Question about Philips 13MDTD20 13 in. TV/DVD Combo
Philips tv 20pf4121 doesn't turn on
When I tried to turn it o I could just hear the sond but the image didn't appear, now I can't even turn it on.
Let me know if somebudy can fix it.
    Problem Solver:
  • 5 Answers
I had exactly the same problem When the TV was switched on all I could see was a flashing green light. After cheching the TV internals and not seeing a problem including the power supply unit which looked and checked normal. Here is what I did to get M TV working again.
Disconnect it from the power supply. Hold down all the buttons simultaneously i.e. the on/off, the volume, the programme, menu buttons, all of them simultaneously and Plug it into the power supply again.
Lo and behold My TV jumped back into life after an absence of about 4 weeks.
Try it yourself exactly as above.
Best of luck.
Irishfreethinker
Posted on Sep 22, 2009
Philips flat tv 20pf4121 05
try buying a universal remote that can be programmed for your TV easier to do it this way then thro any any buttons that exist on the TV
hope this helps
Mar 15, 2014 | Computers & Internet
Hi! i have a philips 20pf4121/05 flat tv.it won't turn on and green light is flashing few times and that s it.do you know how i can fix the problem?
Not likely to be a do it yourself repair. From the model number it is a 20 inch and if the power supply board is bad may not be economical to fix not to mention quite often on the smaller sets parts do not exist.
Aug 29, 2012 | Philips 20PF4121 20 in. EDTV-Ready LCD...
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
My Philips TV model 37PFL9604H1 was used in the
Close, then you should go in the image settings and change the main setting from Store to Home
Jul 06, 2010 | Philips Televison & Video
The receiver doesn´t work. When i switch on,
the solution: Fount of energy broken and 50€ less in the pocket...lolo
Aug 14, 2009 | Philips E-Box FTR9965 DTV Receiver
Philips 20PF4121 LCD tv no picture but flashing error codes
Best of luck.
Irishfreethinker
Jul 09, 2009 | Philips 20PF5120 20 in. EDTV-Ready LCD...
Toshiba 36A50 Horizontal Line in the middle
  • the problem is most common & simple to repair at your home only at minimum cost by skilled technician.
  • as per problem is concern it is due to electrolytic capacitor failure in vertical output stage.
  • hope this will help
  • good luck.
Oct 21, 2007 | Toshiba 36A50 36" TV
Philips 13MDTD20 13 in. TV/DVD Combo Logo
517 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
