Question about Lands Phones
LOUD SPEAKER NOT LOUD ENOUGH
I HAVE AN IDECT X 3 AND THE LOUD SPEAKERS ARE NOT LOUD AT ALL.....ANY IDEAS PLEASE
  • 214 Answers
After checking the reviews for your phone, it seems to be a common problem with that model. I'll give you a link...
http://reviews.argos.co.uk/1493-en_gb/5523324/reviews.htm
Wish the news was better.
Posted on Feb 10, 2009
Bose cinemate speaker system suddenly gets very loud why?
If the unit is around 5-6 years old or less, you have a bad Rotary Encoder. It is an input to the microprocessor IC(a computer within your Bose). If you would like to inquire about repairing your Bose, please visit me at my website, audioserviceclinic.com. You may contact me directly from the site.
Jul 19, 2014 | Bose CineMate GS Series II digital home...
Jl w7 not loud enough
If your sub isn't loud enough you may want to look into a few things;
1. What type of amp you're using and its output rating
2. The gauge of your power, ground, and speaker wiring
3. The condition and type of enclosure you are using
4. Check to make sure the speaker cables don't touch, because this can cause it to ground itself out and produce little to no sound.
5. Check the RCA connections and make sure they are in order
Aug 31, 2012 | Jl Audio 12W7 Car Subwoofer
Just removed stock front speakers from 2000 Jeep Grand Cherokee with premium sound. Speakers were working, but my son wanted new ones. Installed Infinity 9632cf speakers and we're barely getting any...
A lot of companies are using 2 ohm speakers for stock speakers. This means they are more efficient (sounds strange that a stock speaker is efficient). The stock amp may not be able to put enough power out for these to sound good. You may end up needing a new system.
Sep 01, 2011 | Infinity 9632CF 6" x 9" Coaxial Car...
Main Bass speaker not working!!
Hello Adam Hi, it looks like your main IC amplifier inside the main bass box is bad, need to replace that IC. What are your plans, do you want to do the repair or have it service by a tech guy.
May 06, 2010 | Bose Companion 3 Computer Speakers
The volume of my built-in speaker is not loud enough
The volume os thes speakers are limited bytheir size.
If you have increased your volume control to the max, and they are still not loud enough,
I suggest you purchase a pair of acessary speakers, and use them instead.
Mar 14, 2010 | Compaq Presario PCCOM2232US Notebook
I have a kenwood kac-8452 4 channel amp that makes the speakers pulse after the volume gets turned up to 10. I also have a kenwood amp doing the same thing with my subs. any ideas?
Its not pulsing, its called clipping. The sound is being clipped due the amp being pushed past is power capacity and distorting the signal. This will damage your speakers very quickly. No amp should be turned more then 3/4 up. If its not loud enough you need to purchase a larger amp or be comfortable with the wattage it produces at 3/4 volume. You may also have speaker wires touching/crossed causing th issue.
Sep 10, 2009 | Kenwood KAC-8452 Car Audio Amplifier
Noise comming from main speaker.
i think your boofer not working paper wrap
Jul 23, 2009 | Altec Lansing AVS 500 Computer Speakers
How do i disable the protect mode?
Ensure your speaker ratings (4 ohm, 8 ohm, etc) are sufficient with the output of your unit. The protect mode sense a currently level on the output amps that is nearing the failure rating. Just make sure your have properly rated speakers.
May 03, 2009 | Sony STR-DE475 Receiver
Deffective Speakers????
No need to buy a new speaker,
Inside the speaker box there is one TRANSFORMAR with 4 or 2 Diods & capasitor will be there that will connected to your Power cord & another line will go to Speaker ,
smoke has came from the transformar,
If you able to replace that your speaker will start work fine
cheers
Nov 30, 2007 | JBL (JBLONTOUR) Computer Speakers
Loud and strange noises
The built-in speaker amp or the volume switch may be going bad on you. A quick test is to disconnect the speaker set and replace it with a headphone or another working speaker set. If it behaves normally then the problem is in your original speakers, if not then you may have software driver issues or less likely an issue with the sound card. Let us know what you find out.
Jul 28, 2007 | Dell 5650 Computer Speakers
Lands Phones Logo
291 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
