Question about Teac CD-X10i Docking Station for Apple iPod (043774021857)
TEAC CD-X10i won't play iPod or CD's nor will the power turn on
I recently bought the CDX10i and everything is connected correctly. The subwoofer power turns on and I get the orange light, however, the power for the CD player unit will not turn on. I'm suppose to get a green light when this happens and information on the screen does not appear. PLEASE HELP!
  • sledinguru Mar 03, 2009
    I have the same problem. Sub powers up and display backlight lights, but nothing on display and the power button won't light.
Benimur
  • 6966 Answers
SOURCE: TEAC H300CD Player
Hi, Your particular brand/model was made in the very early 2000. It is possible that the eye (optical lens) is already weak and would need replacement or calibration. You may want to try and clean the lens hopefully improving the reading capability. Some users of CD players use a PC CD cleaner to clean the eye (pls read the instructions) though this can be done by going inside the unit). Probably your best bet is to seek the services of a qualified professional. Hope this be of some help and give you ideas. Pls post again how things turn up and/or if you need further information. Good luck and kind regards.
Posted on Aug 04, 2007
informatica
  • 1114 Answers
SOURCE: Teac GF-350 CD Shelf System
Firstly double check that the recordable discs you have bear the label "Digital Audio" on them as per the attached picture. Secondly what happens when you go through the finialise procedure in the manual? Do you see the ?FIn--d? display when you select the finialise button? Do you see ?NO TOC? and ?REC? indicators blinking at the next step? Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 27, 2007
  • 20 Answers
SOURCE: TEAC Amp
The amp is going into "protect mode". This means there is a bad part or parts being detected. Professional service will be needed.
Posted on Sep 15, 2007
SOURCE: teac cd-x10i
  1. press the standby/on switch off
  2. Press and hold the TIME SET button for more than 3 seconds and release it when "12H" or "24H" appears on the display. press the right and left arrows to select. press TIME SET again.
  3. the hour value blinks use the right and left arrows to select the current hour. press TIME SET gain.
  4. The minute value blinks. using the right and left arrows select minutes.
  5. press TIME SET again and the clock starts.
Posted on Jan 04, 2008
  • 3 Answers
SOURCE: can't do anything - LCD screen says "PROTECT"
It may be that there is a problem with a fuse inside the stereo. It may say protect because the fuse has broken a connection that allows it to turn on. If the protect goe sup it is trying to help save the stereo from cooking its self, and give you a chance to get it fixed. If that is not the problem then it may be easier to just buy a new one, because a fix may be expensive if you don't have any warranties.
Posted on Jul 14, 2008
Does the Teac Micro Hi-Fi System CD-X9 support an Ipod nano?
  • Not in the format that IPod supports but it easy enough to convert the IPod songs to the MP3 format that would allow you to burn an MP3 disk that will play on that system.
  • You want to convert it to MPEG-1, Audio Layer 3, 44.1 or 48 kHz fixed bit rate.
  • Here is one of many site you can download the converter from http://www.winmpg.com/ipodto/ipod_mpeg1.html
  • Once you convert the ITune then just burn it to a CD-R or CD-RW disk and the system will play your songs just fine.
  • Hope this helps.
Regards, Tony
Jun 07, 2011 | Car Audio & Video
Have bought ipod nano 5th generation and find the sound is distorted when using my teac cx-225idab docking system. older version of ipod is fine. any clues.I thought it was the ipod and had it exchanged...
Usually, that will happen if the ipod is not compatible w/ the docking station. Try to connect the ipod to a different docking station to check if it will gonna do the same thing...
Oct 26, 2009 | Teac CD-X10i Docking Station for Apple...
My Ipod does not play -
Do a reset of your Ipod.
Should work then..
Jul 21, 2009 | Teac CD-X10i Docking Station for Apple...
My teac micro hi-fi system CD-X10i doesnt work
many units have a fuse inside the back cover near where the power cable comes in. be careful to replace it with the same size fuse as the problem that blew the fuse might still be there and could potentially cause a fire.
I have the same unit and i am looking for help because the cd will not run (wont spin the cd), but the door works. also the FM reception sucks.
Larry
Jun 15, 2009 | Teac CD-X10i Docking Station for Apple...
Hi, I have an 12 inch subwoofer who doesn't want to play. It play when i plug my ipod through the amplifier and i know that the problem comes from my head unit. Everything is right connected behind th
The i pod should play through your head unit when you scroll through the SOURCE button and land on AUX.-thats how it works on mine but yours might be different. Good luck
May 20, 2009 | Clarion DXZ775USB CD Player
Subwoofer doesn't play through ipod, only radio and cd's
Hook up the remote wire from the head unit (grey w/ orange stripe) to the power antenna wire (blue) on the wiring harness adapter.
Jan 15, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Teac cd-x10
try to play a cd I get an error message stating that it detects no cd.
Jul 12, 2008 | Teac CD-X10i Docking Station for Apple...
Audio problems
Did you connect both left and right RCA cable to aux1 forTV?Are you playing CD through your dvd player?
Also,double check your connection from your speakers to subwoofer.
Feb 27, 2008 | Teac PLD-2200 System
Teac CD-X10i Docking Station for Apple iPod (043774021857) Logo
226 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
