Question about SanDisk Sansa e260 MP3 Player
It will not boot. It says that it cannot load.
K. So i was formatting it like I was told to but now, when it goes to start up it reads "Load main image failed. Switch to recovery mode". What have i done? :( I can access Recovery mode, and it still shows up as a 16MB thing in My Computer but I cannot gain access to the main page where all my music is. Is there anyway i can fix this?
  • em_l_funston Feb 10, 2009
    umm. thanks a lot for trying but that meant absolutely nothing to me. Im still as lost as before. (:
Better to unpartition all drives and again partition and then install....now it wont saw ......go to recovery....
Posted on Feb 10, 2009
I can't get passed the main screen when I turn my lenovo desktop all in one on. It goes to the screen that has a 75max so easy so simple how do I get passed it
Hi
Sounds like your boot up files are corrupt so it cant read any further then the screen.
you need the windows start up disc to match the windows installed on your laptop/pc
load it and when it asks you to install or repair select repair and follow the prompts to reinstatement the boot up files or master boot record MBR
cheers
Mar 09, 2015 | Lenovo Computers & Internet
Garmin 1450 LMT Not loading past Garmin logo
The USB will not be recognized until the unit boots to the main screen. This is where the subroutine scans for the insertion of the USB cable. In order to fix this problem, you have to access the flash drive directly, bypassing the standard boot-up. The drive must be properly formatted, otherwise the Nuvi can not write to the flash drive on boot-up and will either go into a boot-up loop or stay stuck at the Garmin logo. Accessing the flash drive must be accomplished in pre-boot mode. there are several programs out there that can do this. Once the drive is properly formatted, the unit will boot, create the Garmin folder, write a few other folders and files and boot-to the main menu. Now, you can connect the cable as usual and start copying over your backed up files. I've repaired this issue many times.
More info can be found here:
http://www.sharc.net/gps_bootup_repair.htm
Aug 29, 2013 | Garmin GPS
Cant flash bios a1410n
Try simple first. When booting, AND BEFORE the XP logo, press f8 repeatedly until you see the boot options menu. If you miss it, you will see the xp loading logo, if so, restart and try again. From the boot menu, try the "boot with last known good configuration" option. If that doesn't fix it, re-boot, f8, and try the "safe mode" option. If it boots with any of these methods, do a full shut down and re-start again normally.
If that doesn't get it to boot normally, I would do the following. (I would, but you should only try this if you have a good understanding of windows and needed programs installing, ram replacement, hard drive repair/replacement and internal computer wiring)
Now, if your computer worked fine, then suddenly started this loop, I dont think it a bios problem. I expect you might have a hardware problem. Did you change any hardware very recently? Sometimes that stops windows from loading. Or, you could try changing the ram and retry, could be bad ram. But I think it is a hard drive issue. I think you will have to reload windows and/or replace the hard drive.
To safeguard your info, you should replace the main hard drive with another drive, load windows fully on it, then add the original drive back in as a slave/secondary drive, and retreive your personal info and files from it. Your needed programs will have to be re-installed on the newer windows drive. When you get all your files copied over (use copy and paste, not cut and paste), you can format the old drive and use it as storage, or just format and keep for the next time, or sell it. I would also run a "drive fitness program" to test it for bad sectors.
Or, if you dont need anything from your windows, you could format and install from the xp install cd. If it loads and runs, the drive is probably ok (I would still test it for bad sectors), or, if it cant load because of errors, the drive is probably bad. Retry with a new drive.
Jul 16, 2013 | HP Pavilion a1410n (ER890AA) PC Desktop
I have a Emachine T5212 and im trying to reformat my hard drive but my internal dvd drive is not recognized.I brought an external dvd drive,but everytime i try to erase my hard drive it tries to load from...
First you need to have media ready to install once format is compelte.
You can not format a drive you are currently using an operating system unless you run the operating system setup disc in which case you would be booting and running from cd once you start reloading you main drive.
