Question about Lutron Electronic Low-Voltage Multi-Location Dimmer by Electronics, Inc
LUTRON DIMMER THERE IS 3 LOW VOLTAGE LIGHTS HOOKED UP TO THIS DIMMER AND THEY ARE THE LITTLE PUCK LIGHTS..THEY WORK JUST FINE UNTIL YOU TURN THEM UP TO FULL POWER AND THEN THE LIGHTS FLICKER..GET DIMMER AND THEN BRIGHTER..TRIED DIFFERENT DIMMER AND THEY DID THE SAME THING..ANY IDEAS AS TO WHAT MAY BE WRONG? USING THE MAESTRO MODEL
  • John Morganti May 11, 2010
    You said the lights are low voltage.  Do they run off a transformer?  Dimmer switches are not rated for use with transformers and the results will be unsatisfactory.
  • Terry Lee
    Terry Lee May 11, 2010
    Let me get this right. The three light fixtures are operating using the same switch i.e. one switch for all three lights? And this circuit is connected to one single-channel dimmer? Usually, this instance in dimming control occurs when the power source is not regulated or a temporary supply is in-placed. If not any of those, do you have similar problems in other areas where similar dimmers are installed?
    President:
  • 704 Answers
The Lutron Maestro dimmer isn't rated or designed to operate low voltage lighting as it is a 120 V-AC rated electronic dimmer. You should either install a standard low voltage ON/OFF switch on this installation or obtain a dimmer rated for use on low voltage lights.
You need special low voltage dimmer designed for use on the low voltage pucks lights you have installed. Usually the low voltage is either 12, 24, or 36 volts, depending on the manufacturer of your particular light set. Once the correct dimmer is in place, the problem with the flickering and pulsing of the lights, should cease.
If you still are having this problem and you can't find a low voltage dimmer, you can contact the maker of your low voltage light kit and they can provide you with an acceptable dimmer option for your lights.
Most Home Depot and Lowe's carry the low voltage puck light kits, and usually have accessories for these lights, including dimmer switches that will work with them.
Hope you find this Very Helpful and best regards!
PS: I found this old, unanswered question and wanted to provide a solution to close out the problem and clear the question from the site.
Posted on Sep 10, 2009
Hi I've got a Lutron electronic slide dimmer
Let's start whittling away some of the information...
First of all, the ZP260QE is from Lightolier,so you may want to give their tech support center a call.
Secondly, ignore the continuity tests, they tell you nothing. Continuity on the secondary is expected because you're on the output of a "true" transformer, which will look like a short on a DC-supplied continuity test. The input to an ELECTRONIC transformers is a switching power supply, which will not look like anything when supplied by a DC voltage/current during a continuity test. Those test results appear normal to me. The +/- 60 also makes sense, if you've measuring voltages on the output of a dimmer, the impedance of the dimmer's off-state and the impedence of the multi-meter makes for some screwy readings that don't always make sense.
Most dimmers rated for electronic low-voltage have protection circuitry built within them to make sure they're not overloaded. Normal incandescent dimmers will just get warmer than usual, these guys should shut down - perhaps that's what you're seeing.
My two suspiciions are either (a) the additional pendent light, combined with the existing track lights, tripped the overload protection, or (b) when you added the pendent light, you got too much of a current inrush that shorted out the components within the dimmer.
Jun 04, 2011 | Lutron Electronic Low-Voltage Dimmer...
I have a lutron skylark s-600-wh. I would like to know if this dimmer is electronic or magnetic??? I will use it for a series of under the counter kitchen puck lights, and was told that the dimmer...
It is neither - it is rated for incandescent lamps only. It sounds like someone suggested that your puck ligths are being controlled by electronic low-voltage transformers, in which case, if you wanted to stick to the Skylark family, should be an SELV-300P-WH.
If you're not sure about any of this, I suggest calling Lutron's tech support line. It's at 1-800-523-9466, they're available 24/7, and can double-check the recommendation.
