Question about Pioneer Car Audio & Video
I want to sell my Pioneer 10'' 350W BAND PASS BOX Car Speaker
I'm trying to sell my Pioneer 10'' 350W BAND PASS BOX Car Speaker, but I don't know for how much I sould sell it. It looks brand new, the only thing that's missing are the cables, I only have the stareo
  • 44 Answers
Search google the model of the pioneer, and try and find a used or new price and go from there.
Boxes are cheap and can be picked up locally anywhere for around $20-30 bucks used so dont charge a rediculous amount because it has a nice box.
For instance if your sub was $100 new. and then you bought a box for $30-50 new.
i would probably only sell it for $80 Max that is in PERFECT condition not blown or anything.
nobody will buy something that is $20 cheaper than retail priced especially if it is used.
I have been in sales and online sales for years.
Selling used items your prices stay low so the sale can happen. Priced to high people will just go buy it brand new if they want it.
I would recomend selling through Craigslist.Org. Local and easier than Ebay
Posted on Feb 17, 2009
I put a sub in my 2002 Altima but when I turn it up the bass cracks on the door speakers??? What do I do to get all the bass on the sub
Hi Ethan,
What you're looking for is called a "crossover". A crossover is an electronic filter for an audio or speaker circuit. In an audio circuit, a crossover is used to prevent or pass certain frequencies or a range of frequencies from passing through it. Since your sub will reproduce the bass or low frequencies, you don't want other speakers to reproduce them. A band pass filter on your door speakers will do this for you. A band pass filter passes only a range or "band" of frequencies and blocks those that are above and below the range or band of frequencies selected. Installing a band pass filter will prevent the very high & very low frequencies from getting to the door /dash speakers. Likewise, you should consider connecting a low pass filter to your subs, too. The low pass filters work a little differently from of the way band pass filters work - they only allow low frequencies to get to the sub - blocking all the other higher frequencies (your other speakers are better suited to reproduce those). Lastly, you would install a high pass filters on tweeters. Tweeters are designed to reproduce only the high frequencies - sending mid and low frequencies to them is wasting power and can cause damage to them.
You purchase the filters for specific crossover points (the block / unblocked point) as determined by the individual speakers. If a sub has a frequency response of 20Hz - 100Hz, a low pass filter of 100Hz would be ideal. Remaining filters would need to begin at 100Hz - assuming the mid-range speakers have a frequency response beginning at 100Hz. A band pass filter of 100Hz - 3KHz would fit the bill nicely if the mid-range speakers go up to 3Khz Match the high end of the band pass to the high end of the frequency response of the mid-range speakers. Next, a high pass filter at 3KHz would allow only the high frequencies to your tweeters. Basically, you want to have the entire audible range 20Hz - 20KHz covered by the speakers and have the crossover points that match the frequency response ranges of the speakers.
I hope this helps & good luck!
Apr 12, 2012 | Pioneer Car Audio & Video
Whats the best kind of amp to use with two of these in a box
Walmart sells a 760 watt 2 ch amp.....It works well with these type of subs. Or any amp rated @ 150 watts per channel RMS. Start with the low pass filter on and with it hooked up and playing raise amp level until distortion can be heard through subs...then back off a bit...Your level is now set.
Sep 17, 2010 | Pioneer TS-W1201C Car Speaker
What is the optimal volume for a speaker box for two Pioneer TS-W26C sub woofers? I know that enclosure speakers have an optimal volume for the boxes, however, I can not find out what the optimal volume...
try this site very hepfull if you can find all the speakers spec's.http://www.ajdesigner.com/speaker/ajvented.php . if you have the latest pioneer speakers they were designed for small enclosures if you imput speaker code in to google search you should find all the details you need .
Sep 05, 2009 | Audio Players & Recorders
Equalizer setting help
try to use the preset equalizer settings after which you can come back to the parametric equalizer and adjust to your own taste. no problem if you don't connect the subwoofer just make sure you set the hi-pass filter to off so that you will hear the full range to your speakers. but, I advice you to put a subwoofer. There is more dynamics to the lower freqs too. don't adjust the source level if there is no problem. take note the EQ of your head unit is a parametric equalizer. hope this helps while you read about parametric EQs.
Apr 20, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
My pioneer vsx-406 receiver won't get out of mute.
find the reset button and reset the unit,in sometimes is behind the face so detach the face.
Mar 19, 2009 | Pioneer DEH-P2900MP CD Receiver...
5 stage band pass sub box, 1 sub stolen, box built to spec subs
I would try walling it up unless you are going to buy 2 brand new subs. the problem is the older power subs had such small magnets so they needed alot less air space inside the box. Unless you can find the EXACT subs this box was made for I would recommend chopping it and doing a single sub. if you try a replacement sub go with the 12" P1 series they are a close match for the power 12's of the past.
Mar 06, 2009 | Rockford Fosgate Car Audio & Video
Chrysler Pacifica Aftermarket Radio Problems
Here is the solution:
Their is a chrysler amplifier some where in your pacifica.In order for your signal to reach the speakers you need to buy a box (from bestbuy install ,or any car stereo install place)that allows the signal to "pass thru"to the speakers.
Nov 22, 2007 | Car Audio & Video
Car audio amp or speakers bad?
If you know how to use a multimeter, you can test the amp this way:
-unhook the subs
-hook up a cheapie speaker you know for sure works to one of the channels
-unhook the audio inputs
-turn the amp on
-set your meter to VDC
-put the positive probe on the inside of the input connector, being sure you make contact with th inner contact
-take the negative probe and tap it on the outside of the connector
What you are doing is sending a low voltage (replicating an audio signal) into the amp audio circuit and allowing the amp to amplify it. If the amp makes the speaker pop each time you strike the probe, the amp is working.
There is an inherent problem with band passes. The naturally filter out high frequencies like a crossover, including distortion, so it makes it hard to hear when the subs begin to protest.
Nov 22, 2007 | Dual XAF-460 Car Audio Amplifier
Pioneer ts w33c
Recommended volume for these speakers is 1-2 cu ft each speaker. Best materials are marine grade plywood and epoxy resin/matting. decide what space you think you can spare and see if you can make a box that will be about the right size in the space. always try and leave as much space behind the speaker as the speaker takes up from the front. look at the link below for some ideas of the ready made boxes you can buy. http://www.pioneerelectronics.com/pna/v3/pg/album/compare/0,,2076_310069931,00.html the speakers you have will need at least 2 one inch ports each in the back of the box, or equivalent. completely sealed can have bad effects on these speakers at high volume. I personally recommend keeping both subs in a seperate box completely, but a good solid box with a divider will probably work - make sure that no holes of any size exist between the two as this will cause distortion with certain channel set ups and is best avoided although some good results have been achieved with back flow between sub sets - it is a bit too hit and miss to be worth trying. If you need ideas how to fit these into your car so they look good - check out http://www.mtv.com/ontv/dyn/pimp_my_ride if you haven't seen it, check out a few episodes and you will get some great ideas and construction tips. Hope this helps :)
Mar 08, 2007 | Pioneer TS-W33C Car Subwoofer
Car Audio & Video Logo
272 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
