Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Water is entering the washer, when not in use.
Water is dripping into the drum in the back area one drop at a time. The machine is not turned on and the lid is open (in the off position). The water accumulates to a few inches over a couple of days, or until the machine is being used. If the machine is not used for a long period of time, when we are not present; the possibility of overflowing causes concern.
  • 46 Answers
The solenoids on your machine that let the water flow in are obviously leaking, but in my opinion not enough to be a real issue. It is always safe practice to turn off water sources to your washer at the fawcets after use, this can also save you from a possible flood if the hoses burst from age and deterioration. You should have a repair tech fix the solenoids though. But you can get away with that for a while if you turn off the water.
Posted on Feb 10, 2009
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Water leaking (dripping) into the drum when machine is off. Drip is coming from where water dispenses into the machine to fill the drum.
Hi just read your posting.The fault with your machine is a faulty water valve.1st turn off the cold tap to the machine and leave for a couple of hrs.If the dripping stops you have a faulty cold valve.If the dripping does not stop then turn off the hot tap and that should stop the leak.Either way to fix this fault a water valve must be replaced.Or you can stop the drip by just turning the taps off after the washing has finished.Hope this helps and please reply for further help if needed.
Jun 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Slow drip near back of lid
Hi there.this may be water dripping from the injector tube where the water actually enters the bowl.It is normal to drip for a short while after the machine has just been used but if it is a constant drip then you probably have a faulty inlet valve.Try this,turn off one of the taps & see if dripping stops.if not,turn off tha other tap & see if it stops.this will tell you which of the valves are leaking.You could just turn the taps off after use,that would save having to replace it.Hope that helped you.if not then give more detail if possible please.cheers!
May 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
Slow drip of water inside the drum. Don't see no moisture but I can hear it dripping. No Moisture on the floor. Any ideas where it could be dripping from?
Turn the water faucets off and listen for the drip to stop.
If the dripping noise stops,replace the water inlet valve on the washer were the hoses connect.
Enter your model number in the site referenced here for parts.
www.appliancepartspros.com
Jan 24, 2010 | Maytag Washing Machines
Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Sep 07, 2009 | Maytag PAV2300 Top Load Washer
Duet model ghw9400pw0 - hot water supply keeps dripping into drum area when cycle ends.
This sounds like a solenoid valve is malfunctioning -- may just need removing and cleaning or tightening -- solenoid valves are connected to the end of the water supply hose on back of machine.
Charlie
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag quiet Plus 2 cloths washer
machines not on and water continuing to enter machine????youll need to replace the machines water valve(its not shutting properly). in meantime turn off water supply when not using machine.
Feb 26, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Water dripping into drum when machine not in use
Your solenoid valve is probably not sealing it is on the back on the washer where the water lines connect. They do go bad after a while and are fairly cheap and easy to replace. $20-$30 dollar range. Just remember to unplug the washer before you replace it. You should be able to order it online using the model number and serial number of the unit. Good luck You should only need a 5/16 wrench or socket and channel locks to replace this item.
Jan 29, 2008 | Washing Machines
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
44 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
