Question about Whirlpool LER4634J Electric Dryer
My Dryer has stop producing heat
Whirlpool LER4634JQ0
My dryer was taking ages to dry cloths, now it has stopped producing any heat. I asume it is the thermostat, but I can't find where the thermosata is located.
Can someone help.
  • 547 Answers
Hi mark it the heating coil in the back of the dryer
Posted on Feb 11, 2009
Whirlpool gas dryer doesn't dry
Make sure vent hose in back of dryer is not blocked or stopped up.
Mar 16, 2014 | Whirlpool WGD94HEXR Duet Steam Dryer gas
Dryer takes twice as long to dry clothes.
Did you check the outside vent? Those get clogged as well.
Oct 27, 2012 | Whirlpool LER7646J Dryer
I have a Whirlpool dryer model LER4634JQ0. It now takes many cycles to dry the clothers. I checked the vent coming out, it is not clogged. I can reach in and feel a little fan motor, which I assume...
your vent line from the wall to the outside of the house can be clogged
or your you high heat coil is burned out and just the low heat coil is working, when you switch to high, both coils work. or you have a one coil system and the heat selector maybe defective
Please rate/vote the response Thanks
Dec 20, 2010 | Whirlpool Dryers
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
MODEL # LER4634JQ0 - the dryer spins properly without noise but the heat is not enough to dry clothes, takes forever.
You may want to try to reset the breaker.
I have a similar prob with my dryer. Something with the unit messes with the current enought to drop voltage enough to stop the heater but not the motor and it does not completely trip the breaker.
Cycle the breaker off, wait a minute and reset the breaker. That should work.
If not, it is probably the heating element.
Hope this helps and saves you money from (hopefully) unnecessary repairs.
If so, please rate me.
Sep 14, 2009 | Dryers
Clothes dryer will not start
sounds as if your motor has tightened-up or seized from heat and age bearing failure which it would cause excessive current draw at start-up if you can access the motor unplug unit then remove belt and spin motor pulley is should turn freely and coast to a stop if it seems tight the bearings are dried out
Jul 12, 2009 | Whirlpool Dryers
It takes my whirlpool dryer three or four cycles to dry clothes
Kenmore Dryers are almost all the same therefore am sending this;
How to Clean a Dryer Vent Video
Why is so inportant to clean the lint?
It was helpful?
May 15, 2009 | Whirlpool Dryers
Gas dryer does not provide heat or air
If you don't have heat the timer will not advance in auto dry. The first thing to check is the glow bar ignitor part number 279311.
Mar 30, 2009 | Whirlpool LGV4634JQ Gas Dryer
Whirpool dryer won't heat up
You need to replace the thermal fuse and the timer. A bad timer will over draw a thermal fuse and cause it to blow.
Please remember to unplug the dryer before servicing
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool ler4634jq0
The gas das't start tere for dryer goes for long time without drying the klotnes
Nov 06, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
625 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
