Question about HP LaserJet 4650 Color Printer Manual Duplex & 160Mb Memory
Option to Print on both sides does not appear
When I go to print, an option to "print on both sides" is not available. I believe I have turned duplex printing on.
    Sergeant:
    Champion:
  • 208 Answers
Check your driver. If you are using a recent version of "HP Universal Printing PS" driver, the duplex option is in the finishing tab.
Posted on Sep 01, 2009
How to print double sided
DOES THE PRINTER HAVE A DUPLEX MODULE ? Print out a configuration page and see if the duplexer appears under options. Good luck.
Jan 16, 2013 | Office Equipment & Supplies
Can you add duplex double sided option to HP d1660
No duplex option is available. The only way to duplex is manual. Meaning you have to print the first side, then turn the page over and re-insert into the printer. Then print the 2nd page onto the back of the first page. The reason this is not an option and generally you do not want to duplex on these machines is that the ink will tend to bleed thru the paper when prining on both sides of a piece of paper. You may have to use a little thincker paper to prevent this.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 28, 2010 | HP D1660 InkJet Printer
In the past I was able to choose the Manual Option which allowed me to print on both sides. Now every time I choose this option, it goes to Off. Can you please help me with this problem?
Many printers support duplex printing, but they don't all make the duplex option available in the same way. With some desktop printers, choosing duplex means that the printer prints all of the copies of the first side of a page, then pauses and asks you to flip the sheets that it just printed and return them to the printer, after which it prints all of the copies of the second side. This method is called manual duplexing.
To print on both sides of a sheet of paper:
  1. On the File menu, click Print.
  2. In the Print dialog box, in the Name list, select the printer that you want to use.
  3. Click Properties.
Note The information in the Properties dialog box varies depending upon the manufacturer of the printer you're using. With some printers, you will see a Layout tab with a Print on both sides option on it. With other printers, you might see a Features tab, and the duplex option might be called something like Two-sided printing. Explore the various tabs in the Properties dialog box until you locate the duplex printing option.
  1. Choose the duplex printing option that you want.
The options will be called something like Long edge (or Flip on long edge) and Short edge (or Flip on short edge). Whether it's better for the paper to be flipped on the short edge or the long edge depends upon the type of publication you're printing. You might need to print a test publication or two to discover which option works best.
  1. Click OK to close the Properties dialog box, and then click OK again to close the Print dialog box and print your publication.
Sep 25, 2010 | HP Deskjet 2460 InkJet Printer
My manual was in a strange language. How do I
Your manual can be found here.
Printing on both sides of paper You can print on both sides of a paper; duplex. Before printing, decide how you want your document oriented. You can only use this feature with Letter, Legal, A4, US Folio, or Oficio sized paper.
Do not print on both sides of the special media, such as labels, envelopes, or thick paper to print on both sides of paper. It may cause a paper jam or damage the machine.
  1. To change the print settings from your software application, access Printing Preferences. (See Opening Printing Preferences.)
  2. Click the Layout tab.
  3. From the Double-sided Printing section, select the binding option you want.
    • Printer Default: If you select this option, this feature is determined by the setting you’ve made on the control panel of the machine.
    • None
    • Long Edge: This option is the conventional layout used in bookbinding.
    • Short Edge: This option is the conventional layout used in calendars.
    • Reverse Double-Sided Printing: Check this option to reverse the print order when duplex printing.
  4. Click the Paper tab, select the Paper Options.
  5. Click OK or Print until you exit the Print window.
If your machine does not have a duplex unit, you should complete the printing job manually. The machine prints every other page of the document first. After that , a message appears on your computer. Follow the on-screen instructions to complete the printing job.
Good Luck!
Jesse
Jan 06, 2010 | Samsung ML-2855ND Laser Printer
HP Laserjet 2015n printer
Sir, the Hp LaserJet 2015n printer CANNOT automatically do duplex printing since the printer does not include mechanism and paper storage areas to cycle the paper through the printer a second time and print on the reverse side. Manual duplex printing can be done as follows: Choose duplex printing and remove all sheets after the printing is complete. Turn the sheets over while preserving the orientation and insert them in the paper feed path. I have an HP 1020 laserjet printer which is similar to the 2015.
Aug 22, 2009 | HP LaserJet P2015n Printer
I am unable to print double-sided. the option is available in 'print options' but i cannot select it. (im using Mac OS X 10.5) thanks!
If the printer is DUPLEX it can turn the paper and do the whole magic automatically. You probably DON'T have a duplex attachment so you'll have to manually have to turn the paper after its printed. When you print, select the option to print only even pages, print, put the printed paper back in and print the odd pages. You may have to try it a couple times before you get it right.... Good luck.
Aug 04, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Greyed out duplex option Samsung CLP-310
does the printer have a duplex option,if yes should be able to print,check driver.if no,option does not allow you.
Jul 06, 2009 | Office Equipment & Supplies
I need to know how to choose a duplex print option for this printer.
when choosing the printer go to printing preferences and you will see the option for duplex if the printer has that option.
Apr 30, 2009 | Office Equipment & Supplies
No option to duplex print Dell 3115cn
The duplexer is seperate purchase to my knowledge. If you have purchased the duplexer, you must enable it in the options tab.
Mar 23, 2009 | Laser 3115cn All-In-One Printer
Check the printer setup and configuration to make sure the duplex option shows up as installed. If not, install / add the option from the option list, and this should return the duplex option to availability. If it doesn't show up in the option list, then the computer is not recognizing it as being installed in the printer, and we will have to look further as to why.
Oct 21, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP LaserJet 4650 Color Printer Manual Duplex & 160Mb Memory Logo
689 people viewed this question
Ben Johnson
