Question about HP 10bII Calculator
Addition of significant numbers
Hi, I would really appreciate if you could tell me how I may add more than 2 significant numbers which appearing on the screen of my calculator. Thanks
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
Press SHIFT DISP then a digit for the number of digits desired after the decimal point.
Posted on Sep 03, 2013
3 Suggested Answers
Dipu007
  • 2110 Answers
SOURCE: Addition Problem with HP 17BII
do a self test
1. Turn the calculator on.
2. If you have the optional infrared printer, turn it on. Certain diagnostic
information is printed during the test.
3. If possible, return to the MAIN menu (press @A).
4. To start the self-test, hold down C while you press the fifth menu
key from the left. Once the self-test has begun, do not press any keys
until you are ready to halt the test.
5. During the test, the calculator beeps periodically and displays various
patterns and characters. Watch for one of two messages that are
displayed before the test automatically repeats:
􀂄 If the calculator passes the self-test, the calculator displays
􀂄 If the calculator displays     followed by a five-digit number,
the calculator requires service.
6. To halt the self-test, hold down C while you press the third menu
key from the left. The calculator displays             . If you
press any other key instead, the test halts and the calculator displays
a     message. This results from an incorrect key being pressed,
and does not mean that the calculator requires service.
7. If the calculator failed the self-test, repeat steps 4 through 6 to verify
the results. If you do not have a printer, write down the messages that
are displayed in step 5.
Posted on Jan 01, 2009
  • 102366 Answers
SOURCE: when i turned on my calculator and began typing
Adjust the screen contrast. Turn the calculator on. Press and release the 2nd key, then press and hold the up-arrow key until the numbers darken. If you go too far, repeat the process with the 2nd and down-arrow keys.
Posted on Mar 22, 2011
How do I add more than one phone number and email address to existing contacts on my Samsung Galaxy J1 mini?
there is something in it called edit under options . or try writing down the name number(s) you want then delete the first entry and then add NEW CONTACT
Jun 24, 2016 | Samsung Cell Phones
How do I enter contacts and their phone numbers
Hi Joseph
Add a New Contact
Step 1 Touch the "Main Menu" soft key on your LG phone, or use the directional keys on your phone to select the "Main Menu" option.
Step 2 Touch or select the "Contacts" option to access a menu that allows you to add a new contact. Select the "New Contact" option using the soft key or directional keys. This action opens a blank contact template.
Step 3 Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Add the contact name in the same manner. Touch or select "Save" to complete the addition of the new contact.
Add a New Number to an Existing Contact
Step 1 Touch the "Main Menu" soft key, or use the directional keys on your phone to select the "Main Menu" option.
Step 2 Touch or select the "Contacts" option. Scroll through your contact list and select an existing contact to whom you want to add a number. Touch or select the "Edit" option.
Step 3 Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Edit the contact name in the same manner if desired. Touch or select "Save" to save the new number under the existing contact.
Apr 18, 2016 | LG Cell Phones
What is a sum.
The sum is the result of an addition.
When you add two numbers, the result you find is the sum of the two numbers.
15+10=25. The sum of 15 and 10 is 25.
Sep 22, 2014 | Office Equipment & Supplies
Phasor addition on classpad 330
Open up keyboard, go to 'cat' tab and scroll down to get ' <( ' symbol.
Input the magnitude followed by angle separated by a comma (E.g. <(15,10) ). The first element in the bracket is the magnitude of the phasor while the second element is the angle.
To do phasor addition simply add more of the '<(' symbol. (E.g. <(15,10) + <(12,5) is the addition of phasor_1 with magnitude 15 and angle 10 and phasor_2 with magnitude 12 and angle 5 ).
Note: the symbol ' <( ' appears at the very bottom of the list and the '<' symbol is actually more flat in appearance like how a normal phasor is usually represented.
Apr 09, 2014 | Casio ClassPad 330 Graphing Calculator
Addition meaning and properties
I suppose you have 5 fingers in each hand.
