Question about NEC VT47 Multimedia Projector
Hd flashes every few minutes
All the other ports on the projector work fine but when i try to use the HD setting every few minutes the screen will flash. i have looked for a reset button but have been unable to find one. can anyone help.Oley D8H projector
  • 1,602 Answers
THE DEVICE THAT HELPS THE SYSTEM FROM OVERHEADING MAY HAVE BURNED OUT IT IS SOME TYPE OF TRANSISTOR THAT HAS PHOTO CELLS IN THE COMPONET TO KEEP THE SYSEM OPERATING PROPERLY.
YOU CAN GO ON LINE AND TYPE THE FOLLOW INFORMATION IN THE ADDRESS BAR
NEC VT47 MULTIMEDIA PROJECTOR LIGHT FLASHING
ENTER
THIS IS TO SEE IF ANYONE ELSE IS HAVING THE SAME PROBLEMS AS YOU AND WHAT THEY HAD TO DO TO FIX THE PROBLEMS.
ROD GANDY
Posted on Feb 10, 2009
Why when I use the inbuilt projector of the Sony Camcorder HDR-PJ240E with an external device,the projected screen becomes plain blue after a few minutes?
This maybe due to the external device not receiving signal to keep the display on the screen or a cable that isn't quite right. Many HD cables can cause this issue due to a security feature built into it to prevent streaming copies which helps prevent piracy. If you are using say an HDMI cable, try a different one.
Nov 26, 2014 | Sony HDR-PJ240E/B Full HD Handycam...
WHY DOES MY HD OPTOMA DLP 70 TURN OFF AFTER FEW MINUTES?
If you have recently replaced the bulb you may need to reset the lamp counter in the projector menu.
If you have not replaced the bulb, the projector may be shutting down due to over-heating. Check that the projector is clear of as much dust and debris as possible.
Sep 03, 2014 | Optoma Hd70 Dlp Hd High Definition 720p...
Denon AVR-4806 HDMI problem
Check which port you have the HDMI cable connected to, then go into the menu on the TV, look for it on screen and Enable it .
Good luck
Nov 16, 2013 | Denon AVR-4800 Receiver
Screen locking
it probably needs to be reset by taking the battery out for a few minutes or you can try checking to see if there are any software updates for the phone
Mar 14, 2013 | Motorola Mobility DROID RAZR MAXX HD
Dear, i would like to know how and what cable i need to connect my laoptop to a home cinema 705 HD projector
Hello Jerrel43, Here is a quick overview: 1. You must first learn what port your laptop offers for video output. Your laptop could have one or several of the following: VGA (sometimes referred to as RGB), DVI, DisplayPort, S-Video, or HDMI. The following link offers pictures of each. http://hookpctotv.com/laptop-hd Keep in mind that DVI and HDMI offer the highest quality picture, so if your laptop has one of these, use them. 2. You must learn what port your projector offers for video input. After doing a quick search, it seems that your prjector offers VGA, S-Video, as well as HDMI. 3. Plug your projector into the computer with the port available on your laptop. Power on your projector and laptop. 4. Make sure your operating system is "outputting" (sending signal to) the video signal to the projector. This can be done in a few different ways (and varies according to which operating system your laptop is using). A) If you are using a Windows XP laptop, right-click anywhere on the desktop and choose the "properties" button. Click on the settings tab at the top right of the window that opens. Click on the blue box with the number 2 and then click the box below that says "extend my windows desktop to this monitor." At this point you should see and extension of your desktop background being shown by the projector. Just drag any window you would like off of the right side of your laptop monitor and it will show up on your projector.
Feb 27, 2011 | Epson PowerLite Home Cinema 705 HD LCD...
The HDMI port doesn't have a picture. I tried my PS3 and my HD DVR, which both used to work fine.
Depending on the Version HDMI cable you using this may not work.
some units use a lower bandwith cable such as 1.0, 1.2 ect ect
Yes this does make a diffrence.
Let me know if you have any questions.
Aug 31, 2010 | InFocus IN72 Multimedia Projector
Can i set up an xbox 360 on an hp mp3135 multimedia projector
if your xbox has the hdmi port, you need a hdmi to m1 cable. otherwise, you'd need the hd av to m1 cable. there is no vga port on the projector.
Aug 18, 2009 | HP mp3135 Multimedia Projector
Elmo slide to video projector
check the resolution. is your tv hd? the projector may not be.
Aug 20, 2008 | Elmo Projectors TRS-35XG 35mm 80 Slides...
Maxtor OneTouch III Not Recognized by XP
sounds like the USb Port is burned out, might as well chuck it
Jan 09, 2008 | Maxtor OneTouch II external hard drive...
NEC VT47 Multimedia Projector Logo
107 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
