Question about Proscan PS32108 32" TV
Proscan fallas horizontales
Hola a todos espero mepuedan ayudar con este problema tengo un tv proscan ps32108 no llena la pantalla horizontal ya lecambie algunos capasitores de esa misma harea y retifique agunos mas y todos paresen estar bien espero que me entiendan pues apenas pricipio en esto y me gusta mucho esta tv tiene un stk730-150 mi pregunta es que si esta parte tiene que ber con el horizontal pues ya retifique todo lo que yo creo que tiene que ber con esa falla gracias por atender mi pregunta si pueden contestarme a roque65155001@sbcglobal.net
    Top Expert:
  • Proscan Master
  • 73,691 Answers
Pearu-de se kra. Crom de pro mes defen gunari. If you wish to get some details; visit the site linked here. Pull up older posts.
Posted on Jun 23, 2017
4 Suggested Answers
  • 3 Answers
SOURCE: I have a proscan mod # PS32108. We don't have the
IS THERE NO SOURCE/FUNCTION BUTTON ON THE ACTUAL TV ITSELF, WHICH YOU SHOULD BE ABLE TO SWITCH BETWEEN THE SOURCES.
Posted on Sep 13, 2010
  • 8457 Answers
SOURCE: How can I use the proscan PS32108 with my xbox360
Tries pushes the buttons on the tv that controls the tv channels for up and down for tv channels inputs.Pushes the channels buttons up or down for a few times for most tvs and might be ur tv also will goes in modes like line in for 1, 2,Video 1,2 or INPUT 1,2 for output devices for video.
Posted on Jul 13, 2012
gopakumarg43
  • 73691 Answers
SOURCE: como activar el servicio de usb en un proscan de 40 pulgadss
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts. .
Posted on Oct 20, 2016
CONFIGURACION DE DIS POR CAMBIO DE DOMICILIO
Estimado Abel, gracias por tomar el tiempo de contactarnos. Lamento escuchar que este teniendo un problema con la configuracion del receptor. Usualmente cuando uno de nuestros clientes se muda de domicilio nosotros ofrecemos instalacion en el nuevo hogar, enviamos a un technico a que se ocupe de todo, de esta manera nuestros clientes no se tiene que preocupar de nada. Dependiendo del equipo y servicio que usted tenga la antenna debera ser instalada para cierta direccion. Que mensaje le aparece en la pantalla cuando prende el televisor? Me encantaria ayudarle con esto. Por favor contacteme a kimberly.escobar@dish.com con su numero de cuenta y con los detalles en sobre lo que le aparece en la pantalla. Espero escuchar de usted pronto para resolver esto. Gracias por su tiempo.
Mar 12, 2012 | DISH Network IR Remote Control
Eee pc 90ha mb pantalla negra no enciende
Tengo un pc eee top et1602 y la pantalla no enciende se queda negra los led si prende el ventilador tambien ando preocupado si alguien tiene repuesta a este problema por favor enviarme un correo digitalpaint2012@gmail.com o por aca
Feb 16, 2012 | ASUS Eee PC 900 PC Notebook
Como programar un control nuevo a la caja de dish.
hola, tengo un problema con mi control remoto de dish es un 3.4 IR le cambie las pilas y ahora no logro que responda, como apagar la caja o cambiar canales, no responden todas las funciones, si puedo apagar la tv y el volumen.
May 12, 2011 | DISH Network IR Remote Control
Hola tengo un freestar 2004 de repente se prende es foco de la caja de velocidades que puedo hacer gracias
hola tengo una free star 2006 y paso el swiche y no hace nada .prende el tablero y todo el equipo pero paso la llave y nada
Apr 30, 2011 | 2004 Ford Freestar
Mi control de dish no quiere hacer nada quien me ayuda
Hola mi nombre es Kimberly Escobar con DISH Network servicio al cliente. Lamento escuchar que este teniendo un problema con su control de DISH Network, seria un placer asistirle proveyendole informacion que le sea de uso para resulusionar el problema. Si el control no esta haciendo nada primeramente debe asegurarse de que el control este en el modo de SAT significando que cualquier boton que oprima el control el boton de SAT en la parte de arriba se debe encender en rojo. Si ningun boton se enciende en rojo puede intentar poner baterias nuevas en su control, si no funciona significa que el control no sirve necesitaria uno nuevo, si el boton de SAT se prende en rojo puede intentar reprogramar el control a su recibidor. Para hacer esto tiene que accesar la pantalla de System Info en su televisor, puede hacer esto oprimiendo el boton de Sys Info enfrente del recibidor. Despues en el control va a oprimir el boton de SAT hasta que los demas se enciendan rojos cuando vea que se encienden rojos ingrese un numero entre 1-15 seguido por el signo de numero (#) y el boton de record una vez. Trate el control deberis funcionar. Tambien puede entrar a nuestra pagina web http://www.dishnetwork.com/SupportSection/remote-control aqui encuentra ayuda en como arreglar el control y el procedimiento. Si necesita mas ayuda por favor contactenos directamente al 1800-333-DISH gracias espero esto le ayude.
Feb 09, 2011 | DISH Network IR Remote Control
Programar el contro
Hola mi nombre es Mayra Diaz con DISH Network. Tengo entendido que quiere programar un control. Si por favor me puede dar informaci?n adicional con mucho gusto le puedo ayudar con este problema. La informaci?n que necesito es ala televisor que lo quiere programar o al recibidor de DISH Network, otra cosa seria cual es el modelo del control esta localizado en la parte de atr?s de su control.
Jan 13, 2011 | DISH Network IR Remote Control
Acaban de componer mi camioneta (pontiac montana sv6 1999) porque los buzos hidraulicos estaban pegados y no pasaban aceite (le pusieron nuevos), al siguiente dia de uso empezo a fallar la aguja del...
hola ayuda por favor. tengo una pontiac montana 97 y la falla es que en ocasiones da marcha pero no enciende a la primera. hace como que arranca pero se apaga. pero si acelero un poco al dar marcha si arranca y ya se mantiene normal. que sera. gracias. saludos
Nov 19, 2010 | 1999 Pontiac Montana
Tengo un tv que tiene la falla en la convergencia de colores
Hola, gracias por visitatar fix ya.
Mira, tienes un fusible abierto, que no te permite entrar a los ajustes.
A un lado del fly back hay tres pastillitas colo cafe ( fusibles), el de enmedio es el que tienes que cambiar (400ma), pero tienes que resoldar toda el area del fly back, por que ahi tienes falsos o loose connections.
Si tienes alguna pregunta, aqui estare.
Gracias.
Jul 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hola que tal!
Hola,
Tu pantalla tiene 2 sintonizadores, por que no intercambias tu antena y pruebas si de misma forma la falla se sigue comportando, o por lo menos cambia... ejem: que ahora falle el recuadro mientras que el principal ya no. De ser asi, acorralamos en mucho la falla en el sintonizador ya que un sintonizador es primario y el otro es secundario para funcion recuadro.
Prueba y me dices aprovecha, en este momento tengo una identica a la tuya en servicio!!!!
Si resuelves el problema, no olvides calificar mi asistencia
saludos y suerte.
Adonisito
Mexico
Mar 13, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Televison & Video Logo
62 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
