Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool will not spin out water
Whirlpool washer will not spin out water. Top load washer spins...but very little if any water goes out through the drain pipe. I have verified the pipe is clear...but it seems not to be making it that far. What could be stopping it
  • 1 more comment
  • Titoes Feb 10, 2009
    Thanks... I have taken the back off...but do not know where to check for the pump or clothing. Any ideas or would it be hidden?
  • Titoes Feb 11, 2009
    I have already verified that there is nothing in the tube. I am tryinngg to figure out where I can see if there is something else is clogged elsewhere...Thank you so much for your time.
  • Anonymous Feb 13, 2009
    WILL SPIN SLOWLY. NOT AT ALL FAST ENOUGH TO GET OUT WATER.
    COULD THE CYCLE SWITCH CAUSE THIS
    Scholar:
  • 105 Answers
With it spinining fully it may be as simple as a sock or undergarment in the pump, if it is not spining fully the motor coupler is probably in need of replacement
Posted on Feb 10, 2009
  • Cary Crook Feb 10, 2009
    Where the drain hose comes in there is usually a wire clip holding the hose to the discharge side of the pump put a towel down and un clamp and look in or feel
  • Cary Crook Feb 11, 2009
    After making some phone calls to Whirlpool they have sumized that they are having clogging in the sump so it may be virtually invisible at first and second glances, tho not happy with thier answer, on them unlike other and like some manufacturers it is not resolved without cost to you. So it would seem that the pump/sump maybe the issue with a design flaw.
The tub continues to go off balance in spin cycle. Starts out smooth then starts to wobble terribly til the UL shows and shuts down. Support rods are good
There is a little device inside the washer that allows the agitator to spin independent of the drum. If this gets stuck, the washer will try to spin the whole drum instead of just the agitator. This will cause the washer to think the load is too large or out of balance, causing the error code. On some Whirlpools this device is just a washer.
Jan 07, 2015 | Whirlpool WTW8800YC 4.6 cu. ft. Cabrio...
This washer goes to the spin cycle and just buzzed will not send water out
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool Duet Sport--won't completely spin out, leaves water in the tub. I cleaned out the drain filter, it kind of works for 1 load then goes back to not spinning out completely.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Dec 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer wont spin during spin cycle everything else appears ok.
Machine not spinning....check]
1..all water gone clean pump trap and check blocked drain
2....somehting stopping drum spin drum freely by hand.
3....too much soap use low suds soap and very little of it.
4....motor brushes wearing out...call for service for this one.
Good luck
T
Aug 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSR8444 washer, timer works but no spin or aggitation
Your problem is a broken drive coupling between the motor and transmission. Replace the drive coupling.
Jul 27, 2009 | Washing Machines
Washer whining when washing and spinning leaving brown stains on clothes
Turn water off. Remove hoses and clean the rust out of the strainers at hose end. If they are clogged they will sound funny when water goes through them.
May 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine does go thru spin cycle or drain water.
If the washer does not spin, take off the rubber bumbers inculding the little washers attached, inside the lid. It lowers the lid, which takes care of the problem. I had the same problem. Not anymore! Trust me, if nothing is wrong with any other part of the washer, this will work.
Apr 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool lhw0050pq washer will not spin
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
Apr 25, 2007 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
85 people viewed this question
Dan Webster
Dan Webster
Sal De
