Door wont lock
I have a lg washing machine model wm/16225fd.and on the display panel it has a lock sign on it but the door doesnt lock even when its on wash cycle.can you explain
  • l_hannah1 Apr 12, 2009
    how can i fix the mechanism in the door without costing a fortune?
  • Cary Crook May 11, 2010
    Are you getting any codes for example LE or another type code?
  • 77 Answers
Hi, it is probably the lock mechanism that is faulty, you need to get it changed, hope this helps!
Posted on Feb 10, 2009
  • Ian Jones Apr 13, 2009
    Hi, the door lock on washing machines is an electro magnet which in you case has failed, if you can live with it leave it as it is, if you have small children then it may be wish to get a new one, you can access by removing the top of the machine (screws at the rear) then slide the top backwards and remove, look down the fron of the inside cover to locate the lock, is is easily removed and replace with a new one, available from a spares shop, you may need to order it, make sure that the unit is not plugged in to the mains while the top is removed, hope this helps
Lg intellowasher wd1074fb
When you see the DE error code, it means a "door error". This is a sign that either the door is not shutting, locking or opening. Most of the time, this is a simple fix and service is probably not needed. Check for something stuck or lodged in door. Check door gasket. Check door latch.
May 13, 2014 | Washing Machines
Door wont open
Late answer, but --- unplug the machine, wait for the door switch to cool. Not more than four or five minutes, it should open.
The door switch should be replaced, it's easy to do.
Apr 23, 2014 | LG WM-3677HW Front Load Washer / Dryer
DE error code on LG washing machine
Beyond that could just be the door latch itself.
Nov 23, 2013 | LG WM-2277HW Front Load Washer
My LG WM 1812CW turns off soon after the first spin. No error message.
Seems that the main panel is defective. The fault suggests that the program controller or the processor is malfunctioning specially when it works for some time. If you can check on the +5 volt to the processor , the power supply factor can be established as a faulty supply or a blown mains capacitor can also shown this fault .
So remove the panel and check the components for any visible signs.
Jan 14, 2013 | LG WM-2277HW Front Load Washer
Mt LG washing machine (model wm2277hs) displays an error code containing an upside-down "F" and an "E". What part(s) do I replace?
Replace the thermistor, part # 6322FR2046C
It is located right next to the heating element at the bottom front of the outer tub. (just below the door gasket) It is very difficult to replace without removing the front panel.
Mar 03, 2011 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
Our wm-16225fd does not spin/drain.I have fitted a
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 15, 2009 | Washing Machines
Lg washing machine wm-1460fhd door locked wont open
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
Jun 10, 2009 | LG WM-1480FHD Front Load Washer
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Jan 29, 2009 | LG WM-2277HW Front Load Washer
Door lock
if you cannot get to it by just reaching between the rubber rim.
The official way is to take off the top and bottom access panels , 3 screws on each in top rear and on the bottom front, then remove the front control switch panel.
then you can remove the front of the machine.
Feb 27, 2008 | LG WM-1090FHB Front Load Washer
Washing Machines Logo
146 people viewed this question
Top Washing Machines Experts
