Question about Braun 360° Complete 8985 Electric Shaver
Cleaning base thinks it's empty
I just changed the cartidge in my cleaning base. The base starts off saying it's full then quickly moves to the middle mark. When I place the shaver in to clean/charge, the motor whirrs for a couple seconds, clicks off and the base then says that the cartridge is empty. I tried another cartridge, same problem. Any suggestions?
  • Anonymous Apr 20, 2009
    same issue here.
I had the same problem. Try taking out the cartridge and in the compartment where the razor sits in to get clean, there is a drain hole on the left side. Try cleaning the hole out with a toothpick or something similar. It seems that the drain hole clogs and causes this problem. I just did it and all seems to be working fine.
Posted on Feb 17, 2009
Toner leaking and low quality copy
I would check the transferbelt/wastebox/cleaning unit to see if it is full or have a problem with cleaning.
If it is full it will make a soundt as some toner is forced out of the wastebox. I've seen a few examples of cleaning blades that does not clean smoothly too. When the blade moves toner scatters.
It it is full, empty the wastebox and change the cleanin blade.
If not, check the drum and the drum cleaning. I've had a "jumping" cleaning blade on the drum too, also resulting in toner scattering inside the machine. It that is the case, the blade must be changed.
In order to make this machine run kind of OK, you need to keep it super clean, change developer and other parts at least as often as Ricoh says in the service manual.
Make sure you have the latest firmware model, and the right toner.
It is a machine that runs dirty, and based on the POS Adonis series of machines from Ricoh.
For other viewers here, stay away from the Ricoh Aficio 350/450, 1035/45, 2035/45 and newer models like the MP 3500/4500.
You will notice companies that sell copiers from differente brands often have decided not to sell this model from Ricoh, and just choose a different make/brand as their machines (in this segment) are better.
Jul 07, 2017 | Ricoh Aficio MP 3500 Digital Copier 35cpm...
I experienced the same symptoms on my 8995; solid yellow light (even though the cartridge was full), cleaning failed (red light on) after pressing either start button. After many failed attempts to clean the razor, unplugging the station and pushing start button, I decided to clean the razor under running water. I rinsed the razor under water and then turned it on allowing it to run in a pool of water (like it would in the station). After water cleaning, I returned the razor to the station, pressed the start button and it worked! Was able to do both the quick clean and auto clean.
Jan 06, 2013 | Braun 8995 Electric Shaver
I have a Honda mower model HRR2163TDA but it doesn't seem to matter what mower I own because I end up with the same problem. After about two years the spark plug gets fowled ''black'' quickly every time I...
Your piston oil rig may be bad and is alowing oil by wich will fowl the plug. The more load on the engine such as a full bag the more oil gets by.
Apr 18, 2010 | Garden
At the installation of the new printer, it says that one of the black cartidges is empty and need to be replaced. This I did and again the same message came. So one is good, Two times one is not good. What...
If your cartridge is not empty, you simply disregard. Your computer could have been invaded by some virus. Try installing some antivirus software in your computer, and see what happens.
Oct 21, 2009 | Epson Stylus RX580 InkJet Photo Printer
No printing
Check your black ink cartidge. it may be empty.change it with new balck cartridge
this problem may also be due to cartidge holder .
clean cartrideg holder with moist cotton with petrol or some other cleaning liquid as nail polish remover. clean properly the cartirdge socket and mainly the contact point of cartridge socket
Aug 20, 2009 | Lexmark X3650 Printer
Remove and Check Cartridge
One of the cartidges you have purchased is faulty.
you can reinstall the empties one at a time as a process of elimination to determine which new cartridge is the problem
Jun 06, 2009 | HP OfficeJet 6110 All-In-One InkJet...
3600dn keeps saying tray 2 is empty when its not
Its the first finger sensor right above the tray 2 that gets stuck. It should move freely.
Jul 22, 2008 | HP LaserJet 3600dn Printer
After refilling cartidge it still says it is empty
IB4G2008: Do u actually have a solution or a better driver for this printer OR are u just out to promote your site?
Your solution is not helping & if u think it is, pls oh pls,let me know of a DIRECT link for it, as i havent found anything that makes the problem better, nor a better driver for that particular printer.
Pls advise.
Jan 23, 2008 | Lexmark Z1420 Printer
360 is saying empty
I just fixed it now .. when the cartridge is inside and full turn the whole bas upside-down for less than a sec .. ( while the power plug is disconnected ).. then try plugging and cleaning again
Dec 24, 2007 | Braun 360° Complete 8985 Electric Shaver
Braun 360° Complete 8985 Electric Shaver Logo
615 people viewed this question
Top Braun Health & Beauty Experts
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
