Question about RCA P52960 52" Rear Projection Television
I have a RCA Home Theatre Premiere Modle P52960
We moved the tv and now when plug it in the unit will not come on and there is a beeping like a small alarm is going off...
SOURCE: RCA rear projection tv
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
Posted on Sep 18, 2007
  • 1694 Answers
SOURCE: RCA P52960
try a combonation of buttons on front of tv-- hold vol up & chan up fo four seconds?? try menu & vol up for four seconds,etc. Consult o/manual?
Posted on Oct 08, 2007
SD Tech
  • 14553 Answers
SOURCE: RCA Home Theater Premiere 36" TV comes on automatically
Only two possible reasons I can think of for this--
ONE: you have looked in the customer menu and there is no item listed as Timer?
TWO: Does THIS SET HAVE THE GUIDE PLUS LOGO ON THE FRONT OF THE SET? IF IT HAS THE GUIDE PLUS--YOU WILL FIND IT IN THE MENU ALSO---
LET me know if it has the guide plus feature and I can tell you how to end the problem--most of these the set will come on at the same odd time and usually with volume up high.
SD TECH
Posted on Dec 26, 2009
  • 1619 Answers
SOURCE: I am running a Panasonic DVD (DV 606D). I just
then just plug the video into the back of the TV and leave the sound to the tuner.
Posted on May 18, 2010
jdvillanueva
  • 2098 Answers
SOURCE: RCA P52960 52" Projection TV. When the 5A 125V
It is an indication of shorted parts on the power supply.
Replacing the fuse alone can't solve the problem.
I've suspected that you have a short on the following parts (rectifier diode, regulator I.C.) on the power supply section but needs to check by a qualified technician to isolate the problem. It is quite technical and not diy.
If you unit is under warranty then send it to the nearest service center of your manufacturer then avail the warranty.They will fix it for you for free and/or a little charged only.
pls rate my help.
Thanks for using fixya.
Posted on Jan 12, 2011
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
I'm lost/misplaced the user manual for my RCA Home Theatre Premiere TV and am trying to find the procedure to to locate a suitsable AV channel to play my Wireless60 Gaming System
Just downloaded my "RCA SUER GUIDE" FOR MY 1994 RCA COLOR TV. i WENT TO WWW.RCA.COM AND ENTERED MY INFO OF BRAND TYPE OF PRODUCT AND MODEL #, got exactly what I needed. Try it out.
Sep 03, 2011 | Televison & Video
I think my speakers are blown on my sony 53 inch rear projection tv can I run the sound through my home theatre and bypass the blown speakers?
check your audio menu on your tv. mine can turn off the speakers and sends the audio signal out the rca's when the speakers are off.
Oct 25, 2010 | RCA P52960 52" Rear Projection Television
My rca p52960 tv will not turn on at all. What can
I would disconect the front control panel you can do it by opening the back of the unit on top of the light box there is a couple plugs just unplug the one going to the front panel then try to turn it on with the remote
Jan 25, 2010 | RCA P52960 52" Rear Projection Television
Ghosting of picture from a Panasonic home cinema system
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
Mar 18, 2009 | Panasonic Televison & Video
No sound
there is a switch on the back of the tv that has internal and external speakers slection i would check that especialy if you have hooked up any new componants
Dec 07, 2008 | RCA P46924 46" Rear Projection Television
RCA P52960 52" Rear Projection Television Logo
88 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
