Question about Amana ALG331RAW Gas Dryer
How to remove the lower panel, GAS AMANA DRYER, model LEA 30 AW
Has heat, but drum won't turn. Figure it needs new belt, but don't know until I can remove the front lower panel.
  • 360 Answers
Generic instructions.... remove screws through lower panel bottom lip, panel lifts straight up and out.
........................or.....................
Use a putty knife to release the front clips (one near each front corner) and pop
the top to view belt.
Need model # for exact instructions
Posted on Feb 10, 2009
I have a cloth belt off that goes be hind drum. how does this go back on.
I included the routing of the belt, go to this website and find your Amana.........http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Jan 06, 2011 | Amana NED5200TQ Electric Dryer
Tip
How to Install the Heating Element of Maytag Amana Dryer?
The procedure is as follows:--- 1) First of all unplug the dryer from electric outlet for safety reasons.2) There are two panels in the dryer. One is top and other is front panel.3) Both the panels are secured by clips in between them.4) Take a putty knife and insert it in between the top panel and the front panel of the dryer. Press the retaining clips with knife and separate the top and front panel by Lifting up on one corner of the top panel to release the opposite retaining clip.5) After the clips are pressed both the panels will easily get separated. But take care there will be a connecting wires between the panels. You don’t have to pull that wire while separating the panels.6) You will see the door switch on the upper right side corner area of the front panel.7) Remove the wire harness from the door switch carefully.8) The remove the flange of the front panel to the side panel on each side by removing the screws.9) The front panel will get separated from dryer after removing the screws.10) Now with the help of screw driver remove the screws holding the drum bulkhead of the dryer.11) Now push the idler pulley between the drum and the motor assembly with you hand to loosen the belt tension.12) The belt will easily come out one you loosen the belt tension.13) After the belt is out. Carefully lift and remove the drum. Now on the lower rear side you will see the heating element.14) There are wires connecting on the sides of the heating element terminals. The wires are connected by removable connector.15) Remove the connector carefully from heating element with the help of needle nose plier.16) After the wires are removed from heating element’s terminals.Remove the screws holding the heating element.17) The heating will have to be moved a bit to come out easily. Before removing the heating element out.Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.18) Remove the old heating element and insert the new heating element.19) Connect all the wires as it were connected before.20) Refit all the parts which you removed while removing the old heating element in reverse method. Take care you don’t miss any part fitting.
This will help. Thanks.
on Mar 20, 2010 | Dryers
Drum will not turn-it just hums
Installing the belt
facing down.
Please RATE me
Jan 02, 2011 | Amana NDG7800AW Gas Dryer
My model # is LEA 10 AW...Anyone know of this one?? It will not spin on its own.. When you try and turn it on it makes a humming noise, but wont spin...
One of two things its humming because the motor is running and the belt is off/broken in which case you should still feel air coming out the exhaust vent. Or the motor start windings are bad in which case you will need a new motor.. If you have a helper try this open the door have someone hold in one the door switch then have them try to start the unit while you are spinning the drum clockwise, if it then runs the motor is bad
Sep 22, 2010 | Amana LEA11 Dryer
Dryer will not heat, checked and changed thermal fuse and no heat
The igniter is located on the burner assemly inside the dryer cabinet under the dryer drum. You can view it by removing the lower toe panel directly below the dryer door. This is accomplished by inserting a putty knife along the seam where the dryer front meets the toe panel. About two inches in from each side is a retaining clip that you must push down with the the putty knife, while pulling out on the toe panel. Repeat this on the opposite side and the pane will come free.
The way the ignition system on your dryer is supposed to work is like this:
1. Press the start button.
2. The igniter on the burner assembly begins to glow.
3. Once the igniter reaches the required current potential, the gas safety valve opens.
4. Gas is introduced into the manifold and you have ignition.
NOTE: It can take roughly 30 – 90 seconds from the time you press start to the time it takes for the gas to ignite.
This is a built in safety feature that prevents free flowing gas from entering the dryer cabinet without ignition. Such a situation could lead to an explosion.
There are two basic types of igniters:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton2.gif (Rectangular in shape) – needs to produce 3.2 to 3.7 amps2.gif for the gas safety valve to work.
I believe your dryer takes the Norton type igniter. The part number is 279311 and can be purchased at pcappliancerepair.com for about $22. NOTE: Just because your current igniter may still glow, does not mean it is good. Igniters will wear out with age and the current potential will decrease to the point where it no longer will open the gas safety valve.
Now...another cause of poor heating quality and longer dry times is poorly istalled, kinked, or clogged dryer exhaust ventilation ducting. If you have not checked the dryer ducting from where it exits the dryer to the point where it leaves your home, now may be a good time to do so. A dryer needs proper ventilation in order to dry efficiently.
You can easily replace the igniter by performing the following steps:
1. UNPLUG the dryer and remove the lint screen from inside the dryer door.
2. Insert a putty knife along the front seaam where the top panel of the dryer meets the dryer front. Locate the retaining clips and push down while lifting on the top panel. The dryer top will lift up.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing and disconnect the door hinge springs.
