Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
Getting double images on screen like outlines on images
Help in solving : getting double images on screen like outlines on all objects seems to be colors
  • Hitachi Master
  • 3,459 Answers
You can get convergence kits from also.
Posted on Feb 12, 2009
  • Edward
    Edward Feb 12, 2009
    Your TV most likely has one of two possible problems.
    Problem #1: Convergence Chip Failure ( common problem )
    Here are some of the most common symptoms and example photos of a convergence problem
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    Here is a quick test....
    Using your original remote go-to the tv settings then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    Solution #1
    You need to replace the convergence chips and convergence resistors. Check the site They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
    Problem #2 CRT Fluid is Cloudy
    Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
    Picture of a set that needs the fluid changed.
    TV set after fluid change
    Solution #2
    What you will need to do is replace the coolant and clean the crt. You can get a repair kit from that includes replacement coolant, photos. instructions, etc.
  • 184 Answers
Your TV has a failure of its convergence output ICs and perhaps some of the convergence circuit's other associated parts. The part numbers for the ICs are on the IC face. They can be purchased thru Hitachi or online at MCM Electronics.
Posted on Feb 10, 2009
Colors fine but double image: does picture have red or blue outlines around lettering or images?
See attached photos, it they look like your trouble it is convergence problem, if not try to give better description of problem.
You can post a comment here and I will assist you-I am here to help.6b564f8.jpg
Regards, SD TECH
Aug 23, 2010 | Hitachi 60DX10B 60" Rear Projection...
Double image and colour
There are two common problems with these sets.
Problem #1) Convergence
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Oct 07, 2009 | Sony KP-53HS30 53" Rear Projection...
Blue color on screen
If mostly blue shadow appears around the white objects means the cooling liquied is getting dirty and needs to be replaced.
May 27, 2009 | Philips 46PP9302 46" Rear Projection...
Double image with red and green outline on image
Unit will require the 2 STK392-110 convergence amps to be replaced along with a couple of low ohm resistors.
Jan 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
My toshiba 42pw33p television show double image
If the convergence controls don't fix the issue then the convergence circuitry is most likely faulty. A Toshiba repair center will be able to get you an estimate for repair.
Oct 31, 2008 | Televison & Video
Rca hdtv
Check the Fly Back Transformer. be careful when trying to fix TVs. they retain electric currents even if you have disconnected them.
Oct 03, 2008 | RCA D52W135D 52 in. TV/DVD Combo
My phillips model 60pp920217f
You may have to do the full convergence alignment for all three CRTs, as outlined in the service manual for your model. Do you have the full service manual for your set which outlines the alignment and convergence proceedures?
May 08, 2008 | Philips 43PP9202 43" Rear Projection...
Double vision with blue outlines around objects on tv
you may need convergence amp replacement. this is a job to be done an experienced tv repair person ..but can usually be done for a few hundred buck$$
Sep 09, 2007 | Philips 50P8341 50" Rear Projection...
Video burn
Unfortunately, there is no fix for burn in on Plasmas. There is image retention, which is like temporary burn in, but it goes away within minutes of normal viewing. If this won't go away, there is no real fix.
Apr 29, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
217 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
