Question about Gateway Solo 5300 Notebook
Gateway 5350 password forgotten.
I have a Gateway 5350 that I can't get past the password ( Novell). How can I boot and erase the passwords. I havent used in years so I forget., Thanks for your time.
  • Anonymous Feb 27, 2009
    i have a gateway laptop, I forgot the password. HELP
Get past loolst admin password/gateway/vista
You will need a friend and his/her computer to help you with this. On their computer, download a program named " Windows Password Recovery Tool" to a CD. You will need to go into your BIOS to have your first boot item as the DC Rom for this to work. Place the CD in the drive, boot up, and follow instructions. This will erase your Admin password, and allow you to get into the computer. Afdter that you can select a new password, but would be a good idea to write it down this time. Good luck.
Sep 30, 2013 | Gateway GT5220 PC Desktop
Bios password
Do you mean the password necessary to boot your computer into the setup program? As a rule, unless an administrator initially did a restricted password that locks the motherboard; there are no restrictions. You may try to refresh the BIOs by taking out the power cell and shorting the memory connections. If you reset the bios, all of the current information will be erased with the exception of the instruction sets. Reinserting the power cell and will all connectors in place; turn it on and try to reset the date, time, etc. See if that works for you.
Nov 20, 2012 | Acer Aspire 5350 5750 5750g 5750z Series...
I can't get past the initial login screen for my Gateway dx4870. when i enter the password it says incorrect password
You can reset Gratewall login password with Smartkey Windows Password Recovery, just do as the following,
tep1: Get Smartkey Windows Password Recovery from: http://www.recoverlostpassword.com/products/windowspasswordrecovery.html.
Step2: Install and launch it to any accessible computer.
Step3: Use a blank and writable CD/DVD to burn Windows password reset disk with the tool.
Step4: Boot the locked computer from CD/DVD.
Step5: Start to perform Windows password hack with the burned disk.
Step6: Reboot computer and login to the machine without password.
Jul 16, 2012 | Gateway DX Computers & Internet
I cant get past power on and dont remember password
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password
As an easy method to recover the forgotten Windows password, there are only four steps as follow:
Step1: Download Anmosoft Windows Password Reset V8.0( http://www.resetwindowspassword.com
)and install it.
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
Aug 15, 2011 | IBM ThinkPad T43 Notebook
Bios password forgotten, how can I reset password?
To reset the BIOS password read the information from this link.
In case of your Gateway laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
Jan 30, 2011 | Gateway M285-E Notebook
Novell client
Does safe mode work for removing it? you may have to reinstall the os. but try safe mode first.
Aug 14, 2009 | Computers & Internet
Novell 4.91 Password page
You can boot from the xp cd and install xp over the Novell
Dec 04, 2008 | Gateway Profile 3 PC Desktop
Gateway Laptop NT3707- FORGOTTEN PASSWORD
find system commander!!! or ERD Commander.. the geek squad CD would work as well but make sure you boot from the CD and choose the password utilities.
Jun 16, 2008 | Computers & Internet
Forgotten hdd password
HDD password> Is that the same as a BIOS password? You can pull the MOBO battery or look for a tiny jumper that says CMOS, reset jumper to other position for a few seconds and replace to original position then boot up. If all else fails, there is a floppy boot disk you can make from the internet that will allow you to reset a login password, look up on Google.
Mar 03, 2008 | Computers & Internet
Forgotten passwords
*#7370# After typing this phont will ask for security code, Defalt code is12345
Jan 09, 2008 | Nokia 7610
Computers & Internet Logo
130 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
