Question about VeriFone Omni 3700
I have verifone vx510
My verifone started send me flasher ***tamper **** at push any botton the next display send download neede no *go variable and no continued
i not have manual, any solution ??
  • ibrahimh Mar 05, 2009
    i have verifone vx510 problem , when the terminal swiched on flash tamper appears on the screen
Well right now the credit card terminal has no programming software. What you need to do is get in contact with your merchant services number, most have a sticker on the terminal, or there is a 1800 number depending who processes your transactions. You will have to them put in a request to build a new file with your merchant number that is assigned to your business. After that file build is done you will need to download it on a dedicated analog phone line. The 1800 number can instruct you how to complete this process.
Posted on Feb 27, 2010
  • 1,602 Answers
GO ON LINE
VERIFONE OMNI 3700 SERVICE MANUAL
OR
VERFONE VX510 SERVICE MANUAL DRIVERS
ENTER
OR
VERFONE 3700 VX510 FLASHING LIGHTS
ENTER
ROD
Posted on Feb 10, 2009
  • Ronald Erickson Nov 06, 2011
    TAMPER is at times caused by the internal battery. Order TAMPER removal at CardSystemTechnologies.com
    New Friend:
  • 55 Answers
This is a common problem. To clear "tamper" needs battery change and download to clear. Most can be resolved via sending to repair center. Call Frank @ 775-338-6634
Posted on Apr 26, 2014
Tamper means that Verifone's battery is off, in this case keys fall down. You need to send your POS in service center and change its battery. After repairing its better to download new OS, profile and keys. And all will be OK.
Posted on Aug 28, 2012
When i try to print the recipts, they come up blank
Posted on May 05, 2011
  • 42 Answers
Hi,your pos device is not supported digital line so you need arrange analog line for you device.
psoftware109@gmail.com
Posted on Mar 23, 2011
Why is screen indicating download is needed?
PDF]Verifone VX510 User Guide - Moneris Solutions
www.monerisusa.com/support/~/media/Files/.../Vx510_qrg.ashx
VeriFone Vx510 with SoftPay. Quick Reference ... their PIN, and encourage them to protect their PIN. ERROR ... the terminal screen. ... PINpad display is blank: See "PIN Pad Error" ... the ALPHA key (repeatedly if necessary until the desired.
[PDF]Vx 520 - User Guide - Verifone Support Portal
Dec 19, 2015 | VeriFone VX510
VeriFone 510 tampered
I wish I could tell you that you can get your machine repaired in Winnipeg, but I do not know a repair facility there. If you would like to discuss this with me call Frank @ 775-338-6634
Jul 07, 2014 | VeriFone VX510
What does TAMPER
"TAMPER" displays on Vx510, Vx610, or Vx670 terminal Problem/Task "TAMPER" shows on Vx510, Vx610, or Vx670 terminal Environment VeriFone Connect Any Verifone manufactured device that has the capability to contain it's own internal encryption (including Vx510, Vx610, or Vx670 terminal) Cause The message: "Tamper" will appear on the Vx510, Vx610, or Vx670 terminal if it is physically opened, damaged, or if it is jarred enough to flip and enable the internal tamper 'switch'. The reason for this is to ensure any sensitive data that passes through the terminal during a credit card transaction is not intercepted or compromised. Customer Solution/Action 1.
Contact repair facility for repair/replacement of the affected device
If you still needs help call us at (775)358-2922 ask for Randy http://freshpoint.org
Sep 29, 2012 | VeriFone Omni 3700
Download needed no*Go variable in monitor verifone vx510
what you need to do is call your service provider ( bank ) and have them download the program in to the unit what the unit is telling you is the there is no files in the memory
Nov 13, 2011 | VeriFone VX510
How can we resolve bad rtc chip error in verifone vx510?
bad RTC can be repaired. the machine is equipped with multiple sensors inside. if one of them goes bad, or the Battery is dead tampering or bad RTC will show this can be fix by replacing the sensor and or the battery if you need this to be done call me @ (775) 358-2922 hope this help : - )
Sep 13, 2011 | VeriFone VX510
Screen display: verifone 05150 qa0010a1 07/23/2007 verix **tamper** copyright 1997-2007 verifone allrights reserved
the sensors inside are bad or bad plastic casing. call (775)358-2922 look for randy and maybe we can help you. thanks
Aug 01, 2011 | VeriFone VX510
I have two verifone vx510 cc machines. 1st) Need
May 31, 2011 | VeriFone VX510
TAMPER P.O.S VX 510, COMO RESOLVER
which types of Vx510 Tamper error showing on screen?and how many Vx terminals are in problems?
Jan 19, 2011 | VeriFone VX510
I have a VeriFone VX510 and it says "Bad RTC Chip
Nov 18, 2010 | VeriFone VX510
How can I solve the problem **tamper** in Verifone Vx510?
Verifone has a built in safe-guard against tampering. There are certain things that can cause the new Vx Series of terminals to display this error - from someone actually tampering with the terminal, to a physical drop or jarring of the terminal.
I hate to be the bearer of bad news, but the ONLY way for a terminal to be unlocked when displaying "Tamper" is to send it into an authorized service center. I have many of these devices in the field for customers and have dealt with this issue a few times - unfortunately, that's the only way Verifone set it up for this error to be resolved.
Sorry for the bad news, but hope it helped!
Sep 03, 2009 | VeriFone Omni 3700
Retail Supplies Logo
3,811 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
