Question about Acer Aspire 5100 Notebook
Acer 6920g has gone onto acer arcade deluxe cinema .
Tried most things to get ut of it ,no joy when turning it back on it just goes there.please help out a old man .
  • 2 more comments
  • Anonymous Mar 28, 2009
    i have this problem, whenever i startup the acer arcade deuluxe appears just after the windows xp startiup (i have vista)
    any help?
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    i think there is button a harware button for acer arcade deluxe and it got stuck on the contact thats why it is going again anf again to arcade deluxe , tell me if this is the case pls elaborate ur problem
  • glenn hoffman
    glenn hoffman May 11, 2010
    try and describe the problem, in more detail if possible,then we may be able to help you.good day!
  • DEKR
    DEKR May 11, 2010
    i need more info please
I have had the same problem ... that happend to me when I press the arcade deluxe button on the blue gem controler on the left. when I tryed to run vista again it keeps going to the arcade deluxe system ...
the only solution for that case that works with me when I run the system recovery and installed fresh copy from the windows vista that came with my laptop ...
I hope that helps you in your case.
Posted on Mar 08, 2009
When I startup my laptop it goes straight to Arcade Deluxe how do I get back to windows
Per these pages:
http://www.theacerguy.com/forum/topic/quit-acer-arcade-deluxe
http://www.theacerguy.com/forum/topic/acer-arcade-deluxe-loading-on-startup-cant-get-to-windows
This one even tells you how to disable it in windows start up.
http://www.cybertechhelp.com/forums/showthread.php?t=182345
it says to make sure "HOLD" button is not turned on when shuting laptop down otherwise it will do what yours is doing. They are also talking about going in to safe mode and taking it out of start up. Just read the posts and you might be able to get rid of it. The one i found was towards the bottom.
Good luck.
Nov 07, 2010 | Acer Aspire 6920 Notebook PC
The Acer Arcade Deluxe Webcam is not working, but the Acer Crystal Eye Webcam is still working fine. Please, how can I solve the problem with Arcade Webcam software? I believe it stops working after some...
You can do the following: Start your PC as an administrator > click Start or the Windows ball > Control Panel > Performance and Maintenance > System > Hardware > Device Manager > Scroll down to the device driver you wish to roll back > right-click on it and choose Properties > Click the Driver tab and then click Roll Back Driver. Note: Win7 ball > Control Panel > Device Manager. By rolling back the driver, your Arcade Deluxe Webcam should work like it used to.
Oct 15, 2010 | Acer Aspire 55421462 Notebook
My Acer 6920G will not play Blue Ray DVD'S. I am unable to get helpful info from Acer. Tried to find a Driver to download with no sucess. Would greatly appreciate help
You also need a patch from Acer,
http://www.cyberlink.com/prog/oem/acer/update/index.jsp
Acer Arcade Deluxe v1.13.4806
Go to acer arcade deluxe
select "Play Movie"
Select "settings"
select "BD settings"
Select "region code"
Select "region B" for the UK
Important Note!:
You can only change your region !!! 5 !!!! times!
that is 5 times!
I am totally stressing this.....5 times!
You may have to do this a second time so your computer locks on to this region code.
If you watch an american blu-ray vid, on the fifth change of the region code your computer locks to this region !FOREVER!
SO I AM TOLD.
Feb 26, 2010 | Acer Aspire 6920 Notebook PC
Start up stuck on Acer Arcade Deluxe screen
if you can boot into safe mode by pressing f8 at startup, check the startup folder for acer arcade and remove it if present.From your start button go to (start-programs-startup).
another option is to check the run key in the registry: one caveat though - please don't mess with things in the registry you don't understand. Deleting or changing unknown registry keys can result in a non-booting pc.
please stick strictly to my instructions and you will be fine. We're going to look and see if windows is calling the acer arcade to run at boot time:
click your start button and type 'regedit' (no quotes in the start search field. A window titled 'registry editor' will appear. Now, to expand a field in the registry, we left-click on the triangle on the left side of the field.
so, click the triangle beside HKEY_LOCAL_MACHINE
go down to 'software' and click the triangle beside it. go down to Microsoft and click the triangle, go to windows and click the triangle, go to current version and click the triangle, go to run and click on the run folder, not the triangle beside it.
Now look in the list of items in the run folder. these are all items that run when your pc boots. If you see an item with 'acer arcade' or just 'arcade' in the name, then delete it. DO NOT DELETE ANY OTHER REGISTRY KEYS....PLEASE!
if you found acer arcade and removed it then reboot and all should be better. if not, boot to safe mode again, click start button and type in 'msconfig' - no quotes. go to the startup tab, and again only uncheck anything with acer arcade in the name.
Hope this helps!!
Aug 09, 2009 | Acer Aspire 6920 Notebook PC
When I try to launch a Blu-Ray movie Acer Arcade Deluxe attempts to connect to what I guess is a non-existant web site which it fails to do. This is the end of your movie playing experience. There is no...
Ok I,m not sure i can solve the problem for you, but have had problems with my acer 6920 G. Hopefully this will help. I was playing blu ray discs on my acer 6920 G wich i believe has the same sony/nec Optiarc blu-ray player. It was playing blu rays fine for a while. then as newer and newer releases were coming out it would not play some blue rays from certain manufacturers (Fox). Then newer releases from other manufacturers would not play. I was getting updates from acer arcade deluxe that would allow me to play some of the newer releases. The only problem i was having was that the updates (patches?) were not keeping up to the newer releases. The last update from acer was corrupted or somthing was wrong with it and then my blu-ray player wouldn't play anything at all. To solve the problem I reinstalled acer arcade deluxe using the acer e recovery management. This fixed the problem. But now back to square 1. My older blue rays will play but not the newer ones. I've been going over this problem for a while now. The Acer site was no help at all. The e-mailed me some solutions both hardware and software but weren't even close to what the problem is. You can try Cyberlink Power DVD 8 and it runs better than the Acer Arcade Deluxe. (They write the updates for the acer arcade deluxe) It is expensive the last time i checked. Hope this helps a little.
May 01, 2009 | Computers & Internet
Blue Ray Software
Just do recovery your notebook. try to run the acer Arcade without upgrade it. I also have some problem when I upgrade/ update my Acer Arcade to latest Version. I'm using Aspire 6920G.
Jul 05, 2008 | Acer Aspire 5100 Notebook
Where can i download acer arcade or acer arcade deluxe for my notebook
what is it?a support driver?you can download it in acer website by using correct searce engine and by inputing the correct model.
May 19, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
436 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
