Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
Strange problem I can fax to any fax number that I have to except for one particular number. Whenever I fax to this person the fax rings the number and the paper starts going through but then it stops half way through. I then get a transmission report saying "poor line condition". I just don't get it. It is always that same fax number that we have problems with. We have never been able to fax to them. But they can fax to us, with no problems. Any ideas??
  • info334 Feb 10, 2009
    We have told them and they just say that they receive faxes from other people all the time. But it is nice to know that it isn't our problem. Thanks
  • 10,865 Answers
The problem is with their system, not yours. they are probably missing lots of faxes. They may for instance have a few phone lines which receive faxes called a "hunt". If one or more of their lines are bad they may not even realize it.
I suggest you call them and tell them what is going on.
Posted on Feb 10, 2009
We are having issues faxing to one particular number. We think our fax goes through, but spits out a Error 345*. Nothing is sent
fax machines talk to each other before sending data to ensure that the sender/receiver are on the same format and are compatible
for one particular number to be a problem indicates a fax number problem in setting the dialed number area code , dashes etc are all specific
ring the receiving department and ask to confirm that they are having trouble receiving faxes from your number as well
Dec 14, 2016 | HP Office Equipment & Supplies
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
Fax won't answer
If you have an answering machine connected to the same line as your fax:
If you have a voicemail feature associated to the same line as your fax:
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
Sir, whenever we try send any fax there are continue ring no fax tone received so i want know how i can solve this problem
Firstly you should try checking sending fax to other number as well if same thing is happening try following steps.
Go to Setup/Menu- Fax Setup/Menu- Distinctive Ring- Check what is it- If it on Ring Only change it to Fax tone.
Save the settings and get back to the main screen and the tru sending Fax again.
Note* you need to do these steps on the all in one or Fax machine .
Jul 06, 2011 | Office Equipment & Supplies
I have a canon mx410 all in one inkjet printer.i need assistance with setting up the fax to a phone line. Thank you Zainy
  • Call your phone company to sign up for service. Ask for an additional line with a "distinctive ring." The additional line is for your fax machine---whenever you hear the distinctive ring you'll know that a fax is coming through. Get voice mail service on the regular phone line as well.
    Purchase a two-jack phone splitter (sometimes called a wall jack adapter) that allows two cords to plug into the same phone line. Plug it into the phone jack in your wall.
  • Run a phone cord from both machines into the wall adapter. Test the system by calling both your regular phone number (assure it rings and the voice mail picks up) and your fax number to see if the fax machine picks up (you'll hear a set of strange beeping tones).
  • Apr 13, 2011 | Canon Pixma MX410 All-In-One Printer
    Phone numbers
    Try changing the advanced fax setting rings to the same style of rings as distinctive ring-All, two shorts, two longs etc.
    Apr 29, 2009 | Vtech 5.8GHz Analog Cordless Phone
    CAN'T GET FAX TO WORK
    turn off answering mech. count # of rings before fax answers add onemore ring to answering mech. before it answers.
    Dec 27, 2008 | HP OfficeJet 6110 All-In-One InkJet...
    Fax machine problem
    You are hearing the fax machine hand shake. You should have a dedicated line for your fax.
    If not scroll through the menus and set your fax to the maximun NUMBER OF RINGS.
    Nov 12, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
    Invalid number
    Fax machines do not work well or at all on digital lines. They are designed for analog lines, like the standard phone company line. You may have to install a dedicated fax line from your tel. company.
    Jun 11, 2008 | Samsung SCX-4216F All-In-One Laser Printer
    Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
    149 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