If you put your two hands together, you make a new set of fingers out of the first two (the hands)
How many fingers in the new set, count them: 10. When you count by 1, you are in fact adding 1 to the previous result
You could see this new number of fingers as some combination (putting together, gathering) of the two numbers 5.
Mathematically you call this operation (combination) addition
The simplest things are sometimes the hardest to explain, or put into words.
Terminology: words
Let a and b be two numbers (Please do not ask me about their values: make up your own.)
The addition operation is symbolized by the + sign.
Addition of a and b, or of b to a is written as a+b.
The result of the operation is called its sum
If I write a+ b= c, where c is some number
b is called the addend ( it is short for addendum), c is the sum . For some authors both a and b are called addends. You could say that any number involved in an addition (operation) is an addend.
Properties
2+3= 3+2=5
For arbitrary numbers (numbers you may choose), you can write
a+b=b+a
The order of the terms (which comes first, and which second) has changed but the result is the same. This is a property that is common to (shared with) all additions. It has received a scientific name, commutativity.
The addition is a commutative operation and we write a+b=b+a
Now imagine you have to add three or more numbers
2+5 +17
You can do that in two steps
Add 2 and 5, then add the result to 17
(2+5)+17
You can also add in another way: add 5 and 17, then add the result to 2, which you write as 2+(5+17)
Let's compare the results of the two ways
(2+5)+17=7+17=24
2+ (5+17)=2+22=24
The two sums are identical. (2+5)+17=2+(5+17)=24
For other undisclosed numbers we can write
(a+b)+c=a +(b+c)
This property is verified by all sets of three numbers. It is a general property called associativity
There is another property
Neutral element.
In every set of numbers that has addition as a rule there is an element, call it e, such that
for any number a of the set a+e=e+a=a
the element e is called the neutral element, in that when added to a number it gives you back that number. For real numbers, the neutral element is the number 0.
Summary of words introduced :
To add, addition, terms, addends, result, sum, commutativity, commutative property, associativity, associative property, neutral element.
I will stop here, believing that you have ADDED many new terms (words) to you vocabulary.
Dec 12, 2013 | Computers & Internet
I have a samsung 5620monte. im trying to activate my mobile tracking feature. it prompts me to type a mobile number to be my recipient, after i typed a mobile number i was asked to add a country code, im...
You need to insert the country code in front of the number only.
I think your country(Philippines) code is 63.
entre the phone number as
+63-XXXXXXXX
XXXXXXXX-Telephone number
Thank You
Aug 10, 2010 | Samsung S5620 Cell Phone
How do I add Exponents on my T1-30xa calculater
There is a rule of Algebra, that says
(a^m)[x] (a^n) = a^(m+n)
a is the base of the power, n, and m are the exponents. As you can see, multiplying two powers of the same base is equal to the power of the (common) base with the sum of the exponents.
If that is what you had in mind, the calculator uses the rule correctly and no intervention from you is necessary.
If you enter (2^4)[x](2^6), the calculator will give 1024, which is 2^10.
I may be wrong, but what you call add exponents refers really to performing addition where addends (the terms you add) are arbitrary powers, such as
2^7 + (5.5^3) - (1/3)^4
Once you enter a power term, the calculator calculates it and the result is now just a number. It can be added, subtracted, multiplied
For the exemple above
2 [Y to the x] 7 + (5.5)[Y to the x] 3 -(1/3) [Y to the x] 4 [=] yields 294.3626543
For the cube of 5.5 you can use the key combination [2nd][X^3]
Hope it helps.
Oct 08, 2009 | Texas Instruments TI-30 XIIS Calculator
1992 Isuzu Rodeo Distributor wires
On the 3.2L distriburorless ignition, the firing order is a straight 1-2-3-4-5-6.
Cylinder numbering .
88c39f7.jpg-
Hope this works for you
Jul 05, 2008 | 1992 Isuzu Rodeo
Where did all the memory go?
try running Windows scandisk and then defrag on the Sandisk player.
Jun 10, 2007 | SanDisk Sansa e250 MP3 Player
HP 10bII Calculator Logo
60 people viewed this question
Seeker5211
Seeker5211