Feb 21, 2011 | Lutron S-600-wh Skylark Incandescent...
Our lutron three way dimmers leak when off. There appears to be about 8 volts still going to the fixtures. That causes the transformers on the fixtures to sing when off. Probably not good for...
If each fixture has an individual transformer, the chace is that they are electronic (about the size of a matchbox car) If so, you have the wrong dimmer installed. You will need to install a MAELV (Electronic Low Voltage) Dimmer. The regular dimmers are set up for Magnetic Low Voltage and incandescent which work differently. http://www.lutron.com/TechnicalDocumentLibrary/362219.pdf
Here is a link to the difference in how they work. Also, if they are a Low Wattage light like an LED, the dimmer may not have enough resistance to bleed off the excess voltage. The MAW-600 has a minimum load of either 25 or 40 watts. If you are operating LED's you may also need a Low Wattage Interface to act as a simulated load that wires in series with your lights. (lut-lbx)
If it gets too anoying until you get the proper dimmer, you can switch the Air Gap switch at the bottom to the off position. This completely disconnects the power to the load side of the dimmer.
Good Luck
Oct 02, 2010 | Lutron ELECTRONICS MAW-600H-LA SMART...
Keypads will not respond. Either can't turn on or
Possible power supply problem--low voltage from master unit or dead batteries at each switch. Good luck!
Jul 25, 2010 | Lutron Electronic Low-Voltage...
On/off works but dimmers do not. leviton toggle
If each pendant has an individual transformer that is about the size of a hotwheel then you need a dimmer specifically for ELECTRONIC LOW VOLTAGE. A lot of electricians don't know that the different types of lights require different dimmers. Most store bought dimmers are for incandescent lights only, and some nicer dimmers like the Lutron Maestro's are rated for incandescent or MAGNETIC Low Voltage which require a different Sin wave interuption. I don't know that leviton makes a dimmer in that style for Electronic Low Voltage. You could install a Lutron DVELV300P-Wh, but that is a Decora opening. http://www.lutron.com/CMS400/WorkArea/downloadasset.aspx?id=25437
Here is a link to explain the difference in how the dimmer needs to work. Good luck!
Mar 03, 2010 | Leviton Toggle Touch Dimmer - TGI06-1LB -...
Replaced existing Lutron skylark low voltage dimmer
You will need to return the 3-way dimmer and get a single pole dimmer, as the Lutron Skylark series is suspectible to failure if connected to a live circuit first, or misconnected at intial installation. As an electrician, I ceased using these dimmers years ago, due to the rash of call-backs by customers and went with Leviton togglers and have had excellent results.
If you purchased it at a 'big box' store, they will accept the return as a defective item, as they have national agreements with their suppliers to accept customer returns. Just tell them it didn't work and you want a store credit, you can then purchase the lower priced single pole dimmer you need and save some money in the process too.
Hope you find this Very Helpful - best regards!
Aug 18, 2009 | Lutron Electrical Supplies
Lutron Dimmer Not Dimming But On/Off Works
What is the dimmer rated for? Your load on the track appears to be 200 watts. A standard dimmer will burn out, you need to look on the dimmer to see what it is rated for. Did it run hot with the dimmer before you had this problem? They make dimmers for higher wattage that will do the job for you.
Feb 05, 2009 | Lutron ELECTRONICS S-1000H-LA SKYLARK...
Installing electronic transformer with 3 way touch dimmer switch
Consider using a MAELV-600 and a MA-R. The MAELV is rated for 600W Electronic Low-Voltage. The MAELV will require a neutral wire connection.
www.lutron.com/maestro
Aug 30, 2008 | Electrical Supplies
Lutron Electronic Low-Voltage Multi-Location Dimmer by  Electronics, Inc Logo
564 people viewed this question
Top Lutron Electrical Supplies Experts
Steve
jdthefixer
Craig Butler
Craig Butler
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
