Question about Samsung SyncMaster 930B 19" LCD Flat Panel Monitor
Restart computer and monitor says not optimal display
I can't reset the display preferences because the monitor isn't working, can't see to fix the problem cause the screen isn't in optimal display mode.
  • mjolnirco Feb 10, 2009
    my monitor is the 940n, is that matters
  • 585 Answers
If you are indicating you have like 5 or 10 frames stacked across the screen causing the can't see problem, here's the "what-to-do". Reboot the computer and use "F-8" to get it started in safe mode. Make the necessary corrections the the display settings. Save and reboot. That should restore so that you can see to optimize the settings once back in normal mode.
Let me know if I missed it.
Posted on May 15, 2009
Facebook is being real slow in loading pages and it skips around what is going with the site?it is very irritating many people have had the same problem lately so it' not my computer it's a brandnew...
Facebook has been having problems for days like you describe. It is on their server end, not yours. Typically it means that either too many people are accessing the site at the same time, they don't have enough servers to users, or a problem between the user and their servers, somewhere along the net.
Amazon's 'cloud' network went down the other day taking amazon and many other sites offline for hours. As this problem seemed to show up around the same period of time it could be that facebook is using some of their storage or that the outage caused a clog on the net.
Bottomline is that there really isn't anything much you can do but wait until they get it fixed on their end.
Apr 27, 2011 | Computers & Internet
Have a green rectangle about 2 inches by 5 inches in center of screen with yellow letters that say, input signal mout of range. It is A hanns g hg281d monitor
Restart your computer,
and keep hitting the F8 key until a "start-up" menu
(white text over a black background) is displayed.
Choose "Safe Mode" and let Windows start.
Reset the screen-resolution to 800-by-600, and 60 Hertz refresh-rate.
Restart your computer, normally,
and then "tweak" the screen-resolution and refresh-rates that are "optimal" for your monitor.
Aug 09, 2010 | Computers & Internet
Show on the display input signal out of rang
it is the set resolution. change graphic settings on your computer. probably, reduce the resolution and try untill you get an optimal setting.
Regards
Jun 14, 2010 | HP Pavilion F1523 15" LCD Monitor
Display image is too small and off center.
change you cmos battery, configured your settings and off the machine for 5 mins. let on and observe if changes same.
Apr 13, 2010 | Hansol 900 P (White) 19" CRT Monitor
Toshiba L10 display will not work.have pressedfn+f1 and fn+f5 but to no avail.
There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop", click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors' graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?). 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer". *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click, "Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “I hope this Fix it!”
Jan 22, 2010 | Toshiba Satellite L10 Notebook
Adjust size of display on interactive whiteboard we are using a projector and a smartboard and can't get the same display on the smartboard as we have on the computer monitor - we want a better fit. If we...
if you have no zooom and only a digital zoom this wont work so you need a longer vga cable and if you have mounted it you need longer wires and to take your projector further back.
Jan 15, 2010 | Toshiba TLP S30 Multimedia Projector
I have a Dell monitor and the text is blurry and fuzzy, how do I fix this?
this is actually from dell support website.. hope it will correct your problem...
1 Ensure the correct resolution is set for the monitor. Flat panel monitors display the sharpest, clearest images when set to their optimal resolution. Sometimes games and other programs will change the resolution then fail to set it back once they are closed. This will then make the desktop look big, distorted, and grainy. Perform the following steps to adjust the resolution:
  1. Right-click an empty area of the desktop, and then click Properties. (Or, click Start, click Control Panel, and then double-click Display.)
  2. In the Display Properties window, click the Settings tab.
  3. Under Screen resolution, move the slider to the desired setting. For most flat panels the optimal setting will be all the way to the right.
  4. Click Apply, and then click OK.
  5. If prompted, restart the computer.
NOTE: If the resolution will not adjust to the appropriate settings, the video driver may need to be reinstalled or updated.
2 Ensure the screen is clean. Finger prints and smudges will make the screen look blurry. Clean the screen with a soft lint free cloth. If needed, dampen the cloth with warm water or use a LCD cleaning kit that can be purchased from most electronics stores.
3 Use the On Screen Display (OSD) on the monitor to select the Auto Adjust feature. Selecting this will synch the video signal and can sharpen the video image.
4 Reseat the video signal cable to ensure a secure connection.
5 Use the On Screen Display (OSD) on the monitor to select the Factory Reset feature.
6 Test the monitor on another computer or test another monitor on this computer. If available, testing different hardware will isolate if the problem stays with the computer or monitor
Sep 12, 2009 | Gateway FPD2275W LCD Monitor
The menu constantly pops-up on my Samsung 17 inch LDC monitor
what does the pop up menu say? I'm guessing it says something like "Optimal settings are 1280x1024, Press 1 to confirm, press 2 to disable". If the message is anything like this, your monitor is trying to tell you that your display settings are less than optimal. You can either disable the message by "pressing 2" or changing your display settings to the recommended resolution. If the menu you're getting is just the control panel and there's no actual message, leave your computer on, reach around the back and disconnect the power cable from the monitor, wait 5 seconds and plug it back in. Samsung monitors sometimes have a glitch and need to be reset.
May 13, 2009 | Samsung SyncMaster 173V 17" Flat Panel LCD...
Attention out of range is displayed on ibm 2 74 monitor
To resolve this behavior, either change the refresh rate, or change the video adapter settings.
To change the refresh rate:
  1. Restart the computer, and while it is restarting, press F8 until the Startup menu appears. Press 3, and then press ENTER to start the computer in Safe mode.
  2. Right-click the desktop, click Properties, and then click Settings.
  3. Click Advanced, click Adapter, and then click Adapter Default from the Refresh Rate list.
  4. Click OK, click OK again, and then click Yes to restart the computer in Normal mode.
You can set the colors and screen area to your preferences under Display Properties.
To change the video adapter settings:
  3. Click Advanced, click Adapter, and then click Change.
  4. Click Next, and then click Display a list of all the drivers in a specific location, so you can select the driver you want.
  5. Click Next, click Show all hardware, and then click Standard display types under Manufacturers.
  6. Click Standard Display Adapter (VGA), and then click Next.
  7. Click Yes, click Next, click Finish, and then click Yes to restart the computer.
  8. After the computer starts, right-click the desktop, click Properties, and then click Settings.
  9. Click 256 colors, click Apply, and then restart the computer.
  10. After the computer starts, click Start, point to Settings, click Control Panel, and then double-click System.
  11. Click Device Manager, click View devices by type, and then click Display adapters.
  12. Click Standard Display Adapter (VGA), click Remove, and then click OK.
  13. Install all updated monitor drivers.
Apr 13, 2009 | IBM E74 17" CRT Monitor
Out of range
Setting the Refresh Rate in Enable VGA Mode - Windows XP
You will need to go into Enable VGA Mode to change the refresh rate.
  1. Restart the computer and repeatedly tap the F8 key on your keyboard until the Windows Advanced Options Menu appears.
  2. Select “Enable VGA Mode” and press Enter.
  3. If asked to choose your operating system just press Enter.
  4. Once the computer has finished booting up go to Start -> Settings -> Control Panel -> Display -> Settings -> Advanced -> Monitor.
  5. Change your Refresh Rate/Refresh Frequency to a lower setting.
  6. Click Apply to confirm the change.
  7. Close all open windows and restart your computer.
* Click here for help determining the optimal refresh rate for your monitor
Sep 24, 2008 | Computers & Internet
Samsung SyncMaster 930B 19" LCD Flat Panel Monitor Logo
184 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
