Question about Kodak EasyShare V803 Digital Camera
Trouble Formatting New SD card
Kodak Easyshare c310 .Trying to format new 2GB SD card.Keep getting FILESYS ERROR e00100 .Anyone know whats wrong please ?
    President:
  • 2,110 Answers
Try to format using a card reader through PC...
Posted on Feb 10, 2009
What does filesys error e00100 mean
Hello and Welcome to FixYa!
Error e00100 means that the card is corrupted or formatted for another digital camera.Format memory card and see the results,Try to format the memory card using a card reader with the PC, if error still exists then it means the memory card is electronically incompatible and won't work The Kodak C310 uses MMC and SD cards and may be you are using SDHC memory card, In this case change the memory card,
I hope problem will be solved, if error still exists then contact to Kodak Cameras service providers.
I hope this solution helps you
Your token of appreciation in the form of Four thumbs and testimonial will be esteemed.
THANK YOU and Keep Visiting FixYa
Apr 11, 2011 | Kodak EasyShare C310 Digital Camera
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
Inserted 4G memory card...says memory card is full...when I try to format the card, get filesys error e00100.....
The C330 uses MMC and SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and won't work. You need to go with cards 2GB and smaller.
Jan 11, 2011 | Kodak EasyShare C330 Digital Camera
Trying to format screen says filesys error e00100, camera wont format chip, chip is brand new.
Your Kodak camera can only work with a card that has a capacity of 1GB MAX anything more and it just wont work.
Aug 10, 2010 | Kodak EasyShare C310 Digital Camera
I have a kodak c310, trying to format the card and it keeps saying memory full format card, so i format and it comes up FILESYS ERROR e00100, but it's a new card?
The c310 will only accept SD cards up to 2GB.
You haven't said which card you're trying to use but the symptoms are typical of those encountered if you try either a larger capacity SD card (which go to 4GB maximum) or if you're trying to use a later SDHC (the HC means High Capacity) card. The c310 was designed and manufactured before SDHC cards were manufactured and is incompatible at the basic hardware level. SDHC's will fit inside as they have the same form as SD cards, but your camera is unable to use them.
If you have tried using the wrong card then all you need to do to fix the error is to replace it with a standard SD card not exceeding 2GB. In practice you'll find that your camera may have issues with some brands/models of 2GB SD cards but that it will work fine with any make or model of 1GB SD card. The smaller capacity card will also ensure that your camera does not become awkwardly slow in operation.
Hopefully I've answered your question; all I ask in return is that you return the favour by rating my answer.
Oct 21, 2009 | Kodak EasyShare C310 Digital Camera
I bought my Kodak Easyshare C310 a few years ago and has been working fine. I bought a new SD card as lost my old one, and when I inserted into the camera it said the memory card was full (wasnt as brand...
Hi there
Check to make sure the cards write protect is off, take the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg . Put it back in the camera and use the menu to format the card.
If the format fails then its a possibility that you will need a new card.
Good luck and thanks for choosing FixYa!!
Jun 08, 2009 | Kodak EasyShare C310 Digital Camera
I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
Jun 01, 2009 | Kodak EasyShare C330 Digital Camera
Kodak c310 camera won't format new SD 2GB card old card same size
Older C310s won't take that large a card. Try to exchange it for a 1 GB or smaller. I had the same problem - a PNY 1 GB works fine
Mar 22, 2009 | Kodak EasyShare C310 Digital Camera
FILESYS ERROR E00100
Which size has the card?
Is the write protection enabled?
Click
But try an firmware upgrade.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
Dec 20, 2008 | Kodak EasyShare C330 Digital Camera
Kodak EasyShare V803 Digital Camera Logo
686 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
