Question about Grohe Integrated 1/2'' Shower Thermostatic Rough-In Valve With Stops - 3412
Grohe Thermostatic Valve
I have a grohe thermostatic valve which I just installed. My problem is that once the shower is on for 5 minutes providing me with a comfortable hot shower the pressure decreased then shuts off. If I turn the thermostatic valve clockwise the flow resumes providing me with lots of cold water. When I turn the thermostatic valve counterclockwise the cold slows down and stops. This seems to occur with every shower.
I have noticed that when I turn the volume control to the off position and then turn it back on the water seems to flow properly again for about 5 minutes.
  • 332 Answers
The temp, control valve is getting to hot!!! there for only let so much hot water go thru, did you take the inner parts out when soldering this in, if not you might have damaged it, and if so need to replace the cartdrige
Posted on Jun 06, 2009
  • Jim Weaver May 19, 2013
    This is not a solution.
My thermostatic mixer shower will not turn off
he probably put it together wrong.
there is usually a blue gasket inside for testing purposes, if that is not removed, the valve will not turn off.
May 12, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
I have a grohe power shower wich only has cold water coming out. if i replace the thermo catridge will this solve the problem
It has been a while since I have worked on a Grohe, But if it has a built in scald gaurd or thermo cartridge, it may be sticking and need to be replaced.
May 02, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
I need to clean the filter on my grohe shower how do I do this
Use a flat head screw driver and unsrew the brass fitting remove the temperature spindel and wash out. Re install the same way and test.
Feb 19, 2010 | Grohe Grohtherm Thermostatic Rough-In...
Grohe valve Grohtherm Thermostatic Rough 34-126 I turn the mixer to full hot but the temperature remains tepid. All the other faucets in the
The thermostatic stop is set too low. Havent set a grohe before but most other thermostatic shower valves work similar. pull off the handle(however a grohe handle comes off . . ) there should be a notched ring or stop which keeps the handle from going all the way hot. pull out the ring and turn it a few teeth hotter put back and reinstall handle try water temp and adjust again if necessary.
Jan 23, 2010 | Grohe Grohtherm Thermostatic Rough-In...
How do I remove grohe shower trim?
norm cover levers off go round cover at four points
Oct 14, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Grohe Integrated 1/2'' Shower Thermostatic Rough-In Valve With Stops - 3412 Logo
2,900 people viewed this question
Top Grohe Water Heaters Experts
Paul Carew
Craig Butler
Craig Butler
ray gallant
Are you a Grohe Water Heater Expert? Answer questions, earn points and help others
