Question about HP Compaq Presario V2000 Notebook
Thanks kevin, but i don't have pcmcia slot on my notebook.
Have a MPC x 1000 transport are there a way to add wireless to this notebook?
Sure is if you have a USB Port or a PCMCIA Slot.
The usb port is the best option because it is the latest technology. But if you don't have a usb port then go with the pcmcia slot.
Just click the link below and in the white search box at the top of the web page type: usb wireless adapter or pcmcia wireless adapter then press GO.
Sort the results by price from Low to High
I like the hiro usb wireless adapter for $14.99
Apr 23, 2012 | MPC Computers TransPort GX3 Notebook
I purchased a wifi card for my N610c but don't see where it's installed
You don't say which operating system you are using.
You don't say which brand, type, format and model of Wifi Card you bought.
If it is an internal card, this cannot be installed without total disassembly of the notebook and, even then, might not fit because the motherboard might not support it or even have a slot for it. This card also requires internal aerial wires. Such a device also needs channels and LCD Panel sockets for the card's aerial wires.
What you should do is go back to where you bought the card from and exchange it for either a PCMCIA or USB Wireles LAN card, which fit simply into the notebook via its PCMCIA or USB ports. After you install the software and restart the PC, your notebook will be able to connect to your wireless router.
If this answer helps you, please take the time to rate it. This helps answerers better understand the needs and the point of view of the asker and helps us explore the best ways to provide useful, high quality answers.
If you need further help, please feel free to post another question or add a comment to this question.
Thanks for using FixYa.
Aug 30, 2011 | HP Compaq Evo n610c Notebook
On my Laptop I only see conector for Dial Up internet "Thelephone Line conector" I don`t see Ethernet Conector and i have DLS Modem i been using whit my dell Desktop how do i conect the modem to my...
Install drivers for ethernet card or buy a usb to ethernet adapter. That will get you on the net so you can install your other drivers via thinkvantage installer. Or you can just cruise the net with the usb to ethernet adapter itself.
Nov 08, 2009 | IBM ThinkPad 770 Notebook
Test and detect pcmcia slot without any card
There is no known test other that physically installing a card .However by default the drivers are installed as the software you are using should detect the hardware, ok look under device manager pcmcia adapters,if you have it installed the software knows its there,so apart from installing a device in the slot thats the only way you will know.
Good Luck
Sep 05, 2009 | Toshiba Satellite A105 Notebook
Bent pins on Gateway Solo 1450 pcmcia slot.
It would be difficult to remove and replace the PCMCIA slot on any laptop. Buy her a USB wireless adapter from Linksys or DLink. It would be easier and less expensive for you.
Jul 19, 2009 | Gateway Solo 1450 Notebook
Fujitsu Lifebook C4135 specs (32bit CardBus slot included?)
This is a very old laptop, when new it was installed with Windows 98.
Not sure if it had a PCMCIA slot on the laptop, but it can be easily identified if you look on the laptop. If it has PCMCIA slots, most likely it would be located on the LHS or RHS of the laptop. The PCMCIA could be a single slot or a double slot and it would be 55mm wide ie 2 3/4 inches wide with an eject button for a single slot and two eject buttons for a double slot.
Jul 06, 2009 | Fujitsu LifeBook C4135 Notebook
Wireless Card will not fit in slot
First, make sure that the type of card that you bought is compatible with the slot. Your presario can use Type I or II standard PC or PCMCIA cards. If the linksys adapter that you bought is not a PC/PCMCIA card, rather an ExpressCard, it really won't fit.
Jan 01, 2009 | HP Compaq Presario 2200 Notebook
Verizon Wireless PC 5750 air car work in a HP Pavillion
No because the Aircard PC5750 is a PCMCIA slot card, and your laptop has a Next Gen Express Card/ 54 Slot. The Express card slot is smaller than the PCMCIA slot. That makes the PC5750 incompatible.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 20, 2008 | HP Pavilion dv6000z Notebook
PCMCIA slot and DVD/CD
This is kind of a multi tier question answer that requires you do some diagnostic. First, is the PCMCIA slot and DVDrom on the same side of the computer? Also, do you always use the PCMCIA slot? First diagnostic is to try and boot off a XP cd or recovery cd you should have got w/ the computer to see if the DVDrom is in fact not functioning. Next, if you have the ability to try a different PCMCIA card in the slot that would be helpful.
There is a very good chance the PCMCIA slot damaged your board if you use a card all the time as some devices out there can get REALLY hot and do some internal damage.
Nov 08, 2008 | Toshiba Satellite A25-S207 Notebook
My PCMCIA slot cannot detect PCMCIA cards
check with other pcmcia cards if detect this tv card is not supporting your laptop
Mar 25, 2008 | Computers & Internet
HP Compaq Presario V2000 Notebook Logo
29 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
