | Sony Televison & Video
My Sony KD28DL10U digital TV will not tune into freeview
I think this is one of the TV's that wont work as part of the Digital Switchover as it's too old. My Brother has the same TV and has had to buy a new Set top box to get Freeview.
Jun 10, 2009 | Sony Televison & Video
The standby/timer is flashing 6 times on my Sony KP-53HS30 TV
no the 6 blinks indicates a missing voltage. If your talking about a sony lcd KD or KE model you probably have a bad thermal fuse. You must also clean or change the Lamp fan so it won't blow again.
Apr 16, 2009 | Sony KP-53HS30 53" Rear Projection...
STANDBY LIGHT KEEPS BLINKING BUT NO PICTURE OR SOUND
just try unplugging it for a little bit and see how that works.
Feb 01, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Green symbol AV2 won't go away! Sony Trinitron KD-28DL11U
You need to have original Sony TV remote and press Display button on it, on-screen display will disappear.
Nov 25, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Power on problem
Many of the later model Sony TV?s have a built in self-diagnosis function. AKB circuit (automatic kine bias), the timer/standby indicator blinks 5 times for about 30 seconds then goes to the self-diagnosis function. In other words, the IC chips on the Cboard are burned out. This repair is not one that should be attempted by the end user. This repair will need special test equipment. You will need to take it in for repair. It shouldn't cost more than $170-$200. This is cheaper than a new TV set.
Jun 23, 2007 | Sony FD Trinitron WEGA KD-27FS170 TV
Sony Vega Digital TV model KD-28DX50 U
the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, vif,sif, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service technician
Jan 11, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony FD Trinitron WEGA KD-36FS130 36" TV Logo
131 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
