Question about Dell E771MM 17" CRT Monitor
My E771mm Monitor gives me an error message Control menu locked.
My monitor keeps giving me a error message sayin "control menu locked" how do i fix it?
techman
  • 3130 Answers
SOURCE: Problem with Control Panel
It sounds like theres a front panel button that has become intermittant and making contact all by itself. Sometimes when you clean the screen, the cleaner will drip down between the crt face aqnd the cabinet and make the switch in front go bad. Im not sure if this is the case in your problem but its a start. If you didnt spill anything or drip anything into the front panel then your maicroprocessor could be causeing the problem, or the 5 volts that feed the micro could be noisy ie, bad filter capacitor in the power supply. Now as im sure your aware of the hi voltage inside these sets? Its best if you dont have the training to get a pro to assist you as this hi voltage can hang around inside the set even if its unplugged. Good Luck
Posted on Jul 03, 2006
  • 624 Answers
SOURCE: Problem with my Dell E771mm 17 in.CRT monitor
How far from the sides is the image? If it?s just an inch or two you can use the monitor adjustments to expand the image to the edge of the screen where it was previously. If its too far in then the only option is to have it repaired. You didn't mention where you are but in the US even a minor monitor repair that involves at tech opening the monitor is going to cost at least $45, perhaps more. That?s a lot of money for a monitor worth about $100 new so a new or used monitor may be a more cost effective option for you. Let us know if you have any other questions and please don't forget to rate this post.
Posted on Apr 04, 2007
Noggin
  • 944 Answers
SOURCE: philips 109s20 crt monitor
Here's the link for the product support page; http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=109S20&scy=us&slg=AEN&grp=PC_PRODUCTS_GR&cat=CRT_MONITORS_CA&sct=CRT_MONITORS_GT19_SU Click "User Manuals" on the left. or here is a direct link; http://www.p4c.philips.com/files/1/109s20/109s20_dfu_eng.pdf Check page 28: "The Main Menu displays OSD MAIN MENU LOCKED . Pressing the front control panels hasno effect. How can I unlock this function? Press and hold the OSD menu key for about 10 seconds until picture displays "OSD MAIN MENU UNLOCKED"" Hope this helps :)
Posted on Sep 03, 2007
samkong
  • 106 Answers
SOURCE: my sansung monitor bring a lock and unlock menu on the screen
Befor replacing the Control ic please check the micro switches those could also be faulty.
Posted on Oct 07, 2007
hmerchant110
  • 7191 Answers
SOURCE: Monitor Controls Locked
To unlock your monitor, Press and hold the Menu button for 5 - 10 sec. and the OSD menu should be released.
Posted on Apr 30, 2009
Control menu is locked
Press the OSD button for 3-5minutes before it will be unloacked.
I accept donations for my free service Thankshttp://www.paypal.comsend it to paypal email: rpamular10@yahoo.com
Mar 13, 2012 | Dell E771MM 17" CRT Monitor
While i am opening the system i am gtting in monitor control menu is locked ,how i hve to un lock it pls give some tips
Maybe the problem is in your control panel (where the buttons are located) maybe one of the buttons are in normally close state, where in the button is already pressed.first check the buttons use a multimeter to check a good push button reading when not press is 0L in digital multimeter while in analog the reading you get is nothing. and when the buttons is pressed the reading must be 000 it means that the button is good. Try to replace a new push button or buttons. Hope this may help
Aug 06, 2011 | Dell E771MM 17" CRT Monitor
I have a dell monitor and I keep getting this notice that control menu is blocked. how can I resolve this?
For the E771MM, press and hold the OK button on the monitor for 15+ to toggle off the OSD lock. Holding the button turns on the OSD lock as well. The OK button is the rightmost of the control buttons (excluding the power button). This is a useful feature if a small child will be near the monitor or if the monitor is being used for demonstrations.
The user's manual for the Dell E771MM is here: http://support.dell.com/support/edocs/monitors/e771mm/English/index.htm .
I hope this helps.
Jul 01, 2011 | Dell E771MM 17" CRT Monitor
When the monitor (dell e771mm) is hooked up and the computer is turned on, the monitor goes right to a solid blue screen, no text, no error messages, i can manually control the monitor menu and it displays...
I do not think it is your monitor. Plug it into another working machine to see what it does. The result will tell you whether it is the monitor or the computer.
Sep 01, 2017 | Dell E771MM 17" CRT Monitor
My monitor's model is TX 78682 ,now the menu control is locked and I want o know how to unlock it?
try to press and hold the MENU button of your monitor for about 9 to 15 seconds to unlock it. hope this helps. feel free to rate the usefulness of the info
Mar 30, 2011 | Dell E771MM 17" CRT Monitor
My monitor give me this words control menu is locked
Press the menu button and keep pressed for 20 seconds or untill OSD unlocked message come and same procedure for OSD lock.
Thanks,
Bhautesh
Aug 20, 2010 | Philips 107E56 17" CRT Monitor
Want to unlock my monitor
This is the function that locks the OSD in order to keep the current states of
settings or prevent others from adjusting the current settings.
1. Lock : Hold down the menu button for more than five seconds to activate
the OSD adjustment lock function.
2. Unlock : Hold down the menu button for more than five seconds to
deactivate the OSD adjustment lock function.
Though the OSD adjustment lock function is activated, you can still
adjust the brightness and contrast, and adjust MagicBright ( )
using the Direct button.
Found at: http://www.retrevo.com/support/Samsung-713BM-PLUS-Monitors-manual/id/2994ag905/t/2/
Hope this helps and please remeber to give me a rating, thanks!
OpenSource13
Apr 06, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
Powersave problem
If you are using a desktop computer, chances are that you don't want the computer to go to sleep automatically. This is even more the case if you are running Vista in a virtual machine for testing purposes.
Disabling power management is simple and easy. First go to the start menu and click on the Control Panel.
Click on the System and Maintenance link
Then click on the Power Options link:
It will disable automatic sleep mode, but will still turn off display.\
You can click on change plan to disable.
If you are using XP than.
Open control pannel-> click on power option -> keep turn off monitor setting to never.
Feb 10, 2008 | Compaq Evo D500 PC Desktop
Dell E771MM 17" CRT Monitor Logo
178 people viewed this question
Alun Cox
