I think I ruined the Panasonic roller Item No. PFDS1009Z to the Panasonic High Speed Laser Fax and Copier. So I ordered a new one. Now I'm having difficulty replacing the old one with the new one. Can you help? Thanks. Kevin
  • kevinmorme97 Feb 10, 2009
    Can't get thew roller out of the fax/copier machine.
    Kevin
    Sergeant:
  • 250 Answers
To replace the roller you will have to open the printer/copier.as do you have proper tools to open it and it has internal clips and locks in the left and right side of the flaps which has to be removed very carefully.as the locks of plastic are very delicate to be removed very carefully.
Posted on Feb 10, 2009
    Master:
  • 848 Answers
* Turn the fax around so the front is facing you; open the front doors and remove the print cartridge.
* Using the transfer roller removal tool, pry up on the roller using the frame as a pivot point. Discard the old roller.
* Do not touch the new transfer roller with your bare hands; oils from skin on the roller can cause print quality defects.
* Leave the protective wrapper on the transfer roller and insert the right end into the bearing on the right side. Then snap the left end of the roller into position.
* Remove the protective wrapper from the roller and discard.
    Master:
  • 474 Answers
Whatis the exact Make and Model Please, this way I can locate the repair manual for you.
I can also assit you better knowing what it looks like.
It is a Roller and not a fuser right?
ALso, what is actually wrong with it or whatis happening, the more details the better. Thanks
  • 217 Answers
Kindly provide the model no of the fax/copier so that I can help you better
  • 13,433 Answers
Hi
I would suggest buying a service manual for your machine.
I can have a look around and see if I can get you one if you tell me the model of your Panasonic fax machine.
all information you can provide will make it easyer for me to help you to solve your problem.
  • 679 Answers
What is the problem in replacing, please explain?
Thanks
Our fax machine has been saying replace drum for a while and faxes have been getting darker and darker we cleaned it but now we can send but not receive what is the drum?
the drum is green roller in housing with toner, you should order the drum cartridge for your fax. With new drum you get the how to manual also. Follow the procedure.
NOTE THAT THE DRUM UNIT IS SEPARATE FROM TONER UNIT.
Hope that helps!
Oct 19, 2010 | Panasonic Panafax UF-490 Plain Paper Laser...
I have a panafax UF-755E will not accept multiple pages. I have to feed them one at a time? Any suggestions on how to fix this problem?
Pana fax uses a thin peice of rubber to prevent multiple sheets from feeding these wear out.
You can try opening the part where you feed your origials and clean the rubber roller and pad with soap and water and a damp cloth
or
I remember having some luck flipping the ruber pad over
or you can order a replacement here....2nd item down
http://www.worldoffax.com/PANASONIC%20UF%20755E.htm
Apr 14, 2010 | Panasonic Panafax UF-885 Plain Paper Laser...
Rollers will not grab the paper through to fax or copy. Please help!
You need to go and order the bottle called "roller rejuvination solution) from the website fixyourownprinter.com.
Cost under $20.00 and all you need to do is dab a qtip some of the solution and spread the solution from the qtip onto all the roller pin paper pickups.
Wait 10 minutes for it to dry and then test the fax again. It will now pick up single sheets afterwards.
Mar 19, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
How can I reset Replace Drum on the Panasonic KX-FL511 Fax?
First of you will have to purcahse a Panasonic Drum Unit for you fax.
Inside the drum unit yu will have detailed instructions, you will open up the fax in the front take aout the old and install the new.
Here is a link to a helpful guild
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Fax/Copier/How-To-Guides/model.KX-FL511.H#ts
Good luck
Nov 05, 2009 | Panasonic KX-FL541 Plain Paper Laser Fax
Panasonic KX-FL521 Fax Laser Copier, New Toner
This is usually an indication that the toner cartridge wasn't shaken from side to side to distribute the toner evenly.  If this was done, the cause is probably a dirty drum.  Remove the toner cartridge and clean the drum. Either of these two solutions should solve your problem.  Best of luck.
Greg
Jul 09, 2009 | Panasonic Office Equipment & Supplies
How do you adjust paper feed on a panasonic kx-fl511fax/copier
One of two things is happening ok maybe three. If the machine thinks the size of the paper is not what u are using this could happen. Try:
http://pdf.textfiles.com/manuals/FAXMACHINES/Panasonic%20KX-FL511%20Laser%20Fax%20Machine.pdf
For any adjustment you could make.
The second is the paper is getting picked up a little late. The machine knows it did not print the entire page and finishes the job. Try cleaning the pick op roller.
The third is the page being sent to you is to long. This would likely be from one location only. There machine could be slipping when scanning and "extending" the page it is trying to send.
Hope this helps
Mar 10, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Problem with new calls
Unplug and replug power cord.
Aug 18, 2008 | Office Equipment & Supplies
Fax rollers
what kind of roller do you want to install...in feeding unit or in fuser unit?
Dec 17, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
20 people viewed this question
jasbo
jasbo
