Question about ViewSonic VG800 18" LCD Monitor
Viewsonic vx800 blinking green light..no picture.....live in los angeles.....who can repair.....is it $ worth it.thanks
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 64 Answers
I have repaired several Viewsonic VX800 monitors. The symptoms include a power light that flickers or flashed on and off or a screen that flashes on briefly or stays off. The problem is bad electrolytic capacitors on the power supply board. These bad capacitors do not look bad and do not swell but they do develop a high ESR (Equivalent Series Resistance). You need a ESR meter to check them. But if you have these problems, you should assume the capacitors are bad and just go ahead and replace them.
First you must open the monitor and gain access to the power supply board.
1. Remove the stand: It is held with 6 screws on the back. Also on the back are 2 black screws that must also be removed.
2. Remove the button bar from the front, bottom: It is pried off. This will expose the 2 screws holding the front plastic bezel.
3. Remove the silver plastic bezel from the front: First remove the 2 screws holding it, then you can pry the rest off. This will expose the 2 screws holding the screen to the plastic back.
4. Remove the screen and electronics from the plastic back: Remove the 2 screws holding it. The 2 speakers are glued to the plastic case. Cut the glue with a knife. The screen and electronics and speakers should lift out of the plastic back.
5. Remove the metal cover to expose the electronics: There are 2 screws holding the VGA connector and 2 screws holding the DMI connector. There are 9 screws holding the cover. These must all be removed. There is a black plastic sheet glued to the lower edge of the cover. It must be lifted. The cover should now come off.
6. Replace the bad capacitors. The power supply and signal processor are on the same board. It is marked VG800-2. The bad capacitors are surfaced mounted 100UF 25V. The bad capacitors are CM16, CM17, CM2 and CM165. The two most critical are CM16 and CM17, but they all read high ESR, so I just replace them all as long as I have them exposed.
Reassemble in reverse order.
Posted on Apr 17, 2013
If you can solder and are acquainted with electronic parts (or if you have a friend who does), go to this website:
http://www.instructables.com/id/S21Z9IFFE3IPVKP/
I spent just an hour doing this and it worked. Hope this helps.
Posted on Mar 09, 2009
  • 2,404 Answers
Its a problem with bad caps on the power board, problem is that it would cost you more to fix it then to buy another monitor cause your looking at the cost of either capacitors or a whole board if it can't be repaired component level and labor.
My suggestion is to get a new monitor. The repair cost would exceed the cost of a new monitor.
Posted on Feb 10, 2009
Does Maxine Waters own a muti million dollar house in Los Angels?
It would seem that she and her husband own a home in Los Angeles that is, at a minimum, worth $1 million.
Source: http://static.latimes.com/how-much-are-they-worth/maxine-waters
Aug 14, 2017 | Computers & Internet
Where in Los Angeles County can I find a repair shop for screen under the glass. Bott half pixels are not coming in. Only can see half of the picture
  • In/Home Television Service inhometelevisionservice.com In/Home Television Service has been a ... tv repair professionals in Los Angeles ... office in Los Angeles County. What sets our television repair ...
  • Los Angeles County TV Repair ' Television Repair Service ... www.tvrepairman.com/ca/los-angeles-county Results for Los Angeles County TV Repair Service. ... Polaroid TV Repair, RCA TV Repair, Samsung TV Repair, Sanyo TV Repair, Sharp TV Repair, Sony TV Repair, ...
  • Orange County - Los Angeles TV Repair and Installation www.videotechco.com Videotech Co. is a Los Angeles County and Orange County California (CA) TV Installation company. Our services include: Home Theater Installation Services, TV repair ...
  • Dec 16, 2015 | Televison & Video
    No Picture On Screen
    it sounds to me like your tube has gone , go to your local tv repair shop and order a new tube its quite cheap to do so and they should be able to get it you quite fast.
    Mar 10, 2009 | Mitsubishi VS-60601 60" Rear Projection...
    Need local repair in Los Angeles for MagicSinging Model#ED-9000
    are you getting a green flashing light or none at all..
    if green flashing light then it is the mic signal, if none at all, then it is the transceiver inside. contact me sean.delcarmen@magicmic.com
    Sep 03, 2008 | Magic (ED8000) Professional Microphone
    Living Air Classic Emitting awful Smoke smell
    Hello DWolfS,
    1) Are you still looking for a solution?
    2) Are you able to trace the odor (e.g. do you see any visible signs of scorching or burning, esp. with the electronics components?
    3) Unless you are an electronics technician, you won't be swapping out cooked parts from a circuitboard (and if you were, you wouldn't need my advice......(;^]). If the circuitboard is bad, it's probably more trouble than it's worth to fix.
    EcoQuest Int'l, manufacturer of the Living Air, no longer provides repair or refurbishment of the Classic product, but they do offer a trade-in on a newer version. If you can't locate the dealer you purchased it from to assist you, you can likely find a dealer in the LA area (Google or Yahoo keyword search "EcoQuest Dealer, Los Angeles"), or contact EcoQuest directly aT 1-800-989-2299 or customerservice@ecoquestintl.net.; I'm sure they can put you in-touch with a dealer in your area.
    The company website is www.ecoquestintl.com/
    If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
    Thanks in-advance,
    Jon
    Jan 15, 2008 | Ecoquest Living Air Classic Air Purifier
    ViewSonic VG800 18" LCD Monitor Logo
    385 people viewed this question
    Top ViewSonic Computers & Internet Experts
    Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
