Question about Epson Stylus CX4800 All-In-One InkJet Printer
EPSON STYLUS CX4800
When I click the scanner icon nothing happens. It will not start
  • 1 more comment
  • mackeentouch Mar 27, 2009
    i can print but scan, do i have to install another driver for it?
    i'm a mac user
  • Stephen Siasico May 11, 2010
    scanner icon on the computer or on the printer? what is your OS (operating system) Windows or Mac?
  • dirinda89
    dirinda89 May 11, 2010
    Go to control panel, installed printers. Do you see it listed there?
  • 25 Answers
You need to download a "Twain Driver and Epson Scan Utility" from
the Epson Website.
But before you start downloading the Twain Driver we need to delete
the previously installed driver in your computer.
1.) Click and open the MAC or Apple Hard drive / Application and trash Epson Scan and Epson Scanner Monitor ( drag it to your trash )
2.) MAC hard drive / Library / Image Capture / Twain Data Source., we need to trash ( *.ds file )
3.) MAC hard drive / Library / Application Support., trash the Epson Scanner Module
4.) Disconnect the connection ( USB ) between the printer and your MAC.
5. ) Empty your Trash bin and restart your MAC
After the restart we can now download and install the Twain driver to your MAC.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58606&prodoid=56291067&infoType=Downloads&platform=Macintosh
After the installation try to launch Epson Scan under Application
Posted on Apr 09, 2009
SOURCE:
How do you replace an ink cartridge in the Epson Stylus CX4800 printer?
Hello, to shorten the steps I've included these links for your printer manual
Epson Stylus CX4800 Quick reference
Epson Stylus CX4800 Product info on the bookmarks, go to replacing ink catriges
I hope this helps
Jul 11, 2011 | Computers & Internet
Is the Epson Stulus CX4800 a scanner, printer, copier?
Epson Stylus CX4800, is a all in printer. It can scan,copy and print. Thank You.
Jun 17, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Can't locate how to clean print heads on my Epson Stylus CX 4800
Hello, to clean click on start, then click on printer & faxes, then double click the icon Epson CX4800, until it opens. You will see the printing que. Click on printing preferences then select the maintenance tab.
See below., and hope it helps.
Good Luck :0) HERE ARE 2 DIAGRAMS.
Nov 06, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Scanning
You received a cd for the all in one. After Installing the CX4800, you should see an Epson Scan Icon on your desktop. Double click it open, then you should see this. Click on Scan and there you go.
Good Luck.
Oct 27, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Need Scanner Icon
Goto C:\Program Files\Epson
Look for the Epson .exe file, right mouse click on it and select Send To> Desktop (create shortcut).
Hope this help.
Feb 13, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Lost CD software to epson stylus CX4800
u can download the epson stylus cx4800 printer    from the link below..
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=58606&prodoid=56291067&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=18&y=5
there u see many links for several softwares and drivers,choose the appropriate,,,,,,,
if this solution helped or not helped?  pls reply...
Jan 24, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Lost manual for cx4800- how do you clean heads- images are banding
If you have a printer icon in the quick-start portion of the task bar (lower left corner of the screen), Mose over it and see if it's for the Epson 4800; if so, right click the icon and you'll see the maintennce services listed
Aug 18, 2008 | Epson Stylus CX4800 All-In-One InkJet...
One possible solution that we can advice is to do a complete trash & reinstallation of printer driver as well as the scanner driver.
For iMac with Leopard, there is a big possibility that the printer driver is not the correct epson series printer driver that's why you can't ink levels is unavailable. Just to set an expectation, printer driver for CX4800 is pre-installed as resident driver in Leopard. Please try to the following to solve that issue:
Determine Which Driver is Currently Being Used
1. Click on the Apple icon in the upper left corner of the Finder and open System Preferences.
2. In the System Preferences window, click on Print & Fax.
3. In the list of printers on the left side of the Print & Fax window, click once on your Epson printer to select it.
4. Check the name of the driver being used; it is displayed in the center of the Print & Fax window next to “Kind”.
5. If the driver name displayed next to “Kind” is Gutenprint, the incorrect driver is being used. Follow the steps in the next section to select the correct driver.
Selecting the Correct Driver
1. Turn off the printer.
2. Delete the print queue and remove the printer from Print & Fax by clicking on the minus (-) button under the list of printers. Click OK to confirm the removal.
3. Click on the Apple icon in the upper left corner of the Finder and open System Preferences.
4. In the System Preferences window, click on Print & Fax.
5. Turn on the printer. The system should add the printer automatically.
6. If the system does not add the printer or if it adds it using the Gutenprint driver, contact Apple for assistance. You may need to reinstall the Epson drivers provided with Leopard.
NOTE: To check ink levels, click the Utility button, then click EPSON StatusMonitor. The Supply Levels button will not show remaining ink levels for your Epson printer.
Dec 16, 2007 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus CX4800 All-In-One InkJet Printer Logo
978 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
