Question about Honeywell Heating & Cooling
Old gravity Heater kicks off to early
I'm a novice at this, but I check the system over pretty well. I can't seem to find anything wrong except its about 60 years old. Its a Lennox GS42-60S Gravity Heater. It burns natural gas, not oil.
I opened up the fan controller box. When I twist the dial counter clockwise the unit lights up properly. The off is set at 100 - the on at 150 - th elimit at 200
Any ideas?
Is my unit running way to hot or is my fan controll dial burnt
Fixya didn;t have the manufacturer as an option or heaters for that matter, I choose AC as I'm hoping the HVAC guys are answering
Thanks
  • Ken Bledsoe May 11, 2010
    So let me get this straight. you manually turn the fan control to engage the fan to start other wise it will not come on.. Right?
    And you was right in putting this problem in the a/c category
  • 10,865 Answers
I recommend that you begin by calling your supplier of natural gas. They offer a free service whereby they will come to your home and check out your heater. They will also show you exactly how it operates. good luck.
Posted on Feb 14, 2009
  • Joe Hogan Feb 14, 2009
Will an old piece of !!!!! "": dodge 1973 tioga moterhome be able to produce a trouble code for its major malfunctions ????
Are you kidding? Only if it was altered by IBM, maybe. Your first impression was accurate- it's straight mechanics from thereon. I believe Chrysler was the first to come out with electronic ignition in the early '70s, and that was a major step. You know, before that was the old mechanical breaker points sets. Ford played catch-up for years, first with a transistorized ignition (partially electronic ignition) for '74 & '75 or '75 & '76, and then arranging and re-arranging the duraspark ignition system, until engine computers in the early '80's. And that is so with your dodge, I believe: there were no engine computers in '73. Pretty much old style mechanics. I'd say you were lucky, except I know what gas guzzlers those things were !
Jul 21, 2014 | Cars & Trucks
I own a Volvo V40 Auto (year 2000) The heater fan is working but no hot air comes out although I've just tried it again and now seems to be O.K so the problem seems to be intermittent. I would be very...
might need to bleed heating system / radiator. Air lock could stop flow of hot water. Check water colour in radiator - if brown and gungy there could be a build up of sludge so radiator flush required.
when dial / lever moved to turn heat on / off see if you can hear anything moving - there should be! Quite often when heater turned on or off small solid wires move valves that are visible under dash and on engine bay firewall. Watch these rods when someone is turning the heater from cold to hot and see if anything is sticking or loose
Mar 01, 2011 | 2000 Volvo V40
I have a 2006 hyundai accent it is idling high and it seems to me that the tranny is slipping when you first start the car and take off, the rmps hit about 4000 before it finally kicks, my check engine...
No one could tell me what was wrong with my 2006 hyundai . Why the check engine light kept being on. Autozone, Napa, Advance auto, their FREE diagnostic machine could not figure the problem.It kept reading p0012 and they didn't know what exactly that meant so... I had to give in and take it to the hyundai dealership and pay$99 for a real diagnostic test. That's when I was told it was my oil control valve and the problem got fixed, no more headache!
Mar 05, 2009 | 2006 Hyundai Accent
Old Gravity Heater kicks off too soon
Those are pretty good settings. I might set the fan off to about 85 to get a bit more heat from it. Otherwise you're good. Please give me a fixya rating.
Feb 10, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Yz 250 wont kick start
Hi andersondts.
To get you right there i believe it should read as 'jump' start and not 'bump' start ...:-)
Well the problem could be with the battery, is it a maintenance free (dry) or is it a wet 0ne (uses sulphuric acid specific gravity 1250).
( 1) How old is the battery?
( 2) If its a wet one ,check the specific gravity of the acid in it, if its low thn charge it.You may hve to add or top up to its required level , if so thn use distilled water only !
( 3) If the battery is more thn 17months old ...replace it.
( 4) Its not bad to get the charging rate of your bike to make sure that it is working properly as required.
I hope this will help.
GOOD -LUCK.
Knight.
Feb 02, 2009 | 2000 Yamaha DT 125 R
Thermastat don't kick on until turned to 5 & then goes out if turned any lower.
have someone check your gas pressure that sound more like the problem you describe
Oct 16, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
RTH6300B - Not blowing the hot air
I currently have a 2 wire system. I have one red and one white. I hooked the red to the R and the white to the W. I had to go into the system setup using the UP arrow button and the FAN button. The first setting is the 1 setting, and I selected number 2 ( Heating Only ). Then the 5 setting. I selected number 1 ( Gas/oil steam or gravity system ). Then 14 is usually 0 for Fahrenheit. I was just messing around and that is the buttons I used and I tested it. The furnace kicked on and then 10 to 15 secs later the air began to blow through the vents. I hope this works for others who read this.
May 03, 2008 | Honeywell Focus 6300B 5-2 Days...
The water does not heat up
my sugestion is that you buy a new heater cost less than to repair the old one.goodluck.
Mar 29, 2007 | Saeco Vienna SuperAutomatica Coffee...
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