So if you are loading windows .
Review steps below if when you boot you do not have option to select boot device
Boot you laptop / pc and get into the BIOS
<normally f2 or f8 , f12 depending on system.>
Change the BOOT order to cdrom as primary \ you may see the device as USB CD/DVD rom with the actual name of brand there.
Save and exit
Have operating system in cd/dvd rom attached to device
Once it starts to load you will see BRIEFLY in the upper left corner PRESS ANY KEY TO LOAD FROM CD ROM or something similar... stop reading this and press a key ........
From there it should prompt you for setting up a new os, I prefer linux myself but in windows or linux in the setup process you have the option of just loading the operating systems or DELETING THE PARTITIONS and FORMATTING the drive, therefore wiping i .
NOTE: THIS IS NOT WIPING YOUR DATA, if you are trying to hide something, wipe from your drive past **** you never wanna share with anyone again..... repost under how do i wipe my hard drive clean .. its a completely different story .. not hard but different.
Jul 24, 2011 | Computers & Internet
When i put it asked for format, then told me (wondows was unable to complete the format) plz how can solve the problem
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to
cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
or if you are trying to format a usb drive
insert your pen drive
click start click on my computer you should see your pen drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
???????????????????? hope this helps
Jan 22, 2011 | Computers & Internet
Trying to reformat and load my computer for a fresh start. When I reboot to load Windows the screen goes to a small box saying "input not supported". How do I fix this???
visit my site
www.sureshayyar.110mb.com
it has all details on how to reset to facotry setting.....format and reinstall Win etc
you may have to make changes to BIOS to boot from CDROM drive....as a 1st Boot device....
press F1, F2, Del, Esc, F12 key other one that brings up the BIOS screen there look for Boot seq....disable HDD and floppy, enable CD ROM drive and make that 1st boot drive....you need to change it back to HDD the1st boot device later after loading Win....
once you boot from CDROM then follow inst from my site to format HD....and install XP
all the best
pls feedback and comment on how u did
Nov 07, 2010 | Acer AL1916W 19" LCD Monitor
''ERROR ON LOADING THE OPERATING SYSTEM''
ur boot file are corrupt...
or ur main OS files that load Win is corrupt....
re-format and load OS
u need a Win OS disk to install.
Dec 28, 2009 | Computers & Internet
Hi, my Philips DVDR3455H/75 DVD/Hard disk doesnt
THE DVDR3455H HAS A COMMON PROBLEM AFTER A FEW YEARS THE HARD DRIVE GO BAD, IT WONT BOOT UP
99% OF THE PROBLEM WITH THE PHILIPS DVDR3455 IS THE HARD DRIVE.
IT WILL KEEPING REEBOOT OR IT WILL HANG ON THE PHILIPS LOGO.
IT IS NOT A FIRMWARE PROBLEM IT AHARD DRIVE PROBLEM.
ONE THING YOU SHOULD KNOW, IF THE HARD DRIVE IS BAD YOU WILL NOT BE ABLE TO UPGRADE THE FIRMWARE IT WILL NOT READ THE CD OR DVD DISK.
AT THIS POINT IT NOT LOOKING FOR A FIRMWARW DISK BUT IT LOOKING FOR THE BOOT UP SOFTWARE.
OR THE LOAD CD WHAT PHILIPS CALL IT.
SOLUTION REPLACE THE HARD DRIVE WITH THE LOAD SOFTWARE INSTALL ON IT.
THE HARD DRIVE IS SOLD ON EBAY JUST LOOK FOR DVDR3455H YOU WILL FIN NEW DRIVE READY TO INSTALL THAT WILL FIX YOUR PROBLEM.
Nov 03, 2009 | Philips DVDR3455H/37B
Computer will not boot
Chances are if you load the windows CD into the CD player it wil boot to the CD. You can opt to repair the current version of windows without a format. You will not loose your data.
Jan 02, 2008 | Compaq Presario 5000 PC Desktop
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
