Question about Canon BJC-85 InkJet Printer
Printer skips every other line when it prints
Makes print look like it went through a vanition blind. System usually prints ok for the first page then it does the above from then on until shut down for the period. I have cleaned the heads multiple times and replaced the print cartridge several times.
  • 1 more comment
  • andyloehr Feb 10, 2009
    I have a Vista system on my HP laptop. It will not let me install from my disc
    I have a vista HP laptop that will not let me reinstall from the disc or download from the internet. The error light continues to flash. Any other recommendations? I am still in the same predicament.
    Andy
  • andyloehr Feb 11, 2009
    HooRAY it works, Thank you. Now how do I get the error light to stop blinking?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A couple of ideas you may want to explore/consider:
  • if you are using parallel (LPT1), check the connectors (both ends) or replace the cable;
  • if you are using USB, you may need to re-install the drivers;
  • if using IrDA, you may need to re-check settings/configurations.
  • hardware wise, the motor/gear mechanism may need a looking over. Of particular interest would be for an worn, uneven, missing tooth in any of the gear including the tooth belt if used.
Pls post back any updates. Good luck and thank you for using FixYa.
Posted on Feb 10, 2009
  • 679 Answers
Reinstall the driver of your printer.
and let me know.
  • 1 more comment
  • rockfixya
    rockfixya Feb 10, 2009
    Thanks for rating the solution.
    please download diver from following link>>
    http://www.siliconguide.com/drivers/devi...
    after downloading the driver please install it to your computer.
    and let me know for further assistance.
    Thanks for using FixYa.
  • rockfixya
    Ok...
    unplug the printer from the laptop..... and then try to download the software.
    please post back comments for further assistance.
    Thanks
  • rockfixya
    Please also Try---
    Look on the bottom of the cartridges - they have the nozzles. Its easy if there's something stuck on them. You should also clean the holding pen for the cartridges and the bottom of the cradles the cartridges sit in. Use a Q-Tip and alcohol. You should also check the contacts between the cartridge and printer to make sure they are clean.
    Thanks
Skips pages while printing
check the page length set on printer/ system/print server in printer & fax
Jul 26, 2013 | Lexmark Forms Printer 2590 Dot Matrix -...
Canon MP510 skips and makes 2 small blank lines going DOWN the pages, in only cyan and magenta. The two lines show up on the Nozzle Check Pattern but only on cyan and magenta.
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magicis ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to usethe Magic Inkjet Flush kit to soak the print head and you should beprinting again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
You are covered by a 30 day money back guarantee if not.
Good Luck!
Tinteiros (Ebay)
Sep 11, 2009 | Office Equipment & Supplies
Printronix P5210 line printer HOF problem
If you are using a printer that has IGP enabled, you can set the printer to automatically go to the next TOF at the end of the print job. Only if you are using the Graphics portion (printing bar codes and graphics). The option is "Auto FF at ^PN" and you would Enable it.
Dec 29, 2008 | Printronix Line Matrix P5210 Printer
Printing problem in xp
You probably need an Epson driver for Widows XP. Win 98 just isn't going to cut it for continuous forms printing.
Aug 12, 2017 | Epson DFX-9000 Dot Matrix Printer
When printing some lines don't print properly-appears to be just the top half or less of the line will print. It seems it happens every 3rd or 4th line, but has done it on the second line also, so is not...
Try printing out the test page from the printer, this will show you if any of the inkjet holes are getting plugged. If you can't print a test page without the skipping try changing the ink cartridge(s), the test page will show you which one is clogging.
Carl
Dec 10, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Poor print quality - top half page okay, bottom print faded and skips top half page okay, bottom print faded and skips problem Just installed a new cartridge
check the wright cartridge model you installed and well pluged to the printer
if it is ok
try to change printer properties and fix it correct options with there tabs ( ex: paper, print quality etc)
all are well try to reinstall the printer driver
Jul 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
Full ink cartriges print a few lines and skip a few lines
well..did you run a test page?
or clean the print heads?
or recalibrate them?
recommend all these steps for you
and as my 2200th solution, you are entitled to a FREE tuneup for good. find out more about that service here
Mar 23, 2008 | Canon PIXMA iP90 Mobile Printer
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Printronix p5005b line skip problem
yeah I ran into this once, set the printer up to ethernet and not auto switching, i think thats what it was.
Dec 10, 2007 | Printronix Line Matrix P5005B Printer
Canon BJC-85 InkJet Printer Logo
20 people viewed this question
old marine
old marine
