Question about Toshiba 27AF44 27" TV
Horzontal lines across top 2" of screen on both my Toshiba TVs?
This just occurred past 3 mos. - first one TV, then the other started with the horizontal lines. Newest was purchased 2004. Cablevision just left my house and Cablevision claims both my TV tubes are "going" - that I need two new TV's. If it was just one TV, I wouldn't question this - however, what are the odds both TV's (both Toshiba's) would have problems simultaneously. Has anyone heard of this? Hey, if they're on their way out, fine; but just curious if anyone else has had similar issues.
Thanks so much for your assistance!
  • magzelius Feb 12, 2009
    Thank you so much for your response - we contacted Toshiba directly - they also recommended a tech. should come and look at the sets and also supplied phone number to find tech. in my area.
    I'm still shocked it happened simultaneously!
    Thanks again!
  • magzelius Feb 13, 2009
    I can't thank you enough again for your technical support. We were so sure it was a cable issue. Very helpful. Thanks for the enlightenment.
    Magzelius
  • 104 Answers
It's NOT the "tubes" (the glass picture tube you view) this is 90% of the time a capacitor in the vertical circuitry. A good TV tech can find and fix this issue for probably a little less than $100 per set at the most.
Posted on Feb 12, 2009
  • Steve W Feb 12, 2009
    the simultaneous failures are due to a design flaw. Tell the tech that if the problem is due to failing electrolytic capacitors to make sure to install quality 105 degree celcius quality capacitors not the standard 85 degree ones! When the give you the old parts back (and a good tech always will) I bet you will see it say 85degrees right on the label.
    If you make this request, the tech will think you are so smart that you are only hiring him because you don't have time to do the job yourself and so should be quite honest with you I bet!!!!! ;) He might even give you a quantity discount since the problem is almost sure the same part in both sets.
Why has my Toshiba flat screen tv got a broad green horizontal band across the top?
One of the circuit board ribbons connected on the vertical control is probably loose there is a few vids on you tube for this repair , failing that some of the driver capacitors need replacement with higher voltage caps same microfarad.
Oct 15, 2014 | Toshiba Hi-Def Flat-Screen Lcd/Led TVs 32"...
Same white lines on top of screen
you still go the warrenty on it
Jun 04, 2009 | Toshiba 32D46 32" TV
Toshiba Tube TV 32AF45 Picture Squeeze in middle
Try unplugging TV while it is on and let sit for 20 minutes. Re-connect and see...
It sounds like your horzontal control is bad. It requires a new circuit board.
Mastersage!
Feb 18, 2009 | Toshiba 43H70 43" Rear Projection...
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
Insignia 32" TV Thin line across screen 1-2" from top
This is usually caused by bad capacitors in the vertical circuit. If you have an electronics background you should be able to find the defective ones with an ESR tester .
Dec 16, 2008 | Insignia NS- 27" TV27 TV
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
Black line problems
Some components in the vertical deflection amp have been going out of spec with age.
The set may no longer be worth to spend money to service it because of its age. However, if you wanted to invest the money, the set is serviceable. Considering its age, the CRT may be soft, and there are many other older components that can soon fail.
I would be considering a new set.
Jerry G.
Apr 18, 2008 | Toshiba 36A40 36" TV
JVC TV 27" Black line on top of screen
This is for the original problem.. Not the second post.
It's a problem in the horizontal deflection circuit. The parts will be available, but you will be in for some daignostic repairs also to find out why it failing or if it has failed on it's own.
There should be a few caps near the IC (an LA7840) that could also be causing the problem. Click the link, it will make it easier to locate the part inside.
This is the kind of repair best left to a TV tech, but get it done now and it won't cost anywhere near as much as it will later.
Apr 18, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Sep 05, 2006 | Toshiba 27A30 27" TV
Toshiba 27AF44 27" TV Logo
812 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
