Question about TruTech PLV1615T 15 in. LCD Television
Picture disappears and changes to white screen
The picture on the screen begins to jump. This will contine for about 10-15 minutes then turns to a white screen. I checked all connections. I turned tv off for 15 minutes and turned it back on.
  • Anonymous Mar 13, 2014
    about half the screen is lit correctly when first turned on. picture looks good after 15 minutes.
I am assuming that this is the nature of the fault and that it is repeatable. Does what you have described occurs every time you turn the damn thing on. You haven't said is whether or not there are changes in sound when the screen malfunctions or whether your unit plugs into a GPO or a black box which plugs into the GPO.However this only dictates the ease with which the faulty component is replaced What seems to be happening is that white level controls are setting to maximum gain. If the control is digital It is almost certainly due to dirty power. The sound level should also change if the power supply is the culprit. Spikes cause the gain on the control to ramp up or down erratically (change) on digital parameter controls. This resulting in bleeding for white levels and a change in the sound levels. Replace the power supply if possible. A cheap workaround can be made if my assumptions are correct and the main transformer is not faulty. Leave a post if you want more info
Posted on Aug 01, 2007
SOURCE:
Philips 26pf3320
check circuit board for bad connections...
May 19, 2010 | Televison & Video
Screen save stops displaying
If you go to Start Menu --> Control Panel --> Power Options --> then look the option that allows you to change the amount of time that the system turns off the monitor because of inactivity.
Apr 15, 2009 | Toshiba Satellite A215-S7422 Notebook
Screen goes white
you may have a solder joint or an electronic part that is beginning to fail. have an electronic expert look at it.
Feb 07, 2009 | Sharp 25R-S100 25" TV
Color flickers on and off
I went to the Sony support page for your model.(link below)http://esupport.sony.com/US/perl/model-home.pl?mdl=KP61V85&LOC=3
They are undergoing maintenance right now, so I couldn't find any answers for you. I would check back with the website to see if they can help you. If the Standby timer light flashes, you may need to have the TV repaired. There is a "Hot Topics" section for "How to troubleshoot television picture issues" that will probably be very helpful to you.
Dec 05, 2008 | Televison & Video
TV Trouble: Toshiba Flatscreen CRT (Brazilian model: Linha Face)
i suggest if you buy it few months ago that item is under warranty
you to call the toshiba service and try to have changed with another
one or get free service - delfo
Mar 21, 2008 | Televison & Video
Convergence setup menu gone
No rest on this model other than unplugging to let it return to factory default. If your a tech .. Check R19722 and R19703 for open. Both 750 K. these open make the convergence menu to be gone.
Jul 13, 2006 | RCA P52929 52" Rear Projection Television
TruTech PLV1615T 15 in. LCD Television Logo
106 people viewed this question
Top TruTech Televison & Video Experts
Steve Allison
Steve Allison
Joaquim Martins
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
