Question about Dell Inspiron 1200 Notebook
Inspiron 1200 My laptop (Inspiron 1200) will turn on and show the bios screen and then right before the XP should show up, it goes blank. I have tried to reinstall the OS but right after it says "Press any key to boot from cd" it goes blank again. I have tried erd manager also and it will not work. I can run the Dell Diagnostics and everything shows up OK, any suggestions???
    Problem Solver:
  • 17 Answers
Sounds Like a Bad Harddrive. First try to Format it out or even Better, Delete the Partition if you can. Then Go With the Fresh Install. Hope This Helps!...
Posted on Feb 12, 2009
System and administrator password for dell inspiron laptop 1200 model PP10S
  • DELL INSPIRON 1200 Master Password, Unlock Dell Laptop www.novatecdirect.com/.../1200-dell-inspiron-1200-master-password.html ... Mar 31 2015, Dell inspiron 1200 Master Password, 1200, dell, ... and System Disabled Security on Dell Laptop: ... dell inspiron 1200 laptop, reset dell ...
  • Dell PP10S ' eBay z www.ebay.com/bhp/dell-pp10s DELL Inspiron 2200 PP10S Laptop Computer 1 ... The Administrator Password needs to be reset. ... Part Numbers:8 CELL Battery for Dell Inspiron 1000 1200 ...
  • Inspiron Laptop - factory reset no admin password - Dell en.community.dell.com > ... > Laptop > General Hardware my problem is with dell inspiron 1200. Just bought this system. During POST it prompts for an administrative password which I dont have. Displays massage like "this ...
  • Administrator Password for Dell Inspiron 1200 Bios & Hard ... dellpasswords.com/administrator-password/index-of-remove-dell... Remove Dell Inspiron System Disabled Password: Now we have a picture on the right that shows a dell inspiron 1200 laptop with the system disabled password
  • May 08, 2016 | Dell Inspiron Computers & Internet
    My Dell Inspiron 1200 screen is saying recalibrate the battery.Once i have done this the screen goes blank and does not reboot
    Have you tried to turn on the computer without the battery, it could be a shorted (bad) battery... they can prevent the notebook to boot, if the notebook boot's without the battery you need to replace the battery...
    Mar 16, 2011 | Dell Inspiron 1200 Notebook
    Dell Inspiron 6000 won't connet wireless network after reinstall
    check DEVICE MANAGER if the wireless card have the right driver installed. if you found that the wireless card have yellow exclamation point on the right it means, you installed a wrong driver.
    check also in BIOS if the wireless card is enable and the switch is turn on.
    press Fn+F2 to enable wireless radio/anthena (funtion key with wireless icon in blue color)
    some dell laptop have hard switch located right side check this and turn the switch on.
    if you want to see the icon n task bar, go to control panel....network connection...right click on wireless adapter...select properties...check Show on taskbar
    Apr 03, 2009 | Dell Inspiron 6000 Notebook
    Dell logo then blank screen
    you to first put everthing back into your computer then make sure the hard drive is still working by checking your hard drive light see if it is light up or not go into the bios and make sure the computer is set to boot up for your cd rom first and second the hard drive now if you have windows xp home full you will be able to put windows xp full back on the computer if you have upgrade you will need windows 98 se to use for some of the files that the upgrade doesn't have once you do this it should be able to reinstall windows xp and if that doesn't work put windows 98se in the computer and then use the windows xp upgarde to put windows xp back on the computer if none if this work get back to me with more info and I will try to help you get back on track
    thank you and good luck
    Mar 23, 2009 | Dell Computers & Internet
    Boot problem on inspiron 1150
    Try connecting it to an external monitor.
    When you do, as soon as you press the power button to turn on the laptop, close the laptop lid - as this forces the laptop to display on an external monitor.
    If this works, then it means the laptop screen is bad.
    If it doesn't, the most likely cause would be that the laptop video card went bad.
    For a while, some older Dell laptops with high-end nVidia graphics cards tended to die suddenly.
    Mar 27, 2017 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
    Reinstallation of the XP operating system for a Inspiron 1200.
    ya it can be downloaded from several file hosting sites but no assurance for its genuineness
    Nov 26, 2008 | Dell Inspiron 1200 Notebook
    Reinstallation of XP operating system to my Inspiron 1200
    you can use any Windows Xp CD to install the operting system on your laptop.
    however, you need to download few device driver like network, audio, video, chipset, etc..... from the manufactures' website and place them on a CD before you start. otherwise you will have network driver fro you get on the Internet.
    DO NOT DOWNLOAD BIOS UPDATE. unless you are 110% sure you need it.
    Dell 1200 Inspiron OS boot problem
    Two things you should try to resolve this issue: -
    • Check that the FN button on the keyboard to switch from the Laptop monitor to external monitor has not been enabled - these are usually 3 state switches (Laptop screen ON, External screen ON, Both ON) it is really easy to accidentally hit this without realizing.
    • If this works there is no need to try the second option.
    OR
    • Try booting to safe mode - as the laptop boots up and you see the Bios summary screen depress the F8 button and you should receive a screen containing several options.
    • Select the option to Boot to safe mode.
    • If the laptop boots up ok then login to XP, don't be alarmed at the change in screen resolution.
    • Right-click My Computer on the desktop and select Properties - Hardware - Device manager
    • In the tree-view containing the different hardware select Display Adapters you should see your graphics card in there
    • Right-click and select Scan for Hardware Changes if it is ok the close and reboot as normal
    • If there is a problem here it implies the driver is somehow corrupted and may need re-installing from the disk that came with the laptop.
    Nov 15, 2008 | Dell Inspiron 1200 Notebook
    BIOS for Inspiron 1200
    If you're the original owner just call DELL and they will give you master password
    Oct 17, 2008 | Dell Inspiron 1200 Notebook
    Booting up
    Try to start up with the windows XP CD in the drive, it will give you some options to reinstall or repair XP. If this doesnot work, ensure that your BIOS will startup from CD.
    Aug 18, 2008 | Gateway MX6453 Notebook
    Open Questions:
    See all Dell Inspiron 1200 Notebook Questions
    Dell Inspiron 1200 Notebook Logo
    128 people viewed this question
    Alun Cox
