Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
How to use a motorola battery maintenance system
I need instructions on how to use the Motorola battery maintenance system plus model # wpln4079br.Not sure how to run?
  • Motorola Master
  • 1,654 Answers
We are unable to find a user manual posted online. The Motorola part number is 6880309J85 you should be able to get one from your local Motorola dealer for $15 or under. (If not, post again and we will help you purchase one.)
Posted on Feb 11, 2009
How do I wipe a Motorola bq50 with a locked Sims card
What is the FCC ID? Starts with IHDT and is printed on phone. Or go to Motorola Support Find Answers Motorola Mobility Inc then check the Don't know option and then search for reset instructions. BQ50 is the battery not the phone model.
Mark
Motorola Support
Jun 05, 2015 | Motorola Cell Phones
Subsidy code
Specify the Motorola Mobile phone model correctly.You have specified only motorola battery model.To get subsidy code,i would suggest the site Classicunlocking.com after getting code for motorola phone and unlock it step by step using the unlocking instructions.
Jul 23, 2013 | Motorola Mobility (BX40) V8V9mV9hI9U9...
Special cod required for motorola bk70
Do you need to Unlock Your Motorola Phone from Network lock?
What is the correct model of the Phone.. BK70 is motorola phone battery model.You can check the mobile phone model,By removing battery and see the Battery slot or you can check it in motorola phone panel itself.Then get the unlock code for Motorola Phone at Simpleunlocking.com/motorola/rs16wp8/ and unlock it easily.
Sep 22, 2012 | Motorola Mobility Bk70 Battery
Where can i buy batterry and charger of motorola i550 plus?
The battery is readily available online or through any Motorola 2-way radio dealer. You can use part number NTN8971 or NNTN4190 NiMH battery. The phone should also accommodate 4 AA batteries instead of the NiMH battery. (Be certain to never try charging the phone with the AA batteries inside, as it is not designed to do this.)
The wall charger part number NTN1680 is listed as being no longer available from Motorola Solutions. However, during a Google search it appears several vendors still have these available for just over $7 US dollars.
The i550 was a primary phone used in the iDEN Nextel system. It operates on 800 MHz and likely needs to be connected to a system to work. I do not know if it will work as a 2-way radio without being connected to a system. The type of system these were used on has been completely or for the most part shut down. According to this article it will be completely shut down by June 2013. http://www.computerworld.com/s/article/9227557/Sprint_to_shut_down_Nextel_iDEN_network_next_year
Here is a link to the user manual for the i550 http://www.cellphones.ca/upload/manuals/motorola_i550plus.pdf
Best regards.
Sep 21, 2012 | Nextel Motorola i550 plus cell phone w/...
My company has a Motorola battery maintenance system plus modle wpln4079ar. The employee that used this item is no longer with the company and we can not find the manual. I would like to use the system...
Basic instructions: When you have the battery, in the appropriate cup/adapter of your BMS WPLN4079 charger, wait for any sporatic activity on the screen to cease (there is usually a little number jumping from dropping the battery in), then press the analyze (or condition) button. Now your battery will cycle for anywhere from 1 to 4 hours. When it is done you will see a number representing the mAH on the screen. You take this number and divide it by the mAH capacity of the battery. This will tell you how good your battery is. 70% and above is acceptable. Anything below 70% you should consider replacement.
Conditioning your batteries once per month is usually sufficient. Rechargeable batteries have a two year life expectancy. With reconditioning on a monthly basis you can usually get up to 3 years out of a battery, if it is treated well.
You can read the date code on a Motorola battery by find a 3 or 4 digit number on the battery. The first number(s) are the year and the last two digits are the week of the year. Example 1130 or 130 would be 2011 the 30th week.
We are unable to find a user manual posted online. The Motorola part number is 6880309J85 you should be able to get one from your local Motorola dealer or online for $15 or under.
Best regards.
Jul 25, 2011 | Motorola HT1000, MTS2000, MTX8000/9000...
Further question on BMS wpln4079br
Cycle test sees how many charge cycles a battery has left in it. The average number of charge/discharge cycles of a new battery is: NiCd 500-700; NiMH 300-350; Li-Ion 400. (These are averages, batteries will differ.) Analyze looks at the mAH capacity of the battery. With this number you can see what capacity the battery is still holding. (How much gas will fit in the gas tank.) You can improve this number often by running the conditioning cycle. These are better explained in the user manual which comes with the unit. Motorola part #6880309J85.
Jun 07, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
WPLN4079BR problems
When you have the battery, in the appropriate cup/adapter of your BMS WPLN4079 charger, wait for any sporatic activity on the screen to cease (there is usually a little number jumping from dropping the battery in), then press the analyze button. Now your battery will cycle for anywhere from 1 to 4 hours. When it is done you will see a number representing the mAH on the screen. You take this number and divide it by the mAH capacity of the battery. This will tell you how good your battery is. 70% and above is acceptable. Anything below 70% you should consider replacement.
Note: This part number is for a BMS charger, not an Impress. However, you can charge and condition impress batteries on this charger provided you have the correct cup.
Apr 15, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola GP68 Manual
**** you can find it here.
http://ca.wrs.yahoo.com/_ylt=A0oG73C.etJJ4sgATg_rFAx.;_ylu=X3oDMTBzZTloODhnBHNlYwNzcgRwb3MDMjUEY29sbwNhYzIEdnRpZAM-/SIG=12camdtrs/EXP=1238617150/**http%3a//www.fsjagers.com/video/Motorola_GP68_manual_2.pdf
Hope this helps
Mar 25, 2009 | Radio Communications
Passwords unlock
Hello Sir,
Please Visit This site for More help
http://www.motorola.com/consumer
/v/index.jsp?vgnextoid=069265847be0f010VgnVCM1000008206b00aRCRD&show=productHome
http://www.helpmemoto.com/frmTextHelp.aspx?ModelId=14&FeatureId=18
Unfortunately our programmers have not yet added the Motorola V365 to our software. However we are always adding new models, and hope to have the V365 added within the next few weeks. Please check back often for updates on our Motorola V365 service. In the meanwhile, please check our Cingular AT&T Unlocking solution to unlock this phone.
Model Name: Motorola V365
Release date: 4th quarter, 2006
Networks that sell this phone : Cingular (AT&T Wireless)
Estimated time until unlock software compatibility: 2-3 weeks
Other unlock solutions for this model : Cingular AT&T Unlocking
Motorola website link: Motorola V365
Good Luck
Please Don't forget to comment
cheers!!!!!
Feb 01, 2008 | DataViz MacLinkPlus Deluxe 14 and...
Battery
well...sir they do die quickly no matter the age of the battery......but you should buy a new one
Jan 26, 2008 | Motorola Mobility RAZR V3
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
2,160 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
