Question about Aprilaire 700 Humidifier
Aprilaire 700 leaks water from bottom of case
Water drips from bottom of case where latch is located when the unit is running. how do I know if the distribution tray is inserted properly?
  • polconric Mar 08, 2009
    I replaced my 700 model in Dec 2007 because it was leaking near the latch. Now my replacement is leaking. Can anyone help my HVAC can't seem to. dbr
    Novelist:
  • 189 Answers
Install new water panels yearly. On the new panel make sure that the painted dot on the edge of the panel is on the top when you install it.
Always clean the distribution tray and the frame. Make sure the notch on the edge of the distribution tray faces away from the furnace. Make sure the humidifier was installed level. Keep the drain tube opening clear. Insure there is no blockages in the drain tube.
Good luck
HVAC Teacher
Posted on Mar 09, 2009
Aprilaire 700 water never shuts off
the float may be bad or sticking allowing water to run continusly even when unit is off.
Nov 06, 2013 | Aprilaire 700 Humidifier
Aprillaire 760 leaks from the bottom left of the case. panel is new, drain is clear, all vents open in the house, the panel cage is free from excessive scale. Any ideas?
Here is a link to your humidifier http://www.iaqsource.com/article.php/my-aprilaire-humidifier-is-leaking-what-to-do-about-it./?id=35
Oct 19, 2011 | Aprilaire 700 Humidifier
Aprilaire 600 was leaking water from bottom of unit...subsequently filter pad replaced and all parts cleaned of residue; drain tube cleaned and is draining...The problem is that water is still dripping...
Sorry to read about your problem, I hope this helps you out.
you must have a defective water inlet valve, and its letting water in, just a little.. it maybe dirt in the valve, clogging it.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Aprilaire 600 Humidifier
I have an Aprilaire 700 that is leaking at the bottom. Most of the water exits as it should through the drain tube. I am not sure my fan is turning. Is it that quiet or should I hear it? How can I test?
Most likely you have too much water going to the unit you may have to throttle down the water valve that is tapped into the domestic water source. Also check to see if the tray is in the spud going to the drain
Dec 14, 2009 | Aprilaire 700 Humidifier
My Aprilaire 700 does not seem to be working. The
you can bypass the humidistat by shorting the 2 brown wires on the bottom of the humidifier. just remove the 2 wire nuts and touch the 2 together (just 24v)if it comes on then there is a control problem with the humidistat or wiring if it doesnt come on the control board or transformer may be bad or you dont have 120v to the humidifier on the plug. also make sure your furnace blower is running cause the hum cant come on if its wired properly unless the fan is running. you also may want to go to www.aprilaire.com and get a maintenace kit from their online store. it comes with pad and new hose along with a couple other things.
Nov 24, 2009 | Aprilaire 700 Humidifier
Water drips from unit
lift the frontup2 inches should drain out back if not blocked
thumbs up
Aug 17, 2009 | Aprilaire 600 Humidifier
Water is leaking from the bottom of the unit
The tune up kit that I ordered arrived on Friday and I installed most of it on Friday night. While it is nice to have a new frame and the distribution panel and I think the price of the whole kit was fair considering it comes with the parts and 2 water panels, the fix was really simple.
The kit came with the water distribution tube with with a new blue orifice (Aprilaire #4232) already inserted. This orifice is in the end of the plastic tube at the solenoid end. When I removed the old water distribution tube, the old orifice was not really dark blue anymore but kind of a light blue and was deteriorating from 12 years of exposure to the chemicals in the water. What should have been a pin-hole size opening in the orifice was up to about 2mm or a little more so the orifice was letting way too much water through.
If anyone else has this leaking problem, and your orifice is several years old, I would check that first. It is a $2.75 part and may be the cause of the leak. The whole feed tube kit is only $8.75 and includes the feed tube, nozzle, orifice, ferule, compression nut, strainer so if you need to replace the orifice, I would order the whole feed tube kit for a little bit more.
Hope this helps,
Roger...
Jan 17, 2009 | Aprilaire 700 Humidifier
Leaking humidifier
Check for an obstructed drain line.
Feb 28, 2008 | Aprilaire 700 Humidifier
Water leaking from the bottom of the humidifier
Make sure the bottom port on the humidifier is seated properly in drain port. Make sure your drain line is not obstructed.
Feb 25, 2008 | Aprilaire 700 Humidifier
Water dripping from unit
if the water panel needs to be replaced , this can happen. instead of going through the panel , water will run on the outside of the panel and drip through the seems on the humidifier cover. make sure the plastic hose that goes into the water panel is inserted into the water panel.
Dec 27, 2007 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Logo
494 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
