Question about HP Designjet 820 Printer
Repair manual for designjet 820
Would like to have repair manul for designjet 820. No power, no lcd display. Could be main board or power supply.
  • 214 Answers
Try this link. I clicked the download now button & it's active.
http://www.eserviceinfo.com/downloadsm/17339/HP_DesignJets%20500.html
If this helps you plz rate this for me. Thank you kindly.
Posted on Feb 10, 2009
  • 1,602 Answers
GO ON LINE AND DO THE FOLLOWING TYPE
HP DESIGNJET 820 PRINTER SERVICE MANAUL DRIVERS
ENTER
WWW.HP.COM/DESIGNJET
ENTER
ROD
Tv is dim and can't brighten
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 28, 2017 | Televison & Video
46RV535U 46 in. HDTV LCD TV where is the fuse
There are several fuses on the power supply board.
Usually the one that fails is not the main AC line fuse (which is close to the AC line input), but the PFC fuse located, you guessed it, next to the PFC regulator IC on the board.
When the PFC fuse is blown (measuring open) you also need to replace the PFC IC and possibly other components on the board. Most of the time the PFC is sufficient though.
Here's a link for repair service for the board:
http://www.coppelltvrepair.com/p/751/toshiba-46rv535u-power-supply-board-repair-service-for-dead-refusing-to-power-tv-or-faint-display-problem
Also search there for the TV model, we may have repair kits or exchange services available!
Hope this helps!
Jul 30, 2012 | Toshiba Regza 46RV535U 46 in. LCD HDTV
Hp designjet 5500 power supply error 1
Possible that the main capacitor has leaked and so there is drop in the +B or the sub voltages. It is important to check the rail votages to the main board , remove SMPS unit an check.
see link below for tips on SMPS power supply
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
May 12, 2011 | HP DesignJet 5500PS InkJet Printer
I HAVE A NEOVO E-19A MONITOR. ON BOOT UP SCREEN GOES BLANK AFTER ABOUT 5 SECS. TURNING OFF THE MONITOR THEN TURNING BACK ON BRINGS THE SCREEN ON FOR APPROX 5 SECS BEFORE GOING BLANK AGAIN. THIS IS REPEATED...
http://www.devicemanuals.com/guide/LCD/AG%20Neovo/AG-Neovo-S-19A-LCD-Display-English-Owner's-Manual-T1RjMU9Uaz.html
dlc.sun.com/pdf/820-0119-10/820-0119-10.pdf
http://www.scribd.com/doc/3082274/AOC-LCD-Monitor-786LS-Service-Manual
Use these training manuals, to troubleshoot and sort your issue out.
Above is a user manual, and a service manual, in the service manual, are the troubleshooting steps to perform to isolate the problem, and hopefully repair.
May 25, 2010 | Neovo AG 17" LCD Monitor
Sanyo DP52449, tv getting power but no display
When DP52449 (chassis 01 - that is important!) does not power on and the front LED flashes every 15-20 seconds you have a faulty main board, which you need to replace or get serviced.
We presently do not offer replacement boards, but we do offer repair services for them at
http://www.coppelltvrepair.com/p/59/sanyo-dp52449-p52449-01-main-board-n7ke-repair-service
You may also be curious to read the article we wrote back in July 2012 on a problem that sounds exactly like yours and which lead to the service offerring:
http://blog.coppelltvrepair.com/2012/07/sanyo-dp47460-dp42840-dp46819-and.html
Hope this helps!
Feb 20, 2010 | Sanyo DP32746 32 in. LCD Television
Won't power up. Press power button, turns green then orange.
Good day sir/maam, Hi, If the LCD is under warranty, use it, they will replace the LCD monitor for free. If not, you may need spend for a Power supply board, to repair one.
There are two boards usually found on an LCD monitor, one main board that controls the LCD screen, back light, inverter, controls and sound. the second board is the power supply board, which accepts mains voltages 90v-240v AC and convert them to DC to power the entire monitor.
If however you may bring it to a repair shop or dealer, they will replace the power board, and there you go. the monitor is done.
Nov 24, 2009 | BenQ FP737S-D 17" LCD Monitor
LED POWER ONLY LIFE, SCREEN DISPLAY DARKNESS
theres only one solution to the problem you have to replace the whole power supply board .its easier to replace them than finding and soldiering the defective parts like the capacitor on the board .u can just replace the power supply board if u think the power has a problem. if it doesnt work then u have to replace also the main board or the board connecting the rgb cable.its more expensive to replace the board but its worth it. ur lcd will work better and its easy to put them on the lcd casing .
Mar 01, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Designjet 110 plus not turn on
do you change formater board ?or try use firmware utilit you can find it here
http://h10088.www1.hp.com/cda/gap/display/main/gap_home.jsp?cp=1_4011_100&zn=gap
Sep 22, 2008 | HP Designjet 110plus nr InkJet Printer
204 people viewed this question
Seeker5211
Seeker5211
