Question about Dishwashers
Dishwasher ''soft drop door'' mechanism came apart - door now drops
Help!
I have a Jenn-Air JDB6510AWP dishwasher. I took the bottom panel off, pull the unit out slightly, and found the left door spring, tub wheel, and ''soft drop door'' cable all lying in cavity on the left side of the outer tub. I think I located the ''soft drop door'' bolt mounted about 6 inches in along the bottom edge of the base frame. I assume this what the tub wheel slides onto to act as a pulley for the cable. But when I slide the wheel on to the bolt post, hook the spring on to the end slot of the left hinge arm, thread the eye end of the cable on to the other hook end of the spring, loop the cable around the tub wheel, and try sliding the other (flange/hook) end of the cable on to the keyway (2nd slot in from the end) on the left hinge arm, the cable is a few inches too long. Obviously, I'm not assembling it correctly. Does anyone have a diagram or knowledge of how to assembly the ''soft drop door'' mechanism correctly?
Much appreciated!
  • scm00re May 02, 2009
    The soft drop door tub wheel came off and the cable was lying on the floor with the tub wheel. I was able to put the tub wheel back on the bolt and re-loop the cable to the spring. However, when I open the door the tub wheel slides off the bolt and pops off again. Is the tub wheel supposed to click onto the bolt somehow?
I had a similar issue as described by mc1bean. One day my Jenair dishwasher door just fell down. The right side spring was fine. The left side spring was still hooked into the door hinge but the cable was laying on the floor in 2 pieces. Over time it wore down and broke. I ordered just the soft drop cable. Now I could not find any installation instructions how to install the soft drop cable. After a few tries I think I got it right. Here are the instructions for hooking up the right side spring with the cable. The spring has to be hooked into the door hinge at the notch closer to the door. The end of the cable with the hook has to be hooked into the other side of the spring. The cable should lead from the bottom around the pulley up to the door hinge again. Now the other end of the cable has to be hung into the door hinge on the notch further away from the door. There is some slack, but it is not quite enough for the cable to get over the pulley when in rest position and undo itself.
I hope this helps others who have the same issue.
Posted on Aug 26, 2012
2 Suggested Answers
mc1bean
  • 3053 Answers
SOURCE: Jenn-Air dishwasher, model JDB6510AWP dishwasher won't
Hello, sport
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
How do I adjust the door hinge tension on a Beko Dishwasher DW51
Hello!
most dishwashers have springs on each side of the door bottom that can be moved to different mount points to adjust tension.
In many cases they may be accessed by removing the bottom kick panel, but it may be necessary to back off the from adjuster legs, remove any other cabinet securing screws and pull the unit out slightly.
All the best.
Nov 20, 2014 | Beko Dishwashers
I took the inside of the door off my Jenn Air dishwasher and now it won't start
You broke it!!!!!!! Check out the wiring associated with on/off cycle. There might also be a switch by the door designed to not allow unit to turn on when door is open - check it out. It might not be engaged if the inner panel of door is not properly hitting the switch.
Aug 22, 2017 | Jenn-Air 24 in. JDB1100AWS Built-in...
Problems with integrated dishwasher
The door tension is set with a spring. You need to pull the unit out part way and look on the left and right side bottom area near the front. The spring can be adjusted by selecting a different hole in the bracket that it is attached to.
Jun 02, 2013 | Jenn-Air 24 in. JDB1100AWS Built-in...
Adjust door tension on jdb-5 jenn air dishwasher, door too heavy
There are springs on both sides of the door, likely one has snapped. You can get at the spring without removing the machine, sometimes, by pulling the bottom panels...
Jul 02, 2011 | Dishwashers
Door has no tension on it when opening it. It seems like a spring may be broke. How is the best way to go about checking it out and repairing it. Thanks Joey
Remove the front bottom access plate.
Look inside on the bottom right and left front corners for the spring and replace it in the grooves and slots from the door hinge to the cabinet base.
If the cabinet sides are in your way,you must remove the 2 screws mounting the machine to the underside of your counter top and pull the machine forward a few inches.
You should be able to do this without disconnecting water or power.
If the door spring is broken you will have to go to the appliance parts store in your area for another one.
Aug 14, 2010 | Jenn-Air JDB6510 Built-in Dishwasher
Our jenn-Air built in dishwasher smells foul and has since the first time we used it 4 months ago. we have tried bleach, vinegar, finish brand dishwaher cleaner, less soap, cascade soap, running every day,...
We had similar type of problem (as well as residual water always left in bottom) and after pulling out the dishwasher, found that the drainage tube was incorrectly installed by contractor. It was laying on the floor behind it with a only a slight rise to the garbage disposal inlet. I suspect this contributed to sewer odors as well a water back flowing into the dishwasher. I disconnected drainage tube so that it went up 24+" and then connected to garbage disposal (creates a loop that blocks sewer odors and back flow conditions). I also cleared out the filter at bottom of inside the dishwasher. The Use & Care Guide suggested using baking soda in China/Crystal mode for 10 minutes, opening the front door and letting it sit overnight. I repeated that for 3 nights and it did clear up the remaining odor. Don't know if this will help your issue or not. Good luck!
Jan 09, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Jenn Air dishwasher door won't close
i had the exact same issue. it's a broken latch mechanism, and is a fairly common problem.
i bought the part at my local repair shop for $45 (you can find it online for $30). it literally took 10 minutes.
you need to right size bit to remove the 10 bolts on the interior of the door. once you have those out, the latch slides right out of the top. there are 2 electrical connectors (careful - you can get a shock. disconnect the 2 connectors, reconnect to the new one, and zip your 10 bolts back in. super easy
Aug 18, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
Soft drop door mechanism came undone The soft drop door tub wheel
It's held in place by a soft drop nut (99002192). If damaged, the tub wheel part number is (99002183), and the soft drop bolt is (99002189).
May 02, 2009 | Jenn-Air JDB6510 Built-in Dishwasher
Difficult to pull door open and loud click coming from left hinge
I would check for obstruction in the path of the door spring areas. If appropriate, remove the bottom access panel (typically 2 screws); open/close the door in attempt to observe the inside bottom left and right for the clicking sound.
If not already done so, also ensure your dish-washer is raised of the floor a little bit; leveled and properly secured to counter top with 2 screws.
-C
Fremont, CA
Jan 30, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
Dishwashers Logo
419 people viewed this question
Top Dishwashers Experts