4. Locate and remove the dryer chute that covers the blower fan assembly and disconnect the auto dry sensor plug.
5. Hold the door closed and locate the four screws that hold the front panel in place. There should be one screw on each side at the top and at the bottom.
6. With the door shut, lean against the front panel and remove the four screws. Once removed, hold the top of the drum as you pull the front panel away and remove.
You should now have complete access to the dryer interior. You do not have to remove the drum, but if you have to for better access, release the belt tension on the drum. While the tension is released, remove the belt from the drive motor pulley. Leave the belt wrapped around the drum and lift the entire drum with it to remove from the cabinet. You now have full access to the burner assembly to replace the igniter. All you should have to do is disconnect the connector plug and a couple of mounting screws.
Once you have the igniter installed, you need to re-install the drum and belt by following these steps:
1. With the belt still looped around the dryer drum (grooved side facing the drum - try to line the belt up with the wear marks already on the drum from the belt) lift the drum with the belt and insert the back rim of the drum onto the support rollers in the rear of the dryer first.
2. With the drum resting on the rollers, slowly turn the drum clockwise until the rollers seat into the rear drum groove. You should feel the drum drop into place once it seats correctly.
3. Hold the drum in place (you can do this by resting it against your shoulder so you have both hands free). Loop the belt over the drive motor shaft first.
4. Then, with the tensioner in your right hand, pull the wheel to the right and place the belt on the idler wheel with your left hand.
5. Release the tensioner and the idler wheel will tighten up the drive belt against the drum.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram K.
Once you have the belt installed, re-install the dryer front panel by lifting the front of the drum slightly and placing the drum support wheels under the drum. Lift the entire front panel with drum in place and insert the front panel in the side panels. Hold the door shut so it doesn't fly open and line up the screw holes on the bottom edge of the front panel and then align the top. Reinstall the door springs, the auto dry sensor plug, the dryer chute that covers the blower fan housing, followed by the door switch connector plug and ground wire. Lower the top panel back in place.
I know this is rather lengthy, so take your time and read thoroughly. This is not a difficult repair at all. If you still have questions, please let me know. I hope you find this helpful.
Sep 14, 2009 | Whirlpool GGQ8831L Gas Dryer
Maytag gas dryer. Belt broken. How do I open and replace it?
On the right front and left front of the panel there are 2 phillips head screws. They are about 4 inches up from the floor. Remove these 2 screws,lift the door panel out then down to dislodge the top clips. Remove the door switch wires and set the door aside. Remove 4 screws from the front drum support. @ on the right,2 on the left. Remove the drum support.Install the belt around the drum. The smooth side of the belt goes against the drum. Re-attach all the parts in front. Remove the belt access panel on the rear of the dryer on the bottom right side facing the dryer to arrange the belt around the motor pulley and tension roller.
Aug 21, 2009 | Maytag Dryers
Gas dryer Amana Model LGA30AW, rattling noise, no heat.
I was experiencing a similar problem. I just repaired mine yesterday, with the help of this web site. Remove the front bottom panel. The are two screws located on the bottom of the panel. They are there, just slightly hidden. Turn on dryer to heat. Look inside where the panel was. Wait a minute or two and you will see the igniter glow. After a minute or so you might hear a click and the gas valve will open to start flame. After a while flame will go out until it cycles again. If your igniter glows and you hear the rattling noise and then the igniter glow goes out and you have no flame, it might be your solenoid coils are bad. These are the two black round things located on top of the gas valve. Make sure your gas dryer is unplugged. There is a wire clip attached to each solenoid. Unplug them. I needed to pry them off carefully with a flat screwdriver. There is a metal bracket holding those two solenoids in. There are two screws that you will need to remove the bracket. Use a flashlight to see them. Slide them up and off the gas valve. One is a 2 prong and one is a 3 prong. I bought a new set for 26.75. Put the new ones back the same way as you took them off. The is little nips on the top of the solenoid that line back up with the holes of the top bracket when reassembling them. Plug your machine back in and turn on and watch to see if the ignitor glows again and watch for the flame. Put panel back on and enjoy dry hot clothes again. GOOD LUCK
Aug 09, 2009 | Amana ALG331RAW Gas Dryer
Old (approx 30 years) gas dryer. It's been great.
The fron comes off. Two screws located toward the bottom front (where the front panel angles in) hold the front on. Then you need to remove the front bulkhead/duct work.
Putting the belt on the idler pulley is the trick. If you get this far and need more help, let me know.
Vic
May 09, 2009 | Dryers
How to install drum belt in Amana Model LED20AW.
HIya,
Cabinet Removal- Maytag & Amana Top Load Washing Machine
Remove the two (2) screws (item #21 on the attachment below) from the bottom of the front panel. Once the screws are removed, pull out on the bottom of the front panel until the spring clips release for the cabinet top.
Diagrams:
http://www.pcappliancerepair.com/model-display.php
Apr 07, 2009 | Amana DLE330RAW Electric Dryer
How to remove lower front panel/amana gas dryer model ndg2330aww
look under the fornt panel 2 5/16 screws holding it on
Jan 15, 2009 | Amana ALG331RAW Gas Dryer
Amana ALG331RAW Gas Dryer Logo
230 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you an Amana Dryer Expert? Answer questions, earn points and help others
