Question about Kenmore Washing Machines
WILLNOT SPIN OR AGGITATE/IT WILL DRAIN
THE AGGITATER WILLMOVE BY HAND-BUT IT WILL NOT AGGITATE IT MAKES A GRINDING NOISE-DOES NOT SPIN-BUT IT DOES DRAIN
  • 1,031 Answers
Just because the rubber part of the coupler isn't shreded doesn't mean that the plastic parts are not broke... There are three stems that protrude from the plastic parts of the drive coupler,and mesh with the rubber section of the coupler... the stems may be broke off... If you smell rubber burning then I would say almost 99% of the time it's a bad drive coupler...If the coupler is not broke and the rubber section is alright then you have a bad transmission... Most likely the main drive gear is bad... Since you said that you can spin the tub by hand, indicates that the brake system is alright, and nothing is caught between the inner and outer tubs... You can rule out a lid switch problem, cause the washer would agitate even with a broken lid switch, but it would not spin..since the machine make any kind of different sound when you run it Like a high pitch squeal or grinding noise?
check the lid switch see if it's not broke... wasn't the lid switch, but I got to thinking it will agitate at the first part of the wash cycle, but when it goes into the slower speed wash, if your lid switch is broke, then it won't agitate or spin...
Posted on Feb 10, 2009
  • Starnley Johnwells
    Starnley Johnwells Feb 10, 2009
    Most likely the problem with your washer is a bad lid switch Open the control panel, unplug the lid switch connector and check
    continuity. With the lid closed the lid switch should be closed.
    Replace if it's open.hope this helps pls appreciate by rating as fixyaa
LG direct drive washer makes a grinding noise with power and moving it by hand. how much to repair?
sounds like the bearings have worn out. probably expensive, requires the machine to be dismantled almost completely.
Nov 12, 2013 | LG Washing Machines
Wont spin and makes alot of noise
You could check if its drum by removing the belt turn drum by hand if its okay no noise check motor pulley ....is motor ok ?
Nov 17, 2009 | GE Profile Prodigy WPSE4200A
Washer has started making a heck of racket during the drain/spin cycle. It's not consistant. Two loads may go thru ok no noise. A third load and it will make a very loud grinding chain like noise.
Grinding noises are most often the result of a failing water pump. The noise can increase during the spin\drain cycle due to the added load on the pump. Although less likely it could also be the drive belt rubbing on something or a pulley bearing failing. If you are able to locate and remove the drive belt, you should be able to turn the water pump pulley by hand. If the pump does not turn smoothly it is bad.
Aug 06, 2009 | Maytag Washing Machines
Admiral aav-1 makes loud grinding will not spin or drain
Hi, the drain pump impeller is damaged. you will need to replace the entire pump(drain) in this case.
You will hear this noise when the impeller become separated from the actual drive stud or, shaft.
Jul 13, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Wont agitate
My washing machine fills up fine, but then when its time to start aggitating and spin's it makes like a metal on plastic grinding noise, We would like to try to fix it ourself but have no idea which part it is. Could you please HELP?
Nov 14, 2008 | Admiral AW22 Top Load Washer
Washing machine problems
Sounds like the bearings in the drum may have failed, was it vibrating irratic on full spin before it stopped?
Mar 07, 2008 | Washing Machines
Washing Machines Logo
154 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
